Author Topic: Gold Blend. A Coffee Jar Engine........  (Read 108560 times)
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
Re: Gold Blend. A Coffee Jar Engine........
« Reply #75 on: October 14, 2011, 07:16:28 PM »
That's sooo good, David!  Your good job shows in spades with such a large engine running on that tiny flame.
Kudos, my friend!
Dean
Dean W.
Shop Projects:
« Reply #76 on: October 15, 2011, 10:40:06 AM »
Excellent result David ... just goes to show the research you put in paid off I think, your work upfront with the design and how it was eggsecuted is what made it run so well on the tea light.  :thumbup:
« Reply #77 on: October 15, 2011, 07:00:46 PM »
David,
Very splendid  :clap: :clap: :clap:
Offline BK
« Reply #78 on: October 15, 2011, 11:35:05 PM »
G'day David, just read this thread, what a clever design/build and you could not wish for a better result, runs great. :clap: :clap: :thumbup: :thumbup:
I don't know any egg yolks so I'll just scramble outa this nest!!  :beer:
If it aint broke, don't fix it!
« Reply #79 on: October 18, 2011, 03:51:34 PM »
Thanks for all your kind words Chaps.  :thumbup:
Chuck, It would run very well on a stove. Not sure how long the balsa displacer would last though!  ::)
Singed it, with the  meths burner. But, the tealight does it no harm.
Hi Bernie. Nice to see you've joined in.
"Finished" the engine today.
After warming up with a drop of meths, it ran on the tealight for some 2 - 3 hours. All ok!
It needs a base/ firebox now.
Found a stainless steel dog's bowl, in Wilkinson's for £1.35........  :D
« Reply #80 on: October 18, 2011, 05:47:17 PM »
Very nice indeed  :thumbup: :thumbup: :thumbup:
It is amazing the stainless kitchen ware you can pick up for little money
« Reply #81 on: October 19, 2011, 11:05:01 AM »
Very nice to see it running on a tiny tea candle, David, and a very interesting use for that pan.  The next project I expect will use the rim and remains of the omlet pan I expect, right?  It never ceases to amaze me how quiet the stirlings are.  That is a fine runner, and a good show of what can be done with just what is found lying around. very nice indeed! :bow: :jaw: :beer:  Cheers, mad jack
Offline stirling lad
  • Stirling Scotland
« Reply #82 on: October 19, 2011, 04:59:36 PM »
another fine job from the stilldrillin hot air engine factory..
first class job mate.. well done... :thumbup: :clap: :bow:
   .mike...
« Reply #83 on: October 19, 2011, 07:22:54 PM »
True John ... but one thing troubles me ...
This 'stainless steel dog'   stuff ...
Funny place, Chesterfield ...
Bent spires, stainless steel dogs ...
Hmmmmmmm ....
BC
« Reply #84 on: October 20, 2011, 08:18:29 AM »
Thanks again, for your kind comments Chaps!  :thumbup:
Hmmmmmmm ....
BC
There's nowt wrong here.  :thumbup:
But, we do have funny neighbours. Them over the fence, who cause all the problems.......  ::)
Would you like to have to live next door to you?
 :D
« Reply #85 on: October 20, 2011, 02:21:44 PM »
 :D
My neighbours think I'm a little treasure ...
I sign for their parcels ..
And victimise them with my tomato glut ..  :thumbup:
I also keep the noise below 140 dBA ... err... occasionally.
PS   Taller fence ???
BC
« Reply #86 on: October 21, 2011, 05:58:02 PM »
Adapted the feeding bowl/ base.
Piece of 10mm ply. 7.5" square. Screwed bowl on, concentric..........
http://i110.photobucket.com/albums/n95/Dayjo/P1010639.jpgGold Blend. A Coffee Jar Engine........
Then screwed to faceplate.......
http://i110.photobucket.com/albums/n95/Dayjo/P1010648.jpgGold Blend. A Coffee Jar Engine........
Faceplate in r/t chuck, and 2mm endmill..............
http://i110.photobucket.com/albums/n95/Dayjo/P1010644.jpgGold Blend. A Coffee Jar Engine........
No problem! Then opened out to size.......
http://i110.photobucket.com/albums/n95/Dayjo/P1010646.jpgGold Blend. A Coffee Jar Engine........
The square backing ply, rested on the machine table holding against rotating. While opening out the doorway.......
http://i110.photobucket.com/albums/n95/Dayjo/P1010649.jpgGold Blend. A Coffee Jar Engine........
The corners locked into the T slot. For the rear vents.......
http://i110.photobucket.com/albums/n95/Dayjo/P1010652.jpgGold Blend. A Coffee Jar Engine........
Rear view......
http://i110.photobucket.com/albums/n95/Dayjo/P1010656.jpgGold Blend. A Coffee Jar Engine........
Front view.......
http://i110.photobucket.com/albums/n95/Dayjo/P1010657.jpgGold Blend. A Coffee Jar Engine........
Made myself a start up burner.
Nub end of 3/4” brass. Opened out to 12mm x 1/2” deep. Stuffed with wick, will hold enough meths to burn for 2 mins or so. Then swap to tealight.
http://i110.photobucket.com/albums/n95/Dayjo/P1010638.jpgGold Blend. A Coffee Jar Engine........
Now, need to experiment to find the optimum candle height......
http://i110.photobucket.com/albums/n95/Dayjo/P1010660.jpgGold Blend. A Coffee Jar Engine........
« Reply #87 on: October 21, 2011, 06:09:52 PM »
That was cleaver Dave:-it didn't come out as a dogs dinner  :D.
When you hand the board vertical what was it clamped to, from the pic it looked like you were using sky hooks  :scratch:
« Reply #88 on: October 22, 2011, 03:28:26 AM »
Nicely shown as usual
Have you upgraded to 2 candlepower ? :coffee:
« Reply #89 on: October 22, 2011, 03:36:34 AM »
Thanks Stew!
I was a bit pleased.... No distemper, or hard pad. The whole job went much better than expected. (Very thin stainless spinning).  :D
Sky hooks? Nah! Not even a short leash......
I have a tilting r/t. Faceplate boss, gripped in chuck jaws. Just angled it over, until the ply edge, or corner, rested on the machine table.
I could then take off, and re set to position, as often as needed...... :thumbup:
« Reply #90 on: October 22, 2011, 03:46:56 AM »
Thanks Dave!
TWO candles!  :bugeye: Steady on!
Nomate, not just yet. The bowl was a little deeper than I wished. (This thing is growing higher by the week!). Still needs a base board. :scratch:
The candle needs to be held on a plinth, some 3/4" high. Just making do, so far, with a spent holder and a jam jar lid.
The higher skirt/ deeper bowl, will allow me to make up a meths burner. Sometime...... Mebbe......  ::)
« Reply #91 on: October 22, 2011, 06:55:17 AM »
OK, we'll believe you!
Going OT : at least you're not (yet?) in the (Two Ronnies) confusing territory of needing 4 candles !  :coffee:
« Last Edit: October 22, 2011, 08:58:42 AM by DMIOM »
« Reply #92 on: October 22, 2011, 07:05:35 AM »
Yes I always have a big smile when I read and look at your solutions.  :)
Very clever.  :clap: :clap:
« Reply #93 on: October 22, 2011, 08:10:46 AM »
Very ingenious, David D.  I give you  :thumbup:  :thumbup:  :thumbup:  :thumbup:  :thumbup:
« Reply #94 on: October 22, 2011, 12:22:11 PM »
Hi David, very ingenious design of the stand, very effective means of cutting out and getting things in line.  I keep considering a slot in the wick tube of a burner, and a small gear with a stem to wind the wick up and down, but haven't got to it yet, still moving the burner around to keep my engines running evenly.  I took apart one of those fireplace lighters, with the long snout and the pietzo and found it has a good size reservoir and is refillable, and hope to put it on one of my flame suckers, with the lever on the reservoir to adjust the flame, with a simple burner head, and finding a place for the piezo to go.  The alcohol works so well, but it is a bit finicky about adjusting and getting it just right.  I'm looking forward to the finished product, burner, pan, all happily tied together. :jaw: :bugeye:  Very nice indeed :beer:  Cheers, mad jack
« Reply #95 on: November 08, 2011, 06:42:14 AM »
Thank you all, for your continuing positive comments, Chaps. They're all, very much appreciated!  :thumbup:
I found some nice, 8" x 11" rubber wood chopping boards, in a local shop.
Bought a spare, for later.....
http://i110.photobucket.com/albums/n95/Dayjo/P1010664.jpgGold Blend. A Coffee Jar Engine........
Hacked it roughly to round..... Then fixed to the faceplate/ rotary table set up, as before.
Roughed it to 7" diameter using a 12mm endmill.......
http://i110.photobucket.com/albums/n95/Dayjo/P1010668.jpgGold Blend. A Coffee Jar Engine........
Squeezed it onto the lathe, and radiused/ sanded the o/d.......
http://i110.photobucket.com/albums/n95/Dayjo/P1010684.jpgGold Blend. A Coffee Jar Engine........
Spot of varnish........
http://i110.photobucket.com/albums/n95/Dayjo/P1010733.jpgGold Blend. A Coffee Jar Engine........
This thing is getting BIG. Fifteen inches overall height, now.......
http://i110.photobucket.com/albums/n95/Dayjo/P1010737-1.jpgGold Blend. A Coffee Jar Engine........
Workshop time is non existent, at the moment. The end is so near, and yet so far......
I only need to make the candle holder to "finish".......
« Reply #96 on: November 08, 2011, 07:49:18 AM »
Nice work Dave.
Noticed in the last picture on the right, you've got your logo showing on Madmodder.  :clap:  :clap:  :clap: :thumbup:
« Reply #97 on: November 08, 2011, 10:04:07 AM »
Very nice  :thumbup: :thumbup:
« Reply #98 on: November 08, 2011, 01:27:52 PM »
Love it, it's brilliant!  :thumbup:
Offline arnoldb
  • Windhoek, Namibia
« Reply #99 on: November 08, 2011, 04:17:02 PM »
Great job David  :thumbup: :clap: :clap: - you must be getting on to finishing it now  :D
 :beer:, Arnold
