Author Topic: Casting Aluminum help please.  (Read 23135 times)
Offline FLOPGUY
« on: July 19, 2011, 04:51:37 PM »
Hello,
I am trying to cast aluminum. I am very new at this so pardon the simplicity on my knowledge.
I made a Furnace out of cynder blocks, I made a wire rack to hold the crucible out of 1/2' rebar.
I used a metal can as a crucible. I used a propane weed torch as the burned (instructions said it can achieve 3000 deg.)
I tried to do lost foam casting. I tried to cast a crank handle. I put the foam in my sand casting box. I melted my aluminum, but I notice as I was pooring that It seems to get almost a skin layer as I pour and it did not fill the entire foam.
I almost think that I am not getting the aluminum hot enough or am I doing something else wrong?
Thank you,
Mike
Re: Casting Aluminum help please.
« Reply #1 on: July 19, 2011, 04:57:20 PM »
Hi Mike
Thank you,
Mike
Sounds like you answered your own question  :med:  ,,,,,,,,,,, probably not hot enough  :thumbup:  ,,, If you have a thin walled can it will loose heat quickly .
More heat ,, thicker pot  :dremel:
Offline Chazz
« Reply #2 on: July 19, 2011, 05:16:43 PM »
Also, did you 'skim' the surface just prior to the pour?
Chazz
Offline dmbasher
« Reply #3 on: July 19, 2011, 05:29:14 PM »
I believe that industry melts out the foam before casting. Use anti - gassing tablets so you dont get a casting looking like Swiss cheese. At least use a thick steel pot or better, a proper crucible and make sure you have more than enough molten metal to do the job.Good luck.
Offline FLOPGUY
« Reply #4 on: July 19, 2011, 05:39:16 PM »
Chazz
I did pretty much, but I went fast because I was affraid of it cooling down
Offline FLOPGUY
« Reply #5 on: July 19, 2011, 05:44:19 PM »
Do you think I should get a cast iron pot?
I did a couple of sample casts at first making much thicker things, but the handle I am making is thinner.
I don't quite understand the ant-gassing tablets. How does that work?
PatJ
« Reply #6 on: July 19, 2011, 06:05:58 PM »
I have noticed that some foam is pretty high density, and is much thicker than the typical "styrofoam" material.
A thick foam may not vaporize completely, expecially with AL which melts at a somewhat low temperature than some of the other metals.
The internet lists the melting point of AL at 1220 degrees F, but this may vary with the exact type of alloy.
I think the total output in BTU's of the burner is also important, as well as having a furnace that can direct most of that heat into the crucible.  The temperature of the burner is not relevant if you can only heat up a 1" diameter spot on your crucible.
Casting seems to involve several arts including chemistry, metalurgy, non-linear shrinkage, pour rate, gating, solidification, slag removal, etc.
Gassing also seems to be a problem with some metals, but not necessarily all metals.
Having the correct porosity of moulding and core sand seems to be critical, as well has having the correctly sized and placed vent holes.  Gates have to be located in the correct position or you will get solidification of the small sections before the large sections are filled.
The more I read, the more I see just how much of an art it is, and an expensive art at that.
Edit:  Some metals absorb gas when they are melted, and release this gas when they solidify.  If these metals are not degassed prior to pouring, then bubbles form in the casting when the metal solidifies.
I have been studying the book "The Complete Handbook of Sand Casting" by C.W. Ammen.
If you are going to achieve any level of consistency in your pours, you will need to read and understand all of the terms and proceedures in this book, or a book like it.
Even those who have mastered the art of casting have a certain amount of casting failures.
Offline FLOPGUY
« Reply #7 on: July 19, 2011, 06:21:12 PM »
I am not making a very big handle and I am not melting more than a pound of Alum.
I am using fairly dense styrofoam.
My furnace, I found that I needed to leave an opening to get the torch at it maximum. It consumed the air up in the furnace.
Offline Swarfing
« Reply #8 on: July 19, 2011, 08:07:01 PM »
For my burner i use a 25mm tube through the side (10" long), an 0.8mm welding tip soldered to a piece of tube supported in front of the tube, i adjust this in and out for best heat and adjust gas for best roar, then drop back a bit. No fancy setup at all.
Stainless steel canisters last longer than normal steel ones (4 uses then bin). buy a proper crucible for the long haul.
stick some wire into your foam when filling your mould sticking out the top, pull these out once compacted and it will help with the gassing. Works for me and very little failure.
Remember if you get very little shrink back when it is cooling then the gas is still in the casting (some grades of aluminium shrinks less than others). Just adding table salt can help (small amount then stir in)
Once in hole stop digging.
Offline bry1975
    • http://www.satintime.co.uk
« Reply #9 on: July 19, 2011, 08:08:31 PM »
I always thought casting aluminum/aluminium was a very dirty job some years ago I had the job of collecting cast ally drain pipes and other parts like roof finials the place was like a BLACK hole interesting people tho.
Bry
« Reply #10 on: July 19, 2011, 08:59:25 PM »
Mike,
Check this guys sight out. He's been doing this for sometime. Home Foundry
Here's one for lost foam casting that might help to. Lost Foam
Don't get burned.  :thumbup:
Offline FLOPGUY
« Reply #11 on: July 19, 2011, 09:56:21 PM »
Mike,
Thanks,
I am quite safety conscious.  :med:
