Author Topic: rg500 One off special  (Read 45262 times)
Offline timeone
« on: June 27, 2011, 04:48:20 PM »
Some of you guys may be 2 stroke fan so may like to see my rg500 im building ? well almost finished now but i kept a good log of pictures
It started about 2 years ago i managed to locate a 500 engine and all the electrical bits and a good set of exhaust pipes. at first i was going to put the motor into a zxr400 chassis but once id mounted the engine it looked all wrong i wasnt happy just at this time a aprilia rs250 frame appeared on ebay so i bought it and set about modifying it to fit the 500 motor, it took a bit of thinking and some clever ideas but soon the motor was fitted and all looked good i was pleased at this point i only had the motro, frame and swing arm so gradually bought forks wheels and all the other bits as well as making a lot of stuff
I ended up with a really nice looking one off special. im at the point i need to strip it down and paint everything and reassemble which i plan in the next few weeks though the final bodywork paint may not happen for a few months as im skint.
anyway ill sort some pictures out and post them asap
Offline mike os
Re: rg500 One off special
« Reply #1 on: June 27, 2011, 04:53:09 PM »
 :worthless: :worthless: :worthless: :worthless:
got the idea yet?  :D
Political correctness is a doctrine,  ... which holds forth the proposition that it is entirely possible to pick up a turd by the clean end
Offline timeone
« Reply #2 on: July 01, 2011, 11:37:50 AM »
Here you go
this is how she is now
the paint scheme ive decided on is this
http://i103.photobucket.com/albums/m141/beekuk/a1/fin.jpgrg500 One off special
http://i103.photobucket.com/albums/m141/beekuk/a1/7.jpgrg500 One off special
http://i103.photobucket.com/albums/m141/beekuk/a1/6.jpgrg500 One off special
http://i103.photobucket.com/albums/m141/beekuk/a1/5.jpgrg500 One off special
http://i103.photobucket.com/albums/m141/beekuk/a1/4.jpgrg500 One off special
http://i103.photobucket.com/albums/m141/beekuk/a1/3.jpgrg500 One off special
http://i103.photobucket.com/albums/m141/beekuk/a1/2.jpgrg500 One off special
http://i103.photobucket.com/albums/m141/beekuk/a1/1.jpgrg500 One off special
« Reply #3 on: July 01, 2011, 12:32:53 PM »
Huge 2-stroke fan! Building a 535cc RZ/banshee hybrid. RD over there...
Let's see some more!
Did you see that guy in Germany that is doing a huge RG500 project?? Basically rebuilding a frame etc...
« Reply #5 on: July 04, 2011, 07:37:30 PM »
Ringa dinga ding!!!
 :drool: :drool: :drool: :drool:
The smell of premix in the morning (unless you have the oil injection...)
Offline HS93
« Reply #6 on: July 04, 2011, 08:26:17 PM »
can you use Castrol R in the mix ?   :med: :med: :med:
                         :nrocks:  :ddb: Peter :ddb: :nrocks:
Offline timeone
« Reply #7 on: July 06, 2011, 04:23:48 PM »
dont think you can even buy castrol R anymore
there is something that smells like it but im using good old casrol tt
Offline Marauder
« Reply #9 on: October 01, 2011, 03:38:07 AM »
 If you want something that nearly smells the same as castrol R bung some cooking oil in the fuel.( only a little ) LOL
