Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to MadModder!
Home
Help
Search
Login
Register
Gallery, Projects and General
Project Logs
Big Marine Steam Engine
« previous
next »
Print
Pages: [
1
2
3
8
Go Down
Author
Topic: Big Marine Steam Engine (Read 164003 times)
doubleboost
Madmodder Committee
Hero Member
Newcastle Upon Tyne
on:
June 09, 2011, 05:24:19 PM »
You may remember the video i put up about casting a large steam engine cylinder.
Steady progress has been made machining it up.
Originaly i was going th build a mill engine but was talked around in to building a marine unit
Anyhow you like pictures
I will post some more later
Logged
http://www.youtube.com/user/doubleboost
sbwhart
Global Moderator
Hero Member
Smile, Be Happy, Have Fun and Rock Until you Drop
Re: Big Marine Steam Engine
Reply #1 on:
June 10, 2011, 01:23:14 AM »
Going well John
Where did the blood come from ?
Logged
Stilldrillin
Global Moderator
Hero Member
Reply #2 on:
June 10, 2011, 02:17:28 AM »
Looking good John.
The spattered specs show just how much effort you've put in, so far........
Logged
PekkaNF
Hero Member
Reply #3 on:
June 10, 2011, 03:16:13 AM »
That is pretty big.
Engine builders allways leave little on himself on every engine he builds: usually it is blood.
Logged
doubleboost
Madmodder Committee
Hero Member
Newcastle Upon Tyne
Reply #4 on:
June 10, 2011, 06:13:56 PM »
Its not blood its red paint (mind you i have bled for this engine)
More pictures
Valve chest patern
Logged
doubleboost
Madmodder Committee
Hero Member
Newcastle Upon Tyne
Reply #5 on:
June 12, 2011, 01:13:03 PM »
Time for a crank shaft
I was going to build a disc type (nice and easy) then Rob Wilson recond a built up crank would be easy
The engine will have a 3.4 inch stroke so the crank will be a nice meaty job
The 2 webs were welded together then machined in to submission
A bit of en8 bar wea turned up for the big end 7/8 diamiter with 3/4 shoulders 3 thou interfierence fit in the webs
25 mm stainless bar for the mains this was turned between centers (my first attempt at this )_
Turned down to be a nice fit in the webs then a 3 thou press fit
Rob pressed the job together for me 10 ton was mentioned.
Just to make sure i welded it as well
Back between centers for a final clean up
Welding allowed me to put fillets on the webs
To say i am pleased with the finished job would be a understatement
Even took some video of it going around
Pattern for the base next (i hate wood work)
Logged
arnoldb
Hero Member
Windhoek, Namibia
Reply #6 on:
June 12, 2011, 01:55:53 PM »
Good going John
- this is a nice BIG 'un
I love your drive dog
Regards, Arnold
Logged
sbwhart
Global Moderator
Hero Member
Reply #7 on:
June 12, 2011, 02:15:20 PM »
Those glass drive dogs are top notch, where did you get them from John.
Logged
Madmodder Committee
Hero Member
1915 C Cab
Reply #8 on:
June 12, 2011, 02:22:08 PM »
That's going to be some monster of an engine.
Great work John.
Logged
Brass_Machine
Administrator
Hero Member
Reply #9 on:
June 12, 2011, 02:46:27 PM »
Gonna be a big one. Are you going to power anything with it?
Logged
doubleboost
Madmodder Committee
Hero Member
Newcastle Upon Tyne
Reply #10 on:
June 12, 2011, 03:28:15 PM »
I think i should make some drive dogs as i am now addicted to turning between centers.
The dog in the picture came with a toy tool set i had as a child
Logged
doubleboost
Madmodder Committee
Hero Member
Newcastle Upon Tyne
Reply #11 on:
June 16, 2011, 09:33:24 PM »
While thinking about a base for the engine (woodern pattern)
Deceded to make the piston
Thought about using O rings
hopefully this engine will see steam so proper piston rings it is
I would normally have pictures of the tempering process but the wife (wor lass) has taken my camera on holiday with her
At least i have a weak in the shop
Logged
doubleboost
Madmodder Committee
Hero Member
Newcastle Upon Tyne
Reply #12 on:
June 22, 2011, 05:43:26 PM »
Engine base casting
MDF pattern
Mould looking good
Happy with that
Logged
Troutsqueezer
Jr. Member
Reply #13 on:
June 22, 2011, 06:48:32 PM »
I enjoy seeing your setups. Thanks for the pics.
Logged
-Dennis-
Once you see the bandwagon, it's too late.
doubleboost
Madmodder Committee
Hero Member
Newcastle Upon Tyne
Reply #14 on:
June 30, 2011, 05:59:12 PM »
Made some small patterns for the main bearing caps
Click the pictures
Logged
saw
Hero Member
lucky amateur
Reply #15 on:
July 01, 2011, 05:04:14 AM »
This is a pice of art, good work
Logged
_________________________
Greetings / Benni
Hero Member
Kempton Park, South Africa
Reply #16 on:
July 01, 2011, 08:25:25 AM »
Really good stuff
Excellent
Logged
loco
Jr. Member
Reply #17 on:
July 01, 2011, 08:28:15 AM »
So thats where my glasses went - the rose tinted ones
Logged
metalmad
Jr. Member
Reply #18 on:
July 02, 2011, 07:07:37 AM »
Hi John
Looking great mate
being able to cast your engine blocks
PETE
Logged
A little bit every day, sometimes the same little bit!
PekkaNF
Hero Member
Reply #19 on:
July 02, 2011, 09:04:06 AM »
Wee wuu
What metal is that engine base and works? Looks really nice.
Logged
doubleboost
Madmodder Committee
Hero Member
Newcastle Upon Tyne
Reply #20 on:
July 02, 2011, 06:09:50 PM »
The base is aluminium
The cylinder is bearing grade (alloybronze)
Logged
krv3000
Hero Member
Reply #21 on:
July 02, 2011, 08:21:12 PM »
oooo brill work
Logged
cfellows
In Memoriam
Sr. Member
Reply #22 on:
July 02, 2011, 11:06:16 PM »
Nice work, John. I'm looking forward to watching the progress on this one.
Chuck
Logged
doubleboost
Madmodder Committee
Hero Member
Newcastle Upon Tyne
Reply #23 on:
July 20, 2011, 05:45:15 PM »
Got a little bit more done
I needed a lump of bronze flat bar 1 inch thick by 3 inches square for the big end
It is nice to have a furnace
Flat bar cast up
Machined to size cut in half then bored to fit the crank pin (i turned a dummy pin to dead size and one .001 smaller)
To use as test pieces
Very happy with the fit Jjust nipping but still free enough to turn)
Con rod will be next
Logged
PatJ
Guest
Reply #24 on:
July 20, 2011, 09:44:27 PM »
Nice work John.
Pat J
Logged
Print
Pages: [
1
2
3
8
Go Up
« previous
next »
Project Logs
