Author Topic: Stonewashing anyone?  (Read 11377 times)
Offline bry1975
    • http://www.satintime.co.uk
« on: June 07, 2011, 06:03:25 PM »
Anyone tried the stonewashing process?  it certainly looks cool and probably quite similar to abrasive blasting.
Offline dickda1
Re: Stonewashing anyone?
« Reply #1 on: June 07, 2011, 07:55:09 PM »
Could you explain a bit how you stonewash a part?
-Dick
Skype: VladTheChemist
« Reply #2 on: June 07, 2011, 10:07:45 PM »
Almost looks like bead blasted. What is the process?
Offline bry1975
« Reply #3 on: June 08, 2011, 06:07:45 AM »
I believe it's tumbling/barrelling.
"Bill Coye from Tulsa does a very nice stone wash finish. He has a vibrator and buys two different media "rocks" from Brownell and spray WD-40 into the mix. His come out a very nice smoothe finish. "
http://forums.dfoggknives.com/index.php?showtopic=15923
Offline PTsideshow
« Reply #4 on: June 09, 2011, 05:45:29 PM »
It is an effect called stone washing as it should resemble the effect on the stone washed jeans.  Depending on the size and assortments of shapes and amounts of media a harder type media like ceramic works better. The thin oil is so less rusting rather than if a water based fluid is used.
With a smaller nozzled blaster and media and a light touch one could duplicate the soft bead blasted look.
It is also called matte effect in some circles.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline dickda1
« Reply #5 on: June 09, 2011, 06:16:17 PM »
PTsideshow is quite right.  In the states, stonewashing highlights the mottled appearance.  What we call abrasive tumbling is quite common.
I can barely keep up with modern American terminology.  Lived in England for a number of years, but must admit to still be surprised that I have not mastered the lingo on either side of the Atlantic. :doh:
-Dick
Offline bry1975
« Reply #6 on: June 12, 2011, 08:21:24 AM »
Thanks chaps.
Am hoping to make a very basic tumbler and see if I can replicate the stonewash effect, will run the barrel/tumbler of my father's Myford wood lathe.
