Author Topic: 1/8" ID Ball Races (Bearings) - UK Supplier?  (Read 18527 times)
« on: May 27, 2011, 10:06:57 AM »
Hi guys,
I`m after five x  1/8" ID Bearings - ideally the spec in the plans is 1/8" ID, 3/8"OD and 7/64" width. I`ve searched now for near 2 hours over the last week and I found one supplier who wanted £10 per bearing, with 5 to purchase I just can`t afford £50!!  I`ve tried all the usual suspects, bearings boys, simply bearings (although struggled as their site was slow) and ebay with no luck.
I don`t know if anyone knows a good stockest who might have them. I`m not looking for the exact spec, obviously the 1/8" ID is critical but I can fit around the other dimensions.
I know imperial are likely to be more than metric sizes but I can`t justify paying silly prices when I can get 3mm ID bearings cheap. Obviously then I have to start changing plans and I don`t fancy that with this built, especially in 5 different places where the bearings fit!
Hope someone can point me in the right direction.
Offline kwackers
Re: 1/8" ID Ball Races (Bearings) - UK Supplier?
« Reply #1 on: May 27, 2011, 10:16:36 AM »
Arceuro?
Doesn't look like they've quite got that size - but some fairly close.
http://www.arceurotrade.co.uk/Catalogue/Bearings/Ball-Bearings/Ball-Bearings---Imperial
« Reply #2 on: May 27, 2011, 11:14:40 AM »
Bearing station have some for £5.33/ea, albeit with a fatness of 5/32" rather than the 7/64" you'd prefer. Still not cheap, I'll grant you, I guess imperial bearings must have gone right out of fashion.
« Reply #3 on: May 27, 2011, 11:49:13 AM »
Chris -- The standard for American R-type bearings is .125 (1/8) ID X .375 (3/8) OD X .156 (5/32) W.  At 7/64 (.109) W, the bearing ball is going to be quite small and have a very large Hertzian contact stress multiplier.  I have to go back to 1977 to find a 7/64 W bearing listed in a catalog (and I have 2 ft worth of bearing catalogs on my bookshelf).  IF you can accommodate the extra 3/64 (.047) width, I would change to an R-type (deep groove, inch measure) ball bearing.  They run about $3.75-$4.00 ($1.60/L) at booth of my local bearing houses.
« Reply #4 on: May 27, 2011, 11:58:23 AM »
Have a look here Chris.
1/3rd the way down the page....       http://www.technobotsonline.com/bearings/miniature-bearings/miniature-ball-bearings.html
Offline modeldozer
  • Valencia, Spain
    • AJ´s Truckmodeling
« Reply #5 on: May 27, 2011, 03:53:17 PM »
Have a look here http://www.vxb.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=bearings&Category_Code=1-8inch.
Lots of 10 at reasonable price. Have ordered from them in the past and the shipping to Spain was low.
Abraham
Offline HS93
« Reply #6 on: May 27, 2011, 04:11:21 PM »
Abraham
You must be rich, the price of them. you should try  http://stores.ebay.co.uk/Dinball/Bearings-parts-/_i.html?_fsub=7867823&_sc=1&_sid=42095710&_sop=1&_trksid=p4634.c0.m322 if you want them in 10s they have thenm to the uk in under 5 days
But I  would use tecknobots if i wanted them in a hury they tend to do next day and are also cheap and great to deal with they have some handy adio equipment like MP3 player boards.
Peter
« Reply #7 on: May 27, 2011, 06:07:58 PM »
HI dont no if this helps but ther is a bering manufacher  named nsc berings not far from wher i live googel ther name and see wat pops up   regards bob
Offline modeldozer
  • Valencia, Spain
« Reply #8 on: May 27, 2011, 06:51:09 PM »
Top row right hand ref. R2ZZ pack of ten $14.95 = $1.50 each.
Offline picclock
« Reply #9 on: May 28, 2011, 02:07:53 AM »
Only two in the UK that I know of
http://www.technobotsonline.com/miniature-model-bearing-r2zz-1-8-x-3-8-x-5-32.html
http://www.modelfixings.co.uk/Heli%20cylindrical.htm
The second suppliers parts tend to be of higher quality but is you need 1/8th you are paying for it.
Hope this helps
picclock
« Reply #10 on: June 04, 2011, 12:31:47 PM »
Hi, I just wanted to say thanks for all your replies to this thread. I posted it last week before I went away on holiday and although I read through your replies while I was away, it was too difficult typing on the internet connection I had! So thanks for all the links, they were just what I needed and thanks to Clive I now own the 5 that I need along with another 7 for the "bearings" drawer :D   :mmr: :mmr:
Cheers Clive!   and thanks to everyone for your suggestions.
All the best
