Author Topic: hello from Norway!  (Read 8747 times)
Offline Henning
  • Country: no
  • All the kit and no clue!
hello from Norway!
« on: May 18, 2011, 12:51:58 PM »
Having lurked here a bit i can already say  :mmr:
Having recently had a rather bad accident involving woodworkin machinery, my right hand was beeing rather useless. Not to be defeated i decided to get my small Sieg C3 lathe up and running until i could do some woodwork again. Seems i've managed to catch a bad case of  :proj: already, as i have now built a (crude!) tailstock camlock mod and ordered a LOT of stuff to enable me to use the lathe more and get the most out of it. Beeing cramped for space i don't have a mill yet, but i can do rough milling on the lathe, so i wont let that stop me  :zap:
Seems to be my kind of place this  :beer:
Henning
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
Re: hello from Norway!
« Reply #1 on: May 18, 2011, 01:40:08 PM »
A big hello and welcome to the group :wave: :wave:
Tim
« Reply #2 on: May 18, 2011, 02:30:20 PM »
Hi and welcome to us  :wave:
« Reply #3 on: May 18, 2011, 02:36:04 PM »
Hi there Henning!  :wave:
What are your interests? Do you plan on building anything?
« Reply #4 on: May 18, 2011, 03:34:20 PM »
Henning,
Don't let having a disability put you off, there are a lot of lads on here that are a lot worse than yourself, and they have carved themselves a niche to fit into, turning out superb work in their own rights.
It is just a matter of adapting your machinery so that you can operate it safely and most probably a little more slowly, but once you have cracked it, there are no limits to what you can achieve.
Offline j45on
« Reply #5 on: May 18, 2011, 04:28:42 PM »
Welcome Henning  :beer:
Jason
Offline Henning
  • Country: no
« Reply #6 on: May 19, 2011, 03:51:55 AM »
Thanks for all the warm welcomes!  :nrocks:
Henning,
Beeing (relatively ::)) young i grow back nicely, so i will probably gain almost full use of my hand again. Index finger will probably give me some troubles, but all my fingers are there so i am very (VERY) lucky. So no big deal in the end.
Finished my tailstock camlock mod yesterday, a little fine tuning and it's on to the various adjustments necessary after i've had everything in pieces!
Here's a couple of pic's of my tailstok camlock:
Lathe is a Sieg C3 whcih came with DRO standard. Paintjob is "courtesy" of Norwegian importer. I recently sold a C2 from same importer but older model and that had angular roller bearings, so today i will investigate what's inside here and if i need to change bearings in the headstock.
 Thanks again for the welcome!
Henning
« Reply #7 on: May 19, 2011, 04:27:29 AM »
Warm wellcome :beer:
I'm really a greenhorn here, but I allready feel home here: I started something (taper turning) and then I noticed I need more tools (like steady rest) that will require me to make T-nuts for the rotary table and learn how to mill inverted V and some other things I even don't have a name.
Get your daily  :dremel: here!
Offline Henning
  • Country: no
« Reply #8 on: May 21, 2011, 02:44:52 PM »
Thanks Pekka!
Seems to be every nordic country represented here  :beer:
As to interests, my main interest is having a lathe and mill for the odd jobs that pop up, but i will probably try and build an engine soon.
Then we'll see...
Henning
Offline Trion
« Reply #9 on: May 21, 2011, 03:11:41 PM »
Velkommen Henning! Where are you from?
Keep the pictures of your work coming. Good to hear your hand is recovering :)
« Reply #10 on: May 21, 2011, 03:15:22 PM »
Hi Henning, looking good. From where did you by the cast to your'e tailstock camlock ? :dremel:
Offline Henning
  • Country: no
« Reply #11 on: May 22, 2011, 08:02:34 AM »
Hey! Nice to see a fellow Norwegian!
20 min's south of Oslo! you?
Henning
Offline Henning
  • Country: no
« Reply #12 on: May 22, 2011, 08:06:42 AM »
Didn't buy anything. Used pieces i had laying around, drilled a hole in the original tailstock and just cobled the bits and pieces togheter.
I used this page as main inspiration: http://gadgetbuilder.com/CamLock.html and it's one of the various very good pages on the Sieg lathes out there.
Henning
« Reply #13 on: May 30, 2011, 05:33:28 PM »
Welcome to mad modders
