Author Topic: Trials and tribulations with a 7x12 lathe  (Read 77992 times)
Offline cfellows
Re: Trials and tribulations with a 7x12 lathe
« Reply #50 on: June 17, 2011, 11:19:55 PM »
So, exactly how are you adjusting the headstock to take out the two tapers?
Thx...
Chuck
Offline modeldozer
  • Valencia, Spain
    • AJ´s Truckmodeling
« Reply #51 on: June 18, 2011, 04:05:41 AM »
Hi Chuck,
So far only busy with the vertical, and this one is lower at the tailstock end, am shimming under the lefthand of the headstock (front and rear). Am using aluminium foil as shims.  The procedure for testing is known as "Rollies dads method" and is on the toolandmods site.
Abraham
Offline cfellows
« Reply #52 on: June 18, 2011, 12:43:32 PM »
Hi Chuck,
Abraham
Thanks, Abraham.  I'm familiar with the "Rollies Dad's method", but just wonderered if you shimming or scraping.  I think my lath also has some slight headstock alignment issues.  Hasn't been a problem so far because I do mostly pretty shallow work with it.  But I may have to make adjustments at some point.
Chuck
Offline modeldozer
  • Valencia, Spain
« Reply #53 on: June 20, 2011, 08:28:39 AM »
Hi all,
Been at aligning the headstock for three days now, aaand just as me thought me had it nicked ... decided to verify it at varios locations along the travel.   The bed is bent badly in the horizontal   :(  From the chuck the first 80mm is good and then in the next 80mm it tapers back 0.1mm.
Two options I can think of now:
Buy an new bed of unkown "straightnes"
or have this one reground, for this i will need to locate a machine shop with the right equipent/experties and most probably expencive. GRRRRRRR. :bang: :bang: :bang:
As a side note, have located a major sorce of non rigidity in the bed, the part where the headsock bolts on is only supported at the front and left side and it litarly bends by just resting a hand on the headstock.  Found this by chance while checking the alignment, Di was moving as I was moving my hand so I investigated a bit and with the DI between the top of the rear foot and the underside of the headstock, with only light pressure on top it deflects 0.02mm.  Will need some invetigation for a cure.
Sad  :( and frutrated  :bang:
Abraham
Offline loply
« Reply #54 on: June 20, 2011, 09:24:13 AM »
Hi Abe,
So are you saying the V in the bed is not straight, causing the saddle to move away/towards the spindle axis at different points?
Could you identify the areas where the bend occurs and simply scrape them flat? If the 'V' is machined with a 'bulge' on one side this would work, else you would end up with a V which is thinner in spots than others, but it may still be fine, you would just loose contact on one side of the V for the duration of that spot - not ideal, but better than a 0.1mm bend!
Alternatively you could scrape the entire V to a thinner shape and remove the bend, but you would end up having to re-fit the saddle quite a lot?
Rich
Offline modeldozer
  • Valencia, Spain
« Reply #55 on: June 20, 2011, 10:47:16 AM »
Hi Rich,
The V seems to be bent.  Verticaly I have got it perfect (0.00mm on my DI)  Unfortunatly it is to much for scraping, mind you might even be to much for a regrind, like you mentioned it will end up narrower, unless a lot is tacken of the flat surface as well .  Looking into a way of staightening it at the moment  :scratch:
Abraham
PS. Just looked, new bed 142€ shipping included  :scratch:
Offline billmac
« Reply #56 on: June 20, 2011, 10:51:08 AM »
Abraham -
It is possible that the method you are using to measure headstock alignment is misleading you - for several reasons.
If you use a dial indicator with a standard ball foot to measure vertical alignment as you show in your photograph, you will only get a true reading if you have no (zero) misalignment in the horizontal direction. The reason is that any slight horizontal movement will call the ball to run down the side of the round bar. To avoid this you should get an 'elephants foot' for your indicator. This has a flat base and can tolerate a small amount of movement at 90 degrees and still give a true reading. The same argument applies to horizontal measurement.
The second issue you will have is that you must get a degree of droop in a test bar, just under its own weight. You can calculate this to subtract it from your apparent reading. This may be too small to worry about compared to your other problems. Droop is not an issue when measuring horizontally, provided that you use a flat bottomed foot for your indicator.
The third potential issue is with your test bar itself. It has to be very straight for the tests that you are doing. Ideally a ground bar is needed. you can check this within reasonable limits with a surface plate and vee blocks.
Fourthly, a test that just runs along the top of a test bar assumes that the bar is held straight by the chuck. Ideally I would do away with the chuck and use a test bar fitting in your spindle taper. These are available at a reasonable price. In either case you need to take readings with the bar rotated through 90 degree intervals, to find and eliminate the effect of the chuck and taper not being straight and concentric with the axis of the spindle.
Last, the test can be compromised by the TIR of your spindle bearings. You can remove this effect to some extent, but it could be significant enough to cause apparent problems over the distance that you are clocking your bar.
Can't do much about the flexibility of your lathe bed though :scratch:
Offline modeldozer
  • Valencia, Spain
« Reply #57 on: June 20, 2011, 11:07:17 AM »
Hi billmac,
Thanks for the info.  To compensate for chuck runout, bar straightness I am using the methot known as "Rollies dads method", with this am basically determining the centre axis of a cam at each point along the bar and comparing these.
Neet to find one of those "elephats feet "
Abraham
Offline modeldozer
  • Valencia, Spain
« Reply #58 on: June 24, 2011, 07:05:10 PM »
Hi all,
Lathe went in to a major machine shop today.  They will have a look at what can be done an quote on the job. So holding all thubs and praying am hoping for good news.
Abraham
Offline modeldozer
  • Valencia, Spain
« Reply #59 on: June 27, 2011, 04:43:15 PM »
Hi all,
Ended up going to quite a few machine shops, non could do the job. Finaly found a machine tool vendor repair shop that is willing to do it for 250.00€. Decitions decitions? :scratch:
Saw some beautifull machines while there :drool: :drool: alas all to big for my tiny shed.
10x36 chinese lathe like quite a few modders have aroud 5000€, smallest with power cross feed, can´t remeber the size, 3600€ and my favorite 250x500mm 1400e :drool: :drool:
Abraham
