Author Topic: Sieg X3 Table X-Axis End Plate Dimensions  (Read 8678 times)
Offline No1_sonuk
« on: May 09, 2011, 10:33:08 AM »
Does anyone have a dimensioned drawing of the Sieg X3 X-axis left-hand end plate?
Particularly the points related to the factory power feed.
I'm planning on building a power feed (with a stepper) for my shiny new mill, and would rather not spend the time working it out if someone else already has.
Thanks.
lordedmond
Re: Sieg X3 Table X-Axis End Plate Dimensions
« Reply #1 on: May 09, 2011, 10:40:28 AM »
where are you I have a spare one under the bench. email if you wish
I mean the actual power feed plate not the end plate
Although if its a new mill the holes should be there they locate on the centre hole and the two tapped holes
Stuart
« Last Edit: May 09, 2011, 10:49:32 AM by lordedmond »
Offline No1_sonuk
« Reply #2 on: May 09, 2011, 10:50:57 AM »
PMed.
Would still be good if someone could share the info...
lordedmond
« Reply #3 on: May 09, 2011, 11:19:29 AM »
Check your P,M
lordedmond
« Reply #4 on: May 09, 2011, 12:26:40 PM »
in post Tue
Stuart
Offline No1_sonuk
« Reply #5 on: May 09, 2011, 02:58:08 PM »
Thanks
