Author Topic: Oilite or phosphor bronze  (Read 32293 times)
« on: May 05, 2011, 07:02:27 AM »
I seek the opinion of the collective...I should know the answer to this but I've forgotten...
I have a worn oilite bush that I need to replace..Can I use phossie bronze instead and which grade should I use?
Re: Oilite or phosphor bronze
« Reply #1 on: May 05, 2011, 08:21:22 AM »
Thanks for the reply,
Ok, a bit more info..
The bush fits inot an alloy housing, a shaft passes thru driving a magneto on a stationary engine that I'm rebuilding.
The lube system is by splash feed with a scoop on the bottom of the big end cap..So it looks like the oilite bush is to some degree self lubing...
I've looked at buying a new bush but the size I require isnt available.. :doh:
« Reply #2 on: May 05, 2011, 08:29:15 AM »
You can machine oilite with a sharp tool.
try sourcing a bush with larger OD , smaller ID and machine to size. It's also available in solid stick form but not usually cheap.
Out of interest what size are you looking for ?
John S.
« Reply #3 on: May 05, 2011, 09:20:30 AM »
The bush I need has the following attributes:
i/d  =  0.75 in
o/d = 1.00  in
top hat diameter is 1.125 in and is 0.125 in thick.
overall length is 0.75 in
I had given some thought to buying a larger bush as a last resort, if I'm going to be machining, I'd rather do it from scratch...If I cock up machining a bought bush, I'm no better off, if I machine from bar stock, then at least I get more than one chance....Bought bushes aint cheap... :(
« Reply #4 on: May 05, 2011, 09:36:59 AM »
That's a stock bush, let me check suppliers
« Reply #5 on: May 05, 2011, 09:40:27 AM »
What a diamond geezer......... :bow:
Offline 75Plus
« Reply #6 on: May 05, 2011, 09:51:05 AM »
That bush is available on this side for about 1 £ +/- a few pence. If you don't find one let me know and I will send you one.
Joe
« Reply #7 on: May 05, 2011, 10:27:32 AM »
Joe
Joe,
That would be the case wouldnt it......... :D
Since we went all metric it has caused all manner of problems and as such suppliers do not tend to keep legacy stuff.
I may have to take you up on your offer of help.. :thumbup:
« Reply #8 on: May 05, 2011, 10:49:02 AM »
OK got one ordered with a stack of other bearings.
it's ex-stock on the shelf, should deliver to me tomorrow.
Are you going to Harrogate ? Oh it's 1" long BTW but eacy to cut down.
« Reply #9 on: May 05, 2011, 11:45:36 AM »
Yes I'll be at Harrogate, I'll come and do some barracking... :D
How much are you owed for the bush please? Do you want paying now (Paypal or other preffered method) or at Harrogate?
I am in your debt.
« Reply #10 on: May 05, 2011, 12:42:43 PM »
Not got a clue how much, I'll have to ask because I won't get a bill until next month.
Harrogate is fine, be on the CNC's on the ARC stand, hall 2.
« Reply #11 on: May 05, 2011, 01:12:01 PM »
Oh my goodness....sounds like I'll need to take out a mortgage.. :lol:
I'm sure to find you, I'll be there on the Saturday along with some of the other guys on here..
Once again many thanks for your help.
« Reply #12 on: May 05, 2011, 02:08:01 PM »
Well, Mr John Stevenson that was very nice of you :clap: :clap: :clap:
« Reply #13 on: May 05, 2011, 05:06:31 PM »
No but I will, I also ordered 104 angular contact bearings, 100 mm bore.  :doh:
John S.
Offline fluxcored
« Reply #14 on: May 06, 2011, 03:42:30 AM »
Oillite bushings are engineered materials designed for specific life and service factors.  Phosphor bronze tends to run extremely dry and can grab without lubrication.  What you'll need to assess is in this application, is there a way to get lubrication into the joint, will that lubrication maintain itself in the joint over the service life of the machine.  If the lubrication is likely to wear itself away, what are the chances that someone will remember to re-lube it.  Oil impregnated bushings of all shapes and sizes (and brand names) are available for pocket change around here, I'm betting they are available on your side of the pond for want of a little digging.
Very informative. I was just on the verge of buying some phosphor bronze to turn some bushes because oillite is'nt stocked by my supplier and has to be specially ordered.
"Living is a dangerous occupation. Just look at all the dead people out there." - Thomas Lipton
Offline snub
  • Canada
« Reply #15 on: May 07, 2011, 09:54:41 PM »
Speaking of bushings and bearings, I found a few sites in the U.S.A. that have a huge selection and easy to order from websites.
#1 SDP/SI....lots of other neat stuff too.     http://www.sdp-si.com/eStore/CoverPg/bearings.htm
#2 Reid Supply ....lots of oilite bushings.     http://www.reidsupply.com/Results.aspx?pid=10021775
#3 VXB Bearing...lots and lots of "miniature" bearings.    http://vxb.com/
Enjoy!
« Reply #16 on: June 02, 2011, 06:53:18 AM »
HI just a heds up phosphor bronze well the stuff we yoused is pores wehen we had made the bushes we put them in ger oil  ie hp 90 over night to per lubricat it
