Author Topic: power hacksaw  (Read 11238 times)
Offline colin563
power hacksaw
« on: May 01, 2011, 04:20:14 PM »
ive just got a used power hacksaw sieg g1 axminster same as the arc euro version :)
were is the best place to get the blades from
also are any makes or types better than others :scratch:
thanks colin
« Last Edit: May 01, 2011, 04:34:58 PM by colin563 »
Re: power hacksaw
« Reply #1 on: May 01, 2011, 04:55:35 PM »
Colin,
I have the same hacksaw, and changed the blade last year after well over a years hard use. I put a new one in, but really I should have just swapped it around end to end as only one half of the blade is used. I don't think it makes any difference on this model which way the power stroke is, it seems to cut in both directions if the blade is just swapped around. I have kept the old blade for more hard up times, rather than making the usual knife blade from it.
I bought my spare blades from Axminster and they are Bahco, which seem a very good brand, but maybe they now supply a different brand. I don't suppose they wouldn't be much different from anywhere else, the chinese one supplied with it lasted a great deal longer than I thought it would. These saws seem to be very gentle on blades.
One thing I did do though, it doesn't look very pretty, but I fitted a sliding extension weight to the handle, which gives me more cutting downforce, and it works a treat.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/hackweight1.jpgpower hacksaw
http://i202.photobucket.com/albums/aa102/bogstandard_photos/hackweight2.jpgpower hacksaw
http://i202.photobucket.com/albums/aa102/bogstandard_photos/hackweight3.jpgpower hacksaw
That is a cast steel base off a 2ft height gauge, so fairly heavy (and useless for anything else), and it now has a small lock on it that keeps the weight fixed where set to.
« Last Edit: May 01, 2011, 04:57:58 PM by Bogstandard »
Offline colin563
Re: power hacksaw
« Reply #2 on: May 01, 2011, 05:18:09 PM »
thanks for the reply
i did see your post yesterday and ive already looking for replacement grease nipples for it
i seen these blades on ebay not sure how good they are
http://cgi.ebay.co.uk/New-Quality-HSS-Power-Hacksaw-Blade-12-x-1-14TPI-/350436413611?pt=UK_Hand_Tools_Equipment&hash=item5197a350ab
thanks colin
Re: power hacksaw
« Reply #3 on: May 01, 2011, 05:36:13 PM »
I think you are on your own about buying blades.
I have never heard of those, but that doesn't mean they are no good, they could be the best blades ever, but without trying them, you never know.
Offline 75Plus
Re: power hacksaw
« Reply #4 on: May 02, 2011, 07:04:06 PM »
Found this about Miranda. Apparently the company, while in India, has American roots. Lenox blades are well regarded on this side of the pond.
http://www.lenoxindia.com/company.php
Joe
Offline colin563
Re: power hacksaw
« Reply #5 on: May 03, 2011, 05:45:24 AM »
I've just placed an or for them also found some
14tpi eclipse blades
Thanks colin
Re: power hacksaw
« Reply #6 on: May 03, 2011, 05:18:42 PM »
HI you can by  blades from  RS   or  cromwell and toolstashon
