Author Topic: Which machine annoys you most?  (Read 69987 times)
Offline Yettiatcpg
Re: Which machine annoys you most?
« Reply #25 on: February 16, 2012, 07:58:23 PM »
I'm to lazy to break anything. most things have a better shot of rusting out first.  :poke:
on a serious note I did have an issue with my 6" x 48" belt sander. it was way to easy to stall. I upgraded my table saw so I took that motor and flipped it into the sander. now its a 3/4hp and does what its supposed to.
Yetti
If all you have is a Hammer, everything is a nail.
Offline HS93
« Reply #26 on: February 16, 2012, 08:14:42 PM »
all the machines in my shop annoy me especially after coming on hear I see what fantastic things are made with the same equipment as me and what CRAP I turn out and I get very annoyed and frustrated,
 I think it may be the electricity around hear, it makes the  machines inaccurate. :) :lol: :)
 :ddb: :nrocks: :ddb: Peter  :ddb:  :nrocks: :ddb:
Offline kwackers
« Reply #27 on: February 17, 2012, 04:51:31 AM »
I hate whatever I've just put down and it's ability to blend into the background such that I have to spend 20 minutes trying to find it again.
(OK - technically not a machine... ;-)
« Reply #28 on: February 17, 2012, 09:32:10 AM »
I think that it is trying to get into the fourth dimension.  :lol: :lol:
Offline cfellows
« Reply #29 on: March 01, 2012, 12:28:07 AM »
I bolted my bandsaw legs down to a wood platform I made, then put casters on the bottom.  I keep stored it up next to the wall in a corner and just roll it out when I need to cut something long.
The one thing that still annoys me about it is that the blade will slip of the wheels periodically when the blade jams in the work during a heavy cut.  It's hell getting the blade out of the kerf without bending it and then having to remount the blade.  I find that if I clean off the wheels and blade periodically it's less of a problem.
The other tool that annoys me is the geared rotary table.  It's heavy and I hate taking the vise off my mill and mounting up the rotary table.  I also hate centering it  and I hate trying to figure out to clamp work onto it.  Seems like it's always a hassle!
Chuck
Offline Davo J
« Reply #30 on: March 01, 2012, 06:00:28 AM »
It sounds like your not putting enough tension on the blade, doing the knob up by hand you cant over tighten it with just hand pressure. I run mine with coolant and don't have any blade slip problems at all.
If that doesn't help to much, try moving the bearing guide assembly up a bit higher, to get the blade running right to the back of the wheels. Also try tilting the top wheel a little more with the adjustment bolt.
« Reply #31 on: March 01, 2012, 06:32:53 AM »
Telephone...................
John S.
« Reply #32 on: March 01, 2012, 08:53:50 AM »
Another week or so and it'll be the lawnmower again.
Actually, it's having to use it that annoys me, rather than the machine itself. That performs perfectly well.
Andy (a reluctant gardener)
« Reply #33 on: March 01, 2012, 09:30:02 AM »
well i wood have to say the wife but she ant a machine
  • Country: za
« Reply #34 on: March 01, 2012, 09:34:54 AM »
Ooow Bob, I'm going to tell her   :lol:  :lol:  :lol:  :lol:
« Reply #35 on: March 01, 2012, 01:19:28 PM »
Yeah, that one gets me too. Once, I got righteously angry over a tool I couldn't find, only to discover it in my hand! Fortunately, that one doesn't happen too often, but I frequently lose things I had "just 1 minute ago". Probably doesn't help that pretty much every horizontal surface I own is piled high with crap important possessions...
« Reply #36 on: March 01, 2012, 04:37:26 PM »
John S.
Excellent  how could i forget that. Me and phones dont mix at best of times yet alone mid job, even worse some one flogging you something day in day out.
Just found a new annoying machine, a chinese band saw.
Baldrocker
« Reply #37 on: March 01, 2012, 05:34:05 PM »
I always thought that was the function of every horizontal surface.
My pet hate is the ones that are not horizontal, you know the
surfaces where everything slides off when they reach critical mass.
br
Offline cfellows
« Reply #38 on: March 02, 2012, 05:14:38 PM »
Another annoying tool... String Trimmers.  I have a Black & Decker, corded 120v string trimmer.  The cord is annoying as he11, but the biggest annoyance is the automatic string feed.  I don't know what bonehead thought of that, but it's horrible.  It doesn't feed when it should, it feeds too much when it does feed, you never know when it's going to feed so it gouges out a big swath of grass or takes big chunks out of the wood fence.   What a mess.
I've been looking for new string trimmer and it seems the manufacturers think we're all idiots or they just don't want to sell them.
Rechargeable with a Lithium battery is my first choice.  Light weight, no cord, easy starting, but I absolutely cannot find one that doesn't have automatic line feed.  Gas would be my second choice since they don't have a cord.  But they are heavy, more than twice the weight of Lithium cordless models.  The only one I found that was relatively light was an Echo.  At about 9 pounds it's still 3 pounds heavier than my Black & Decker.  On top of that, the Echo is a 2 stroke which means I have to mix the oil and gas.  That means I have to have two gasoline containers since my lawn mower is a 4 stroke
In the meantime, I've remedied the automatic line feed by cutting 6" strips of line, knotting one end and slipping through the holes in the side of the spool with the knot inside.  I can do my whole yard and only change out the strips 3 or 4 times.  I figure if I get .105 line I can do the whole yard on one set.
Chuck
« Reply #39 on: March 02, 2012, 06:02:16 PM »
Chuck. I have a length of bowden cable in mine I got that fed up of the nylon string.
Solder the end 2" and leave the rest, one bit lasts about 6 months.
John S.
Offline AndyB
« Reply #40 on: March 03, 2012, 06:31:03 AM »
Hi all,
I am with most of you all the way.
Andy: yep! I have got two pairs of those shears and lots of blood blisters on my belly when I have to cut any sheet!  :(
Kwackers; I seem to be beset by workshop gremlins that love to hide whatever I have just used and put down. I swear it is true; I once put a tool down while in the middle of a job, couldn't find it again. It turned up in my wife's shed and I had not been in there and she had not been in mine! Explain that if you can!!! :scratch:
Ade; In your hand? Are you that gremlin? :lol: :lol: :lol:
Bob; Sorry, I don't agree. When the wife breaks something and I can fix it she is so amazed and grateful that she is glad of the time that I spend in the shed and on here learning new tricks. Instant justification for the hobby! :lol: :lol:
Peter; I can sympathise with your predicament. I keep looking at and trying to justify the cost of some machine, a milling machine mostly, then see what someone has made on the machines that I have got already! What keeps me sane is a little booklet produced by Drummond in the 20's that has, amongst others, a radial engine totally made on a treadle Roundbed lathe :jaw: :bugeye:
Ade; Why is it that every attempt to 'tidy up' means that those flat surfaces get filled more than they were before? :doh: :doh:
I think this thread should be renamed Duracell; I could go on..and on...and on   :lol: :lol: :lol: :lol: :lol: :lol:
  • Country: za
« Reply #41 on: March 03, 2012, 06:35:24 AM »
John S.
That's a good idea. :thumbup: :clap:
Offline AussieJimG
« Reply #42 on: March 03, 2012, 09:58:08 PM »
Soft jaws in the vice. They fall in whenever I am trying to put something in the vice, especially if it is something that has to be held with both hands.
I did buy a set of plastic magnetic ones but they were about as useful as a hip pocket in a singlet - too soft to grip properly.
Then adhesive-backed magnetic rubber on the aluminium ones - again too soft and broke up.
While typing this, I have to wonder why I have hard jaws on the vice at all since I never use them. Perhaps the answer is just to
take off the hard jaws and fit aluminium ones.
Jim
Offline cfellows
« Reply #43 on: March 04, 2012, 12:32:29 PM »
John S.
That is a good idea.
Chuck
« Reply #44 on: March 04, 2012, 01:10:19 PM »
That's what I did with my Kurt-a-like "Titelock" vice. I also made mine extra tall, so I could cut fixed "parallels" into the jaws. So far, they're doing great.
I also put Ali jaws in my bench vice, they too seem to work well, although it's too early to say yet as I've not had to use them in anger.
« Reply #45 on: March 04, 2012, 01:38:44 PM »
Jim,
I have hard jaws in mine but ground the grips off. Positively hate loose jaws, refuse to use them, lick the normal jaws to remove the grips then every so often give them a clean up lick.
Nothing I do required great big grip marks splatted all over the work.
John S.
Offline AussieJimG
« Reply #46 on: April 06, 2012, 01:24:56 AM »
In reply 42, I said I had realised that I could replace the hard jaws in my vice with soft jaws. Eventually, I did it! And the work a treat.
Of course, the next day I wanted more grip and had to put the old one back temporarily, but that's just Murphy getting revenge.
Now, I wonder if I can include  photo ...
Offline ConductorX
    • The Volkswright Shop
« Reply #47 on: January 18, 2013, 07:35:18 AM »
I have to vote with the string trimmers.  I hate tiny gas engines that take 100 pulls to start and then lugging the thing around trimming the weeds.
I also have the same issue with chain saws because the tiny engines won't start.
Only one brand of trimmer actually has an easy to start every time engine. They don't sell them any more because now all such engines have to be 4 cycle.
"G"
« Reply #48 on: January 18, 2013, 07:43:58 AM »
I think I have to say my Eagle 30 mill...
Having to raise/lower the head to accomodate differing cutters...It always loses its reference point... :doh:
Other than that I love it to bits for making swarf... :D
Offline Fredbare
  • Fakenham, Norfolk
« Reply #49 on: January 18, 2013, 10:59:20 AM »
This forum, I've just bought a tool for £60, and then read that someone's just bought the same tool for 25p at a boot sale.
