Author Topic: Hit n Miss Engine ,,,,to MR D Kerzel's design  (Read 183402 times)
Boz
Re: Hit n Miss Engine ,,,,to MR D Kerzel's design
« Reply #75 on: May 06, 2011, 03:17:40 AM »
As ever, some interesting techniques for me to learn from, as well as a lovely build :bow:
Boz
« Reply #76 on: May 06, 2011, 08:59:33 AM »
That is a really nice way of keeping the pressure from bending the crank using that spacer.
Just wondering, I noticed you drilled right through the two bearing supports in position. When I built my Stuart I was encouraged not to do this because they may deflect off centre as the drill went through. I guess because you were boring you could take a very light final cuts and run it in and out so that you knew you wouldn`t get this deflection - is that right?
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #77 on: May 06, 2011, 05:35:16 PM »
"Several hours later".....   : )  That's a funny bit about the saw, Rob.
Things are looking great, and you're showing some solid machining practice.  Enjoying your thread here, mate!
Dean W.
Shop Projects:
« Reply #78 on: May 07, 2011, 04:38:39 PM »
Cheers lads  :D :thumbup:
what are u doing with the gear shaft rob?
are u using custom gear sizes?
Hi Pete ,,,,,,,,,,,,,,,,,,,,,, Nothing as exciting ,, just fixing the shaft a slightly different way  :)
Hi Chris ,,,,,,,,,,,,,,, you got it ,i took it easy drilling ,, leaving plenty of material to bore to final size  :dremel:
Well i just about finished the crank ,, still needs some de burring , a couple of key ways milled and cut to length  :dremel:
Milled off the excess material ,,, to lazy to use a hacksaw  ::)
Mounted between centres and ruff turned
Then finish turned to size
Cheers Rob
« Reply #79 on: May 07, 2011, 04:42:10 PM »
Still a master pice Rob. :clap: :clap:
Offline arnoldb
  • Windhoek, Namibia
« Reply #80 on: May 07, 2011, 04:53:52 PM »
Beautiful crank mate  :bow: :bow:
And it's good to see you giving the Myford a bit of a workout for a change  :D - I see the TTA is mounted conveniently as a magnetic base stand  :lol: :lol: :lol:
Kind regards, Arnold
« Reply #81 on: May 07, 2011, 05:03:23 PM »
that is a great finish you have there Rob :bow: :bow: :bow:
I bet you did not use emery tape to achive it ether
Offline cfellows
« Reply #82 on: May 07, 2011, 05:09:38 PM »
Very nice work on that crankshaft.  I've made a few and they are not easy.  Don't think any of mine turned out quite as nice as yours!
Chuck
Offline metalmad
« Reply #83 on: May 07, 2011, 06:39:26 PM »
Hi Rob
That crank is so nice buddy, Im glad u left it a little long on the reg side because, I found an easy fix for the lockout lever's
interference issues was to make a wider bobbin.
That just moves everything out of the way  :thumbup: :clap:
your kerzel is going to be a rare thing of beauty Rob
(Kerzel Club member)
« Last Edit: May 08, 2011, 04:24:54 AM by metalmad »
A little bit every day, sometimes the same little bit!
« Reply #84 on: May 08, 2011, 02:11:04 AM »
Crackin' work Rob!  :clap: :thumbup:
« Reply #85 on: May 08, 2011, 08:45:33 AM »
Hi Rob,
A masterfull piece of work :thumbup:
very nice :clap:
« Reply #86 on: May 08, 2011, 12:24:11 PM »
Hi Rob, that is truly a master's bit of work on that crank, and I am going to be following your demonstration of the proper way to set up to turn the shafts on my next crank.  I've got three pieces of 1 and 3/4 round stock each with three reamed holes in them, which have been getting progressively thinner as each time they go together with pins and shafts, they get further out of true. :hammer: :headbang:  It is time for them to be scrap, and a proper crank assembled, and you have shown the way.  I've seen many variations on the method, but your description of finding the exact diameter of the piece holding it in alignment is the best way I've ever seen and I will be using it in my next build. :bow:  This engine should be a real runner when you're finished.   :beer:  Cheers, Jack
« Reply #87 on: May 08, 2011, 12:27:11 PM »
I have just had a propper look & feel of that crank  :D :D :D :D
The pictures dont do it justice :bow: :bow: :bow: :bow:
Offline klank
  • Sunny East Devon
« Reply #88 on: May 08, 2011, 01:38:51 PM »
Hi Rob,
Thanks for everything you have shown here.
The pictures are so clear and instructive - truly a "master class" in techniques - much to learn from.
Very best wishes
Peter
Offline CallMeAl
« Reply #89 on: May 08, 2011, 04:46:48 PM »
Wow Rob - wonderful work, I have had another lesson given by the master! :clap:
I skin cats my own way!
dkyfn
« Reply #90 on: May 19, 2011, 01:37:12 AM »
Rob, I'm  going through withdrawls...   :poke:  I feel like a junkie that needs his "Rob fix"...  <tee hee>  I hope all is well with you   :wave:
Sorry I'll edit it this, this is Kenneth from my machine upstairs...
« Reply #91 on: May 29, 2011, 11:54:43 AM »
Hi Lads , many thanks for the comments  :thumbup:
The shop time has been a bit slow passed two weeks  :(  ,,,,,, but i have managed a bit this weekend  :ddb: :ddb: :ddb: not allot but still moving on .
Made the main bearings .
Slapped a bit 1mm stainless plate on the Denford  cnc mill and out popped a couple of name plates ,,,,,,, well i did have to make an engraving  cutter , draw it and then sort out the G code ,,,,,,,, and wait 58 minutes for it to go through 12503 lines of code   :coffee:
And cheers to MR Bluechip for the dam small 10 BA screws  :beer:
May have a bash at the flywheels the morn  :dremel:
« Reply #92 on: May 29, 2011, 12:04:00 PM »
K - E - R- Z - E - L. ?
Funny name for a frog ?   :scratch:
« Reply #93 on: May 29, 2011, 12:11:26 PM »
:lol: :lol: :lol: :lol: :lol: funny   :coffee:
you not answer your PMs now  :poke:
Offline Jasonb
« Reply #94 on: May 29, 2011, 12:24:44 PM »
And theres me been waiting 2 weeks to see how the spark plug turns out ::)
Good to see some more progress
J
« Reply #95 on: May 29, 2011, 04:10:00 PM »
I thought you would have lined the slots up on the 10 ba screws :lol: :lol: :lol: :lol: :lol:
Joking apart thios is total class  :bow: :bow: :bow: :bow:
« Reply #96 on: May 29, 2011, 05:20:19 PM »
Quite right John, really attractive engine ..  :thumbup:
Wonder how long before he notices you've nicked the piston and con-rod for yours ???
Dave BC
Offline metalmad
« Reply #97 on: May 29, 2011, 06:31:27 PM »
WOW
that name plate is an inspiration  :drool:
I am sooooo wanting to be able to do that  :drool: :drool: :drool:
Pete :wave:
« Reply #98 on: May 30, 2011, 02:18:54 AM »
That name plate lookss smashing Rob, did you make two one for each side ?.
Offline Jasonb
« Reply #99 on: May 30, 2011, 02:56:04 AM »
Name plate does look good BUT I've never seen a hit & miss with a name plate like that, usually transfers on the side of the hopper and a small plate elsewhere giving details like HP and serial mumber and also held with roundheads
I have some spare 12BA roundheads and some JB weld to fill the old holes if you want :D
Jason
