Author Topic: Pamper your tools in a cosy drawer space!  (Read 445406 times)
Re: Pamper your tools in a cosy drawer space!
« Reply #25 on: August 30, 2011, 10:36:31 PM »
Hey John! You are now Famous!
Linky to Makezine
and OFC, you know about this one!
MachinistBlog
Congrats my friend!
tumutbound
« Reply #26 on: August 30, 2011, 11:21:14 PM »
Geoff, I hope the move goes well for you.
The move went very well and, thanks to you, the trip was a lot quieter than it could have been.
I got hold of some plastic bags, similar to the ones supplied in supermarkets but a bit thicker. I placed these over the contents of the tool box drawers, covered them with a sheet of MDF and blew the foam into them. It wasn't that neat as it only meant to last for the trip which it did.
Biggest problem I had was getting rid of the bags/foam - there's no garbage collection at all where I'm currently staying. :scratch:
« Reply #27 on: August 31, 2011, 05:25:19 AM »
Glad the move went well for you Geoff.
Thanks Eric, I hope it goes well for everyone who tries it!
Offline FredEx
« Reply #28 on: August 31, 2011, 03:37:54 PM »
Great idea.  :clap:
I had a weaved material that the foam could bleed through. I put the material down over the tools, used a light spray of contact glue, stuck tissue paper to that and then did the foam. That tissue paper layer was enough so there was no leaking through the weaved material. Without that spray glue I was afraid the material would pull away.
« Reply #29 on: August 31, 2011, 11:21:12 PM »
Great idea.  :clap:
Next time just dampen the material a little and test that, you will probably find the water in the fabric reacts with the foam and immediatley blocks the weave, by the way, if you push and pump really hard you can force the foam through the t-shirt fabric too.
Offline keyteem
« Reply #30 on: September 10, 2011, 02:43:13 PM »
Just coming on board for the first time and seeing this I HAD TO REPLY!!!!!!
that is an AWESOME idea, you the man. I just purchased a set of threading masters and followers
for a lathe and after spending days getting them all spiffed up shinny and clean
was wondering how to keep them safe and sound!
When I am done I will post a pic.
It amazes me what some of you supergenius's come up with! why didn't I thinkathat :doh:
Den
Offline flutedchamber
« Reply #31 on: September 11, 2011, 02:06:50 AM »
That's a great idea you have there.  One question tho.  There are certain foams that lead to rusting because they produce something along the lines of an acid (acetic acid IIRC) which causes a flash rust on steel.  The better grade steel..the more rust.
« Reply #32 on: September 11, 2011, 05:18:49 AM »
Yes, check the foam chemistry if that is a concern for you.
Offline fatal-exception
« Reply #33 on: September 16, 2011, 03:31:19 PM »
Pure genius! Hats off to you!  :clap:
« Reply #34 on: April 01, 2013, 12:42:31 AM »
Oooops......  deleted by me.........wrong forum! :doh:
« Last Edit: April 01, 2013, 03:09:53 PM by John Hill »
Offline AllenR13
« Reply #35 on: June 13, 2013, 08:22:14 PM »
Thank you for posting this!!!    :headbang:
It's something I will be doing in the near future
« Reply #36 on: September 05, 2013, 03:40:16 PM »
 :update:
I bet that never in your wildest dreams did you think that when you started this thread it would be the most read thread on MadModder. Currently there are over 52,000 view's and it is still climbing.  :D :D
To All       :proj:
It goes to show that something that every one 99% of our members is capable of making can be the most widely read thread.
To all the members, new, old, lurkers and others I am sure that you have some simple or complicated ideas that you could start a thread with and share with the rest of us. I look forward to what you can come up with.  :) :)
« Reply #37 on: October 11, 2013, 03:03:49 PM »
Most read thread on MM?  Well well, what an achievement. :coffee:
Hmmmm..... have we seen many pics of any who have tried the idea? :lol:
« Reply #38 on: October 11, 2013, 03:29:47 PM »
Hi John
I don't recall seeing many pictures of other people's results but the number of views just keeps climbing. Hopefully if anybody new reads this and tries it out they will post some photos of how it worked for them.
How's retirement going for you John? Are you ready to go back to work so you can get a rest or have you got it all under control?  All the best John.  :D :D
« Reply #39 on: October 12, 2013, 01:52:59 AM »
Hi Don
Things are going well here although I dont get as much time in my 'shop as I would like spending just too many hours at the local aviation museum! :Doh:
Of course I do get to do a lot of machine jobs making bits to replace missing parts for some of the exhibits, axles and widgets, that sort of thing.
« Reply #40 on: October 29, 2013, 12:48:35 PM »
                   I got ma box,  got ma tools,  just need ma foam, an am ready to go.
« Reply #41 on: October 29, 2013, 01:06:40 PM »
David
When you get your foam and are ready, set, go....grab the camera and take a few shots to add a few photos's to this thread and keep it going. Like they say, a picture is like a thousand words.   :D :D
Offline Eugene
« Reply #42 on: October 30, 2013, 10:37:47 AM »
A great idea shortly to be incorporated into my shop build; thank you.
That expanding foam is really useful stuff. I've used it quite a bit in refurbishing our cottage where a gap filling and adhesive material is a Godsend (not an upright wall or right angle in the joint  :() and also for repairing and stabilising wonky wooden flooring in a disabled friends house. The pressure of it's expansion is surprising; if you put a piece of timber against an uneven brick wall and apply the foam, unless you carefully wedge things in place the expansion will simply push the timber way out of position. So you really will have to weight it down well in your tool drawer.
The one tip I can offer from experience is to strongly recommend that you wear latex gloves and your tattiest old working clobber; it's an absolute b****** to get off skin and you won't remove it from clothing at all.
Eug
Offline ctim2008
« Reply #43 on: November 08, 2013, 05:01:52 PM »
Tried this idea for two of my tool drawers at work. My first try completely failed and was unusable. I'm not sure if I just didn't use enough foam, it didn't expand at all, or a combination of the two. Regardless I wouldn't recommend using the "Great Stuff: Window and Door" foam as it stays flexible once cured and barely expanded at all. After that failure I went back and got the "Great Stuff: Big Gap Filler" and am currently waiting for it to finish curing. It seems okay so far and I'll be sure to post pictures tomorrow when it's done.
Thanks for the idea!!
« Reply #44 on: November 09, 2013, 02:32:11 AM »
Hi, I hope that new foam does the trick for you.  I only tried one and had a good result the first try but I did have to mess around a bit getting enough and not too much foam into all the corners etc.
I am looking forward to seeing your pictures! :wave:
Offline Ooompa
« Reply #45 on: November 10, 2013, 02:02:40 PM »
I am going to unashamedly steal this idea and use it on a display box reconstruction I am currently undertaking. I will however give credit to the OP. I am just not smart enough to dream this up.
Great, great idea.
graham.
« Reply #46 on: November 10, 2013, 06:10:41 PM »
Go for it Graham but please post pictures!
Offline ctim2008
« Reply #47 on: November 11, 2013, 01:20:54 PM »
Okay, so now that take two is done, I think it's time for a take 3. I've never worked with expanding foam before and it's definitely showing. I'm still not happy with the way it came out and am going to do it again. I think I finally figured out what my mistakes were and hopefully this next try will get it done. Here are pics from my second try:
https://db.tt/SpFUqzXr
20lb shop bags on top
https://db.tt/lszC97fB
The 80lbs of weight I probably should have put on there to begin with.
https://db.tt/Q7l7Oq0g
Here's the tools in the drawer. You can see that the sides didn't turn out too well.
https://db.tt/XDJbpJck
close up on the form of the tools, still not as good as I want it to be.
I'll come back and post pictures again once I finally get a product I'm happy with haha!
« Reply #48 on: November 12, 2013, 03:22:33 AM »
Hi, do you think maybe the fabric was stretched too tight before your put the foam on?  When I did mine I just laid the t-shirt fabric over the tools and I was fairly careful to push the foam down and squish it around abit before putting the board over the top.
You got a good deep fit around that crescent wrench.
I made a case liner for some of my astronomy bits and pieces and they didnt fit in too deep either partly because I didnt want to force the foam through the fabric onto those bits.
Offline Bangkok Mick
« Reply #49 on: November 12, 2013, 03:50:38 AM »
Nice one
