Author Topic: Tiny CNC router  (Read 98411 times)
Offline j45on
Tiny CNC router
« on: April 09, 2011, 04:30:41 PM »
I am building a tiny CNC router based on this http://makeyourbot.org/mantis9-1
But I am beefing it up a little with proper ball bearing slides with a view to remaking the frame from aluminium if I can get it all working correctly  :hammer:
This is what I have "thrown" together so far
http://i602.photobucket.com/albums/tt102/ja2onx/minirouter.jpgTiny CNC router
I have now got to the point where I need electronics  :zap: I was originally going to use some salvaged printer stepper motors but I don't think they will be up to the job.
Does anybody see any problem with one of these ? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280655297567&ssPageName=STRK:MEWAX:IT#ht_6455wt_1141
I only want to engrave wood and maybe some aluminium with this either using a dremmel or a custom spindle and brushless motor
« Last Edit: April 10, 2011, 12:51:48 PM by j45on »
Jason
Re: CNC router
« Reply #1 on: April 09, 2011, 04:48:18 PM »
Hi Jason
sorry i cant answer your question  :doh:
Looks a cool project  :dremel:   :thumbup: ,,,,,,,,,, what size is the work table ?
Offline j45on
Re: CNC router
« Reply #2 on: April 09, 2011, 04:58:24 PM »
I'm unsure  :scratch: I will measure it tomorrow I also don't know what the usable table surface area is yet
The whole thing is only 300mm x 300mm square though.
Jason
Re: CNC router
« Reply #3 on: April 09, 2011, 05:31:09 PM »
Jason
would this be any use to you on your build ?
280 x 220 x 25  ally ,,,,,,,,,needs a clean
Re: CNC router
« Reply #4 on: April 09, 2011, 05:46:15 PM »
This looks to be an very intressting project, I will follow this  :thumbup:
Re: CNC router
« Reply #5 on: April 09, 2011, 05:56:33 PM »
Jason, good luck with this. It is something I am massively interested in, infact I started making one a while back:
http://www.raynerd.co.uk/?p=532
However, it was a little bit too big AND the electronics were just working out far too expensive. I purchased a very cheap driver off ebay for £10 and it blew up with imo, no fault of my own I! I then purchased a cheap second hand motor and couldn`t get it to work. Then I went and purchased a motor and driver from ArcEuro and had no issue with them, they worked perfectly but they were for my milling maching x-axis stepper driver controller so for three more, I just couldn`t afford it!! I sold the lead screw and infact, I sold the table as far as I had got with it!!
I`m hoping I`m going to get some help with a build during summer so I`d be really interested to see if those drivers and motors do the business! I have seen them on ebay before and wondered!
Offline j45on
Re: CNC router
« Reply #6 on: April 09, 2011, 06:09:48 PM »
Jason
Might be rob if I get it working  :zap:
I shall keep it in mind  :thumbup:
I went with this one in the end Chris as it also had a power supply http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260754805346&ssPageName=ADME:B:EOIBSA:GB:1123#ht_6225wt_1141
I will let you know if it is any good.
« Last Edit: April 09, 2011, 06:25:47 PM by j45on »
Jason
Offline Imagineering
Re: CNC router
« Reply #7 on: April 09, 2011, 07:04:00 PM »
Hi Jason,
Have a look at http://cnczone.com/
There you will find many answers to the many questions you will have on your quest for CNC.
Murray.
Offline Swarfing
Re: CNC router
« Reply #8 on: April 10, 2011, 03:46:13 AM »
Jason
I use a similar board for my router with the same size motors and it works fines. Setting up the board can be a bit of a pain but with the screw you are using i don't see a problem. My work area is 700 x500. Join this site as is very useful and a dam good bunch of blokes http://www.mycncuk.com.
Once in hole stop digging.
Offline j45on
Re: CNC router
« Reply #9 on: April 10, 2011, 06:46:55 AM »
Cheers for the links guys  :thumbup: there is so much information to take in  :coffee:
Jason
Offline j45on
Re: Tiny CNC router
« Reply #10 on: April 10, 2011, 01:05:39 PM »
I had a bit of time this afternoon so I knocked up a new anti-backlash nut from some Delrin I was not happy with my previous effort.( on the right)
The new one (left) is longer and has three thin slots (very hard no see) in the end which are held shut with an o-ring.
http://i602.photobucket.com/albums/tt102/ja2onx/back1.jpgTiny CNC router
This all runs nice and smoothly now with no noticeable backlash in the screw and nut  :ddb:
But I now need to find some thicker angle or another way to mount the nut as the current piece of angle flexes  :doh:
http://i602.photobucket.com/albums/tt102/ja2onx/rou1.jpgTiny CNC router
Jason
Offline j45on
Re: Tiny CNC router
« Reply #11 on: April 10, 2011, 03:28:14 PM »
Managed a bit more shed time and finished up a clamp thingy  ::)
The lead screw is supported by two bearings at the front which are the same thickness as the wood and are a very tight fit with a flanged screw to prevent movement.
at the rear I have just one bearing.
http://i602.photobucket.com/albums/tt102/ja2onx/bb2.jpgTiny CNC router
To stop the lead screw from moving I just have a spacer between the oldham coupling at the front which rides on the inner race.
http://i602.photobucket.com/albums/tt102/ja2onx/bb.jpgTiny CNC router
And on the other side a have a pinch clamp thingy I knocked up which rides on the inner race, these are held tight against the bearings and then have their screws tightened preventing the lead screw from moving
Not as good as a thrust washer but seems to be ok time will tell.
http://i602.photobucket.com/albums/tt102/ja2onx/bb3.jpgTiny CNC router
« Last Edit: April 10, 2011, 03:30:44 PM by j45on »
Jason
Offline j45on
Re: Tiny CNC router
« Reply #12 on: April 13, 2011, 03:57:05 AM »
Well my steppers and controller have arrived
http://i602.photobucket.com/albums/tt102/ja2onx/5e9bc3fc.jpgTiny CNC router
And after a while last night I had all three running, as to if it is any good as mentioned in the "lost posts" time will tell.
Jason
Offline John Swift
Re: Tiny CNC router
« Reply #13 on: April 13, 2011, 05:32:40 AM »
Hi jason ,
I'm following your progress with great interest
 it looks like a good machine to try out our diy cnc skills ,
I hope your board has the problems fix that existed in the early versions of the board described in the cnczone posts
missing link from  lost post :- How I fixed my Chinese TB6560 controller (updated)
http://www.cnczone.com/forums/general_electronics_discussion/110986-how_i_fixed_my_chinese.html
  good luck
Offline j45on
Re: Tiny CNC router
« Reply #14 on: April 13, 2011, 07:26:48 AM »
Thanks John I had not bookmarked the link,I have now  :thumbup:
I also thought this would be great to learn about cnc.
There would be no point converting my mill for example if I could never figure out how to use the software.
I was watching some Mach3 videos last night I would have been stuffed without them,very helpfull.
http://www.machsupport.com/videos/
Jason
Re: Tiny CNC router
« Reply #15 on: April 13, 2011, 08:21:26 AM »
Jason,
Shout up if you get stuck on programming or Mach, I have used it the odd time or so.
John S.
Offline j45on
Re: Tiny CNC router
« Reply #16 on: April 13, 2011, 05:02:41 PM »
Jason,
John S.
Many thanks John  :thumbup: hopefully I wont have to but with so much cnc info on the net it can all get a bit confusing
For the life of me I cant find out how to work out my steps per mm when using micro-stepping  :palm:
My motors are 200 step per revolution
My lead screws are 2mm per revolution
I have the stepper driver set to 1/8 micro steps (the motors seem a lot quieter set like that)
Jason
Re: Tiny CNC router
« Reply #17 on: April 13, 2011, 05:09:06 PM »
Steps per revolution x microsteps / pitch
so 200 x 8 =1600 / 2 = 800
Offline j45on
Re: Tiny CNC router
« Reply #18 on: April 13, 2011, 05:15:23 PM »
Thank you John  :beer:
Jason
Offline j45on
Re: Tiny CNC router
« Reply #19 on: April 16, 2011, 05:23:27 PM »
Just a quick video of one axis working I'm still playing and tuning so it will probably go a bit quicker
hhmmmm video not imbedding  :scratch:
Jason
Offline John Swift
Re: Tiny CNC router
« Reply #20 on: April 16, 2011, 07:40:43 PM »
Hi Jason,
it will be a while before i'm ready but
i've had a look at the Mach3 videos  , lots of information to keep in mind thanks
your video looks like a good start
can't wait for the next one when its all running
one thing missing from your board is a charge pump circuit
just incase the computer stops working
http://www.machsupport.com/docs/ChargePumpSafety.pdf
while the  madmodders move has been taking place
I had another look at the cnczone thread and decided for problem boards
most of the mods could be made as a plug in adaptor / new breakout board
that plugs in the opto isolator and IC sockets
Offline j45on
Re: Tiny CNC router
« Reply #21 on: April 17, 2011, 02:50:45 PM »
Cheers John
Knowing next to nothing about CNC or mach3 I dont know if my driver board is faulty or not yet  :scratch:
All I know so far is that all three motors move when I press some keys and the DRO'S match the distance traveled.
Until I get it finished I guess I wont know.
I did some googling on charge pumps and I'm still confused :doh:
Jason
Offline John Swift
Re: Tiny CNC router
« Reply #22 on: April 17, 2011, 04:09:43 PM »
Hi Jason ,
the charge pump circuit is a simple voltage doubler circuit thats used as a "missing pulse" detector
this is used to generate a E-stop signal if the computer stops working
mach 3 can be configured to send  12500 pulses a second to pin 1 ,say
this is ac coupled to the junction of the two bat85 diodes to ensure the circuit doesn't respond to a static logic level
the hidden gate capacitance is charged as long as the pulses arrive on time
the fet is now  on and via the relay and E-stop circuit power enabled for  the machine
if / when the pc stops working the pulses to the circuit is lost and the E-stop activated
the second circuit achives the same thing with a timer circuit as long as it is reset in time
hope this makes sence
« Last Edit: April 17, 2011, 04:20:14 PM by John Swift »
Offline j45on
Re: Tiny CNC router
« Reply #23 on: April 17, 2011, 05:53:41 PM »
That make sense  :thumbup:
I have noticed that the motors make a "misfire like noise" every so often is this missed steps ?
And the motors make a hell of a noise when stopped would this be the motors or the driver ?
I think rather than trying to mod this driver I would go for separate drivers and a break out board
For my tiny machine these would probably do http://www.skpang.co.uk/catalog/product_info.php?products_id=576 worth trying one at that price
and use one of these http://www.diycnc.co.uk/html/pcpps.html it has a built in charge pump
Jason
Offline John Swift
Re: Tiny CNC router
« Reply #24 on: April 17, 2011, 07:27:27 PM »
Hi Jason ,
at the moment I don't have a system to play with so you are a few steps on from me
but if you can move your table up and down several times under load and the real position
is the same as mach thinks it is , your probably not missing steps
the noise you hear from the motor is mainly because the supply to the motor winding is chopped (PWM) to limit the current
this in conjunction with motor resonances and the interaction of a switch mode power supply you will hear various noises
if you don't need all signals in and out isolating the breakout board looks ok
the stepper drivers are a bit small for you motors I expect you will need to run them at the limit of 2A per phase
and still under run your motors
