Author Topic: My Chester Conquest Mill.....  (Read 22396 times)
« on: April 08, 2011, 01:16:21 PM »
A while back, I asked for forum guidance regarding a new mill.... http://madmodder.net/index.php?topic=4312.0
Well, It's finally. "finished"!   :D
Looking back..... It was a straightforward stripdown/ rebuild. Slightly more so, than any Chinese new machine.
New R8 spindle. Wonky locating peg. Pulled, re inserted, pressed back into place in me vice.......
The planned taper roller bearings are wider than the originals.
So, I turned the lower seat area as close as I sensibly could to the locating peg......
The machine arrived. Took off the head, stripped completely....
The spindle was oversize. The bearings would not have fitted without a lot of brute force. So, I had to ease the diameters with fine emery, until there was only interference in the bearing seat area.
Made plastic plugs for the now unused holes......
Top bearing and polished spindle........
The pulleys lined up perfectly, thanks to the lower bearing seat.
Look! No gears! The pulley was a little loose, running slightly eccentric on the spindle.......
Two years on from my last Conquest, they're still using the quirky stickers.......
Head back on. Time to fit/ lube the X and Y slideways.
Hmmm...... The leadscrew's a little short.......
Quick phonecall to Chester. "Oh? Now, that's a new one!"
Mk II screw arrived, next day.......
I really, don't like the Z axis fine feed knob.......
Bored out an old Warco lathe handwheel, to match a small spigot on the knob......
A few spots of sleeve retainer......
Looks ok, I think. Works well too.......
Now, it's time to do all the little tweaks which improve the handling/ working/ adjustment etc.
Filed a drill point on all the gib screws. Straightened and polished the gibs. Swapped the silly handwheel locknuts for stiffnuts.
I really dislike the wobbly handwheel handles..... So, I drill a piece of 10mm brass 8mm through. Then taper file the o/d to match the handle's taper bore.....
"Screw" it on. Part off.... Grease and assemble......
Last job was to fit the rubber bellows. Found they were both tight as a drumskin at full traverse.
Another phonecall produced a rear (largest) bellows, only. So, I fitted that one at the front.
The new rear one came from Arc Euro.
Job done, apart from final tramming.......
I'm a bit pleased with that......  :thumbup:
Offline jim
Re: My Chester Conquest Mill.....
« Reply #1 on: April 08, 2011, 01:20:48 PM »
worth the work :thumbup:
« Reply #2 on: April 08, 2011, 01:22:52 PM »
Looking good Dave, soon be back in the chip business.
:thumbup:
« Reply #3 on: April 08, 2011, 01:25:02 PM »
Looking great David  :clap: :clap: :clap: :clap:
Now will you be getting back on with those hot air engines  :poke: :poke: :lol: :)
« Reply #4 on: April 08, 2011, 02:19:53 PM »
Nice one Dave. :thumbup:
After all that, I hope it gives you many years of trouble free and enjoyable machining.
Offline Trion
« Reply #5 on: April 08, 2011, 04:49:35 PM »
Nicely done and well shown! Now lets see the mill in use! :)
Offline SPiN Racing
« Reply #6 on: April 08, 2011, 11:09:31 PM »
Beautifully done!
SPiN Racing
« Reply #7 on: April 09, 2011, 03:52:06 AM »
Thanks for your kind comments Chaps!  :thumbup:
Available time is still a problem. I think chipping production will be a little slow for some time, yet.  ::)
Hot air engines, Rob? Another orphan arrived, last week.......  :palm:
« Reply #8 on: April 09, 2011, 03:55:54 AM »
:lol: :lol: :lol: :lol: now why dose that not surprise me, David   :lol: :lol:
What have you taken in now ?   :proj:
« Reply #9 on: April 09, 2011, 08:19:30 AM »
Yer 'tiz Rob!  :thumbup:
Said, never to have run.  ::)
Swapped for a twin cylinder, Mamod SE3 steam engine, which I recycled some 18 months ago......  :D
« Reply #10 on: April 10, 2011, 04:56:20 AM »
Hi David
very interesting engine you have there  :clap: :clap: :clap: looks well made too  :dremel:  any idea why it never ran ?   :scratch:
i am sure you will be able to work your magic on it  :med:
« Reply #11 on: April 10, 2011, 05:42:39 AM »
Hi David
Probably because it's so ugly - it repels rotation.   :lol:
John S.
« Reply #12 on: April 10, 2011, 03:57:29 PM »
Hi David
John S.
That's a bit cutting to delicate constitutions, John!  :wack:
Don't you know, beauty is in the eye of the beholder? Only......  ::)
Anyroad, I'm not too pretty meself...... We'll get along ok!  :thumbup:
« Reply #13 on: April 10, 2011, 04:18:03 PM »
I think it's quite nice ...  :thumbup:
But then, I do have an eye for the finer things in life ...  ::) :beer:
Is it brass or maybe anodised aluminium ( or hallooooominum  )
I'm sure you will get it chirping Dave ...
Dave BC
« Reply #14 on: April 13, 2011, 02:13:43 AM »
Hi Dave.
Thanks for that! (A bit of deja vu, here)!  ::)
Brass, aluminium, stainless steel......  :thumbup:
Working on the Huxtable base at the mo. This one's waiting, in the cupboard with the other orphans......  :coffee:
