Author Topic: New Furnace Build ,,, Cupola  (Read 108550 times)
Online awemawson
Re: New Furnace Build ,,, Cupola
« Reply #100 on: June 02, 2013, 03:52:42 PM »
I do have a few sheets, but they are only 35mm wide by 125mm long. PM me an address if they are any use to you.
« Reply #101 on: June 02, 2013, 05:02:30 PM »
Hi Rob , its coming along really well now , I look forward to seeing the first cast getting done :thumbup:  :clap:
 Cheers Mick
« Reply #102 on: June 02, 2013, 07:27:58 PM »
Great to watch how you do things, Rob. Are you putting in a slagging door, too?
That furnace is a work of art.
« Reply #103 on: June 03, 2013, 11:47:49 AM »
Thanks Lads  :beer:
Hi Steve ,   I am in two minds about fitting a slag hole , I think maybe if I were to run the furnace all day slag build up could be a problem . What do you think ?  you fitting one ?
« Reply #104 on: June 03, 2013, 01:42:47 PM »
I don't think I am going to, Rob because my well will be so shallow @ 10 lbs iron. But I was thinking that it might make one man operation somewhat easier -- re skimming before the pour.
I guess the ideal for one person might be a teapot type ladle.
« Reply #105 on: June 07, 2013, 05:20:19 PM »
Well my fan motor EXPLODED!  :lol: :lol: :lol: :lol:
Tested insulation with mega  :zap: thats OK , ran up motor , bearings sound a tad dry , checked shaft  :palm:
Looks like it has had an ill fitting pulley on it  some time in its life ,,,,,,, the price you pay for using salvaged parts  :coffee: and the centrifugal switch contacts could do with a clean .
So its repair motor first job tomorrow  :dremel:
« Reply #106 on: June 07, 2013, 08:12:58 PM »
Yikes!
Wait a minute......
It didn't really explode,  you just took it apart to make sure it was in perfect running order.
Why I oughta....
« Reply #107 on: June 09, 2013, 02:29:11 PM »
Evening Lads  :beer:
A wee bit done to the motor , pressed off the bearings .
Ground the shaft end parallel with the good old tool post grinder  :dremel:
And pressed one of the new bearings back on the shaft .
Now when I removed the motor fan cover one of the wee screw heads sheared off .
Well corroded in as per with ally and steel . A bit of heat needed ,for jobs like this I use a heat gun .waist of time trying to use penetrating oil at this point .
File a couple of flats on the screw if poss  , don't cut a slot for a screwdriver or you will be getting the drill out ,  warm the ally part up , just wiggle the screw back and forth to crack the bond once its loose a bit then spay some penetrating oil on . been using this method for yonks on motor bike and outboard engines .
« Reply #108 on: June 09, 2013, 03:15:04 PM »
Nice repair on the shaft rob
Be careful with the grinding dust on your lathe bed  :lol: :lol: :lol: :lol: :lol: :lol:
"plus gas" is good for snapped studs (oxygen plus acetylene) :) :) :) :) :) :) :) :)
Online awemawson
« Reply #109 on: June 09, 2013, 03:48:33 PM »
Conventional advice is if you must use a tool post grinder, cover the ways in damp newspaper first, then after use, a good clean up and re-oil. Grinding grit trapped under a way wipe can cause no end of damage.
« Reply #110 on: June 10, 2013, 11:58:14 AM »
Sound advice Andrew  :thumbup:
I had the shop vac stuffed between the ways  :dremel:
Offline Mayhem
  • purveyor of mischief
« Reply #111 on: June 13, 2013, 09:02:04 AM »
Better pull your finger out Rob - Steve is talking about mixing mould sand in his build  :whip:
« Reply #112 on: June 13, 2013, 10:46:50 AM »
Talk is cheap.   :zap:   Raining again today can't even mix the stuff. Rain through to weekend predicted  :bang:
Last two years: drought. Can't complain.
« Reply #113 on: June 16, 2013, 03:48:36 AM »
 :lol: :lol: Aye Steve is kicking my butt  , I have been rather distracted this week , work , new shop toys , just picked up a load of blacksmiths gear yesterday  :hammer:  I am fighting the urge to knock up a forge  :lol: :lol:
Offline Mayhem
« Reply #114 on: June 16, 2013, 07:01:31 AM »
New shop toys you say?  Do show  :drool:
Did you see the forge I made from an old Landcruiser rim?
« Reply #115 on: June 16, 2013, 10:56:59 AM »
Hi Darren
Just some more rust old gear to add to my distractions  :Doh:
« Reply #116 on: June 16, 2013, 02:28:18 PM »
Wow, look at that!! :drool:
I'd be knocking up a forge if I had that trove, Rob ...... that is beautiful!
In fact, I've been resisting doing the same thing, And that might get unsuccessful if I keep tripping over the #$@! brake drum and 2" tee and pipe nipples just sitting in front of my shed door where I'm storing the torch. .....no, no, must complete the honey-do list ...... :coffee:
« Reply #117 on: June 16, 2013, 03:06:21 PM »
Hi Steve
 :lol: :lol: Its easy to get distracted  :Doh:  , My anvil is actually on a swage block stand .
So i will need to make a stand for the anvil as I will be putting the swage block in the stand , anvil is too low as is . I also have a pile of fire bricks to use up .
Thinking I could use some of them  on the forge hearth  , It would also give me some were to silver solder /braze if i clean the coke from the hearth .
Forge would also be  cheaper than using acetylene for hot work .
« Reply #118 on: June 16, 2013, 03:29:48 PM »
Mate
You have gone from a CNC build to Blacksmithing  :jaw: :jaw: :jaw: :jaw: :jaw: :bugeye: :bugeye: :bugeye: :bugeye:
They say that variety is the spice of life  :lol: :lol: :lol: :lol: :lol:
« Reply #119 on: June 16, 2013, 06:31:18 PM »
 Hi Rob .......................Go with the mood I say  :D ...... nowt wrong with combining CNC with blacksmithing lol. It looks like you have a canny selection of tongs etc there and the bick iron is a good handy bit of kit too.
I look forward to seeing the anvil stand and forge projects  :thumbup:
 cheers Mick
« Reply #120 on: June 16, 2013, 07:53:31 PM »
A CNC drop hammer, bellows and automated coal scuttle would show the 3D printer boys a thing or two, wouldn't it?
« Reply #121 on: June 16, 2013, 08:36:04 PM »
I hope you don't have any close neighbours - coz you won't be on speaking terms after you start using that lot :D
« Reply #122 on: June 21, 2013, 04:27:05 PM »
Hi Lads
Done a bit tonight , made the fan rotor boss ,
Cutting key way on the shaper .
Drilling the clamping screw holes , I did this in the lathe with my ye-oldey shop made dividing head .
That the boss finished
« Reply #123 on: June 21, 2013, 04:42:43 PM »
Very nice Rob :bow: :bow: :bow: :bow: :bow:
That key way is a beauty
« Reply #124 on: June 21, 2013, 05:40:48 PM »
 Shiny as usual Rob  :thumbup: , I like the dividing head for the lathe, just shows there is always more than one way to skin a cat , as John says  nice crisp keyway too. Hope you have a bsuy weekend in the shop and the project gets one step closer to being done  :clap:
 Cheers Mick.
