Author Topic: a new flame eater, just to be different  (Read 40680 times)
« on: March 28, 2011, 12:19:10 PM »
Hi all, after seeing the success of so many "poppins", and playing around with ideas, I thought I'd build another to try out some new intersections of different engines.  This is basically a "poppin", but scaled up a bit, with a three quarter inch bore, an inch and a quarter stroke, cast iron piston in a cast iron cylinder, with a cast iron head.
I started with a stick of cast iron, about an inch and a quarter diameter, turning the cooling fins first so I could use the tailstock for support.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0001-20.jpga new flame eater, just to be different
starting the cooling fins
http://i894.photobucket.com/albums/ac150/madjackghengis/_0002-19.jpga new flame eater, just to be different
fins completed, time to drill before boring.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0003-19.jpga new flame eater, just to be different
After step drilling and then boring just undersized, I reamed it out with a .750 reamer
http://i894.photobucket.com/albums/ac150/madjackghengis/_0004-18.jpga new flame eater, just to be different
I want this to have good compression, so I'm going to lap it using a piece of delrin plastic to hold the compound, and have cut it to just barely fit in the bore as reamed.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0006-16.jpga new flame eater, just to be different
after smearing the lap with some fine valve grinding compound, it is rolled on a steel table with a piece of steel to embed the compound in the plastic, and this spreads the compound evenly as well
http://i894.photobucket.com/albums/ac150/madjackghengis/_0005-17.jpga new flame eater, just to be different
the lap is put in the lathe, the cylinder held in hand, and it is lapped until the feel of the whole of the cylinder is the same, and there are no tight spots.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0008-15.jpga new flame eater, just to be different
a piston has to be turned up, so I put a pipe cap on a piece of pipe, and turned the o.d. to just barely fit the bore.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0007-15.jpga new flame eater, just to be different
I wrapped the piston with a piece of notebook paper to protect its finish, and bored out the threads, bored to get about a forty thousandths wall, and to get a flat surface parallel to the front face, on the inside
http://i894.photobucket.com/albums/ac150/madjackghengis/_0011-15.jpga new flame eater, just to be different
once the piston is ready, I used some polishing compound as a carrier, and will be using jewler's rouge to lap the piston to the cylinder
http://i894.photobucket.com/albums/ac150/madjackghengis/_0012-16.jpga new flame eater, just to be different
with the piston screwed to the end of an old throttle shaft of brass out of a carburetor, I've rubbed in the rouge and clamped the shaft in a vise to hold the piston steady
http://i894.photobucket.com/albums/ac150/madjackghengis/_0013-14.jpga new flame eater, just to be different
the cylinder is carefully rotated and moved back and forth as it eases into the bore, the compound opening it up just a bit as it goes
http://i894.photobucket.com/albums/ac150/madjackghengis/_0009-15.jpga new flame eater, just to be different
a look at the piston with compound blackened by the lapping, ready for fresh compound.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0010-15.jpga new flame eater, just to be different
the final lapping is done with both piston and cylinder in hand, for the feel and to be certain any tight spots are found and worked out
http://i894.photobucket.com/albums/ac150/madjackghengis/_0017-10.jpga new flame eater, just to be different
with the lapping completed, the cylinder is set up in the milling vise for mounting holes to be center drilled
http://i894.photobucket.com/albums/ac150/madjackghengis/_0016-11.jpga new flame eater, just to be different
after which the bolt holes are drilled and tapped
http://i894.photobucket.com/albums/ac150/madjackghengis/_0018-9.jpga new flame eater, just to be different
here I'm squaring up the top side of the frame of the engine
http://i894.photobucket.com/albums/ac150/madjackghengis/_0019-9.jpga new flame eater, just to be different
flipping it over, getting ready to flycut the bottom side
http://i894.photobucket.com/albums/ac150/madjackghengis/_0020-9.jpga new flame eater, just to be different
and flycutting it, using soluable oil for coolant
http://i894.photobucket.com/albums/ac150/madjackghengis/_0021-7.jpga new flame eater, just to be different
at this point, it is time to square up the face where the cylinder will mount
http://i894.photobucket.com/albums/ac150/madjackghengis/_0023-8.jpga new flame eater, just to be different
flycutting the front face
http://i894.photobucket.com/albums/ac150/madjackghengis/_0024-7.jpga new flame eater, just to be different
the final cut, finishing the end
http://i894.photobucket.com/albums/ac150/madjackghengis/_0026-5.jpga new flame eater, just to be different
touching off with the end mill, using a cigarette paper to get a dead zero
http://i894.photobucket.com/albums/ac150/madjackghengis/_0027-6.jpga new flame eater, just to be different
milling the slot which will set up the thickness of the front face where the cylinder mounts
http://i894.photobucket.com/albums/ac150/madjackghengis/_0028-4.jpga new flame eater, just to be different
touching off the back side, again with a cigarette paper for zero clearance on the cutter
http://i894.photobucket.com/albums/ac150/madjackghengis/_0029-5.jpga new flame eater, just to be different
touching off the front side, getting ready to mill the slot for the crank assembly
http://i894.photobucket.com/albums/ac150/madjackghengis/_0030-4.jpga new flame eater, just to be different
starting the slot, lots of chips and fluid
http://i894.photobucket.com/albums/ac150/madjackghengis/_0031-6.jpga new flame eater, just to be different
lots more chips, removing a couple cubic inches of volume
http://i894.photobucket.com/albums/ac150/madjackghengis/_0032-3.jpga new flame eater, just to be different
finishing up the slot for the crankshaft, taking light cuts the full depth, and getting the two pillars even in thickness
this about does it for today, more to come soon.  Mad Jack
Re: a new flame eater, just to be different
« Reply #1 on: March 28, 2011, 12:44:15 PM »
This will be very intressting to follow  :thumbup: :thumbup:
« Reply #2 on: March 29, 2011, 11:35:57 AM »
Thanks Saw, well, to start on the crank, I put a piece of free machining inch and three quarters in the lathe, center drilled it, drilled and reamed out a three sixteenths hole, about an inch deep, as the mainshaft holes.  I will be parting off two crank cheeks, after I put the stock in the milling vise and drill and ream the crank pin hole, this ensures the two cheeks will hold the shafts and pin parallel to each other.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0048-1.jpga new flame eater, just to be different
with the center hole drilled and reamed, the stock is set up square in the milling vise, and the crank pin hole drilled and reamed
http://i894.photobucket.com/albums/ac150/madjackghengis/_0049-1.jpga new flame eater, just to be different
the finished hole will give an inch and an eighth stroke
http://i894.photobucket.com/albums/ac150/madjackghengis/_0050.jpga new flame eater, just to be different
now it needs to be cut off, and the two crank cheeks faced off parallel to each other
http://i894.photobucket.com/albums/ac150/madjackghengis/_0051.jpga new flame eater, just to be different
ready to go back in the lathe
http://i894.photobucket.com/albums/ac150/madjackghengis/_0052-1.jpga new flame eater, just to be different
two slices a bit over a quarter in thick, enough to face off clean
http://i894.photobucket.com/albums/ac150/madjackghengis/_0054.jpga new flame eater, just to be different
facing the other side off
http://i894.photobucket.com/albums/ac150/madjackghengis/_0055.jpga new flame eater, just to be different
setting up the cheeks for balancing holes to be drilled
http://i894.photobucket.com/albums/ac150/madjackghengis/_0056.jpga new flame eater, just to be different
center drilling, and drilling a pilot hole for each balance hole
http://i894.photobucket.com/albums/ac150/madjackghengis/_0057.jpga new flame eater, just to be different
opening up the holes to a size which looks good
http://i894.photobucket.com/albums/ac150/madjackghengis/_0062.jpga new flame eater, just to be different
cleaning up the crank cheeks for locktite to hold the shafts and pin in place
http://i894.photobucket.com/albums/ac150/madjackghengis/_0061.jpga new flame eater, just to be different
pressing in the crankpin, using a roller bearing in the main shaft holes for alignment
http://i894.photobucket.com/albums/ac150/madjackghengis/_0064.jpga new flame eater, just to be different
using a piece of tube, a bar, setting up to press in the mainshafts
http://i894.photobucket.com/albums/ac150/madjackghengis/_0063.jpga new flame eater, just to be different
pressing a shaft home
http://i894.photobucket.com/albums/ac150/madjackghengis/_0065.jpga new flame eater, just to be different
the assembled crank laying in the slots of the frame
http://i894.photobucket.com/albums/ac150/madjackghengis/_0066.jpga new flame eater, just to be different
another view of the crank laying in place, that's it for now, more to come soon, Mad Jack
Offline cfellows
« Reply #3 on: March 31, 2011, 10:53:16 AM »
Nice looking engine.  Will be interesting to see how she runs!
Chuck
« Reply #4 on: March 31, 2011, 11:18:21 AM »
madjackghengis I have to ask you some questions about the flycut (I'll got min this morning but I have never run it). How fast shell the drill run during flycuting?
How deep can it take? I suppose it deppend on the mill, I'll got an china-mill, a small one..  ::)
Your progress on youre engine is fantastic.  :bow:
Offline BiggerHammer
« Reply #5 on: March 31, 2011, 08:41:05 PM »
Thank you for showing how you lap your cylinder and piston. Looks much more effective than my method.
« Reply #6 on: March 31, 2011, 08:51:28 PM »
Lookin' good Jack.
You seem to be gettin' a bit of a fetish for them thar lickers.
Be careful, they can take over your life.
« Reply #7 on: April 01, 2011, 02:01:16 AM »
Great job Jack,  :thumbup:  :clap: :clap: :clap:
All the clutter on your benches is very interesting too, trying to work out what all the bits and pieces are for.
  :wack: Yes I know I'm a nosey bugger.
 :headbang: :headbang: :headbang: :headbang:
« Reply #8 on: April 01, 2011, 12:00:15 PM »
Thanks all for the interest, Saw, run your flycutter as fast as you can on aluminum, with as fine an edge as you can hone on it with a stone, and use coolant, try to have the cutter overhang either side by just a little bit, and make sure you're head is trammed (perpendicular to the table) and you'll get a nice finish.  John, it's one of those things that bites you, and then you have this disease :lol:, I get too many ideas looking at everyone else's projects, and keep wanting to try them out.  Stew, don't worry about nosey, I can't help but look at all my mate's clutter as well, with interest and wonder, suffice to say some are parts that didn't work but might work on something else, some are potential parts, and some are just clutter, there for confusion's sake.  Mr. Hammer, I learned to lap for fuel pumps for diesels, and for aircraft hydraulics, I can't help it, when I have fine grained cast iron, it demands a finish worthy of its structure and capacity, as it's so easy to work with and get a gorgeous finish.
    I've been busy writing this morning, but I've got more to post, so I will have substantially more posted tomorrow, and maybe a video if I'm lucky.  John, every time I see a flame eater, it's got a different valve arrangement, or some other substantial part is interesting, and I can't seem to not build it into "just one more before I get back to my main post".  Then I also get the comments of those who come into my shop and that just takes me over the top and I've got to grab another piece of cast or billet or something, and get on with the idea.  This engine is your fault, with that crazy valve arrangement :poke: :lol: :beer:  Cheers, Jack
« Reply #9 on: April 01, 2011, 12:41:37 PM »
Jack,
I know exactly where you are coming from.
I got enthralled with Chuck's poppet valve engines a while back, and just had to make one, but got carried away experimenting with different cams. It is half way thru a bling exercise, one of the many engines I have to finish off after the proving run. My flame licker takes priority though, that is being finished off first.
This is what I ended up with when I tried to make an engine like Chuck's.
« Reply #10 on: April 02, 2011, 12:03:21 PM »
So John, you just come back with a challenge of another engine to have to look at and consider making a copy, well, if that's your answer, here's mine :lol:
http://i894.photobucket.com/albums/ac150/madjackghengis/_0067.jpga new flame eater, just to be different
cutting off the end of the con rod shaft stock (the bent end, because this is not an elbow engine)
http://i894.photobucket.com/albums/ac150/madjackghengis/_0068.jpga new flame eater, just to be different
with the shaft in a spindex, milling the end of the rod flat to go in the gudeon block of the piston
http://i894.photobucket.com/albums/ac150/madjackghengis/_0069.jpga new flame eater, just to be different
having milled both sides, drilling the gudeon pin hole, a sixteenth of an inch diameter
http://i894.photobucket.com/albums/ac150/madjackghengis/_0007-17.jpga new flame eater, just to be different
the big end of the rod will be a two piece design, as in the plans for the poppin', cutting off a piece of bronze for the big end
http://i894.photobucket.com/albums/ac150/madjackghengis/_0008-17.jpga new flame eater, just to be different
laying it out for cutting in two
http://i894.photobucket.com/albums/ac150/madjackghengis/_0009-17.jpga new flame eater, just to be different
some jobs are just too small for machine work
http://i894.photobucket.com/albums/ac150/madjackghengis/_0010-17.jpga new flame eater, just to be different
the two pieces, ready for some machining
http://i894.photobucket.com/albums/ac150/madjackghengis/_0011-17.jpga new flame eater, just to be different
both pieces were set up in the vise with a square, I used a three sixteenths end mill to slot the first piece, forgot to take a picture
http://i894.photobucket.com/albums/ac150/madjackghengis/_0012-18.jpga new flame eater, just to be different
setting up to machine the second piece to fit the first
http://i894.photobucket.com/albums/ac150/madjackghengis/_0013-16.jpga new flame eater, just to be different
starting machining, this will end up a "tongue" to fit in the slot of the other
http://i894.photobucket.com/albums/ac150/madjackghengis/_0014-15.jpga new flame eater, just to be different
finishing cut on the first side
http://i894.photobucket.com/albums/ac150/madjackghengis/_0015-13.jpga new flame eater, just to be different
finding the second side with a cigarette paper, this side is critical as the fit has to be snug without the solder
http://i894.photobucket.com/albums/ac150/madjackghengis/_0017-12.jpga new flame eater, just to be different
second side found, ready to mill
http://i894.photobucket.com/albums/ac150/madjackghengis/_0018-11.jpga new flame eater, just to be different
making chips out of bronze
http://i894.photobucket.com/albums/ac150/madjackghengis/_0019-11.jpga new flame eater, just to be different
more chips
http://i894.photobucket.com/albums/ac150/madjackghengis/_0021-9.jpga new flame eater, just to be different
after measuring, making the final cut
http://i894.photobucket.com/albums/ac150/madjackghengis/_0022-7.jpga new flame eater, just to be different
the two pieces slip together just like they were made for each other, then soft soldered, forgot to take a picture oops :headbang:
http://i894.photobucket.com/albums/ac150/madjackghengis/_0023-10.jpga new flame eater, just to be different
clamped in the vise, finding the center line
first, one side
http://i894.photobucket.com/albums/ac150/madjackghengis/_0025-8.jpga new flame eater, just to be different
then the other, and center up using the DRO
http://i894.photobucket.com/albums/ac150/madjackghengis/_0026-7.jpga new flame eater, just to be different
changing to a pointy wiggler end, to find the end of the "tongue"
http://i894.photobucket.com/albums/ac150/madjackghengis/_0027-8.jpga new flame eater, just to be different
found, mill zeroed here for the crank pin
http://i894.photobucket.com/albums/ac150/madjackghengis/_0030-6.jpga new flame eater, just to be different
center drilled, ready for drilling for reaming
http://i894.photobucket.com/albums/ac150/madjackghengis/_0032-5.jpga new flame eater, just to be different
http://i894.photobucket.com/albums/ac150/madjackghengis/_0033-5.jpga new flame eater, just to be different
just under reamer size
http://i894.photobucket.com/albums/ac150/madjackghengis/_0034-5.jpga new flame eater, just to be different
the reamer set in place
http://i894.photobucket.com/albums/ac150/madjackghengis/_0035-3.jpga new flame eater, just to be different
reaming the crank pin hole
http://i894.photobucket.com/albums/ac150/madjackghengis/_0036-4.jpga new flame eater, just to be different
and done, now the clamp hole
http://i894.photobucket.com/albums/ac150/madjackghengis/_0037-3.jpga new flame eater, just to be different
centering side to side
http://i894.photobucket.com/albums/ac150/madjackghengis/_0039-2.jpga new flame eater, just to be different
center drilling
http://i894.photobucket.com/albums/ac150/madjackghengis/_0040-2.jpga new flame eater, just to be different
tap drilling for #4-40 bolt
http://i894.photobucket.com/albums/ac150/madjackghengis/_0041-2.jpga new flame eater, just to be different
clearance drilling
http://i894.photobucket.com/albums/ac150/madjackghengis/_0042-2.jpga new flame eater, just to be different
tapping for the bolt
http://i894.photobucket.com/albums/ac150/madjackghengis/_0043-2.jpga new flame eater, just to be different
reducing the width of the block
http://i894.photobucket.com/albums/ac150/madjackghengis/_0044-2.jpga new flame eater, just to be different
and the other side
http://i894.photobucket.com/albums/ac150/madjackghengis/_0045-2.jpga new flame eater, just to be different
setting up to reduce the length a bit
http://i894.photobucket.com/albums/ac150/madjackghengis/_0047-2.jpga new flame eater, just to be different
first cut, vise not quite tight enough, no problem though
http://i894.photobucket.com/albums/ac150/madjackghengis/_0048-2.jpga new flame eater, just to be different
taking off the first corner
http://i894.photobucket.com/albums/ac150/madjackghengis/_0050-1.jpga new flame eater, just to be different
and taking off the other
http://i894.photobucket.com/albums/ac150/madjackghengis/_0051-1.jpga new flame eater, just to be different
sanding off the burrs
http://i894.photobucket.com/albums/ac150/madjackghengis/_0052-2.jpga new flame eater, just to be different
chucking in the four jaw, for the rod hole to be drilled and tapped
http://i894.photobucket.com/albums/ac150/madjackghengis/_0053-2.jpga new flame eater, just to be different
after drilling, tapping for the rod
http://i894.photobucket.com/albums/ac150/madjackghengis/_0055-1.jpga new flame eater, just to be different
ready for the finishing work
http://i894.photobucket.com/albums/ac150/madjackghengis/_0056-1.jpga new flame eater, just to be different
filing the corners for radii
http://i894.photobucket.com/albums/ac150/madjackghengis/_0057-1.jpga new flame eater, just to be different
and the second corner, too
http://i894.photobucket.com/albums/ac150/madjackghengis/_0058-1.jpga new flame eater, just to be different
cleaned up, burrs removed, ready for un-soldering
http://i894.photobucket.com/albums/ac150/madjackghengis/_0059-1.jpga new flame eater, just to be different
solder removed, time to clean it up
http://i894.photobucket.com/albums/ac150/madjackghengis/_0060-1.jpga new flame eater, just to be different
another view of the parts
http://i894.photobucket.com/albums/ac150/madjackghengis/_0061-1.jpga new flame eater, just to be different
the gudeon block for the piston
http://i894.photobucket.com/albums/ac150/madjackghengis/_0062-1.jpga new flame eater, just to be different
milling the end, the other is already tapped for the screw to hold it to the piston
http://i894.photobucket.com/albums/ac150/madjackghengis/_0063-1.jpga new flame eater, just to be different
milling the other flat
http://i894.photobucket.com/albums/ac150/madjackghengis/_0064-1.jpga new flame eater, just to be different
touching off with the slitting saw
http://i894.photobucket.com/albums/ac150/madjackghengis/_0065-1.jpga new flame eater, just to be different
slitting for the connecting rod small end, a sixteenth slot
done and ready to install in the piston.  That's about it for today, more to come tomorrow.  Thanks for watching, cheers, Jack :beer: :poke:
« Reply #11 on: April 02, 2011, 12:13:31 PM »
It's always so intressting to follow your'e work. I lifting my hat for the master.  :bow: :bow: :bow:
« Reply #12 on: April 02, 2011, 12:31:40 PM »
By 'ek Jack!  :bugeye:
I knew you were starting another 'licker. But, you've galloped off without me! Where have I been?  :scratch:
It's all looking really good.....   :clap: :clap:
Love the big end assembly..... Couldn't work out what you were doing. Until you showed it separated!   :thumbup:
Keep on, keeping on.....  :D
Offline dbvandy
« Reply #13 on: April 02, 2011, 01:25:14 PM »
watts dis fancy ma-sheene you doin all theis cuttin on?  Looks x-pen-sive....
 :poke:
Doug
"if you can pay someone to do it, then you can do it... just might cost more and take longer."  ~Grandpa Vanderbilt
« Reply #14 on: April 03, 2011, 11:40:10 AM »
Hi Doug, do you mean my Taiwanese mill?  It's only expensive if you consider money as an object, I just consider it a means to increasing my tooling.  It's only taken forty years to build my shop, I figure by the time I reach middle age, I should have a pretty nice set up.  Once I saw the form of big end in the "poppin", I had to make one, and I'm very happy with how it turned out, tight enough to be good bearing, but loose enough to turn freely, and it makes removal of the rod easy, even with the engine fully assembled.  The original rod was a piece of eighth inch rod which I flatted on end in the mill, and drilled a wrist pin hole in, and turned down the other end to about .095 and threaded 4-40, but it was a mite bit long, and when I tried to turn off the extra eighth inch, I broke the threads clean off, so I had to start again on the rod.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0001-22.jpga new flame eater, just to be different
I didn't have another piece of eighth inch that was straight, but I found a piece of eighth in key stock, and decided I could mill both sides on one end, in the vise and put a gudeon pin hole in it, and then turn down the other end and thread it at the right length.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0002-21.jpga new flame eater, just to be different
using an indicator, I centered it in a four jaw, then stoned the tool, as I always do before a new cut.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0003-21.jpga new flame eater, just to be different
I grind the cutter, then lap it on a diamond lap, then I stone it between pieces until it needs grinding again, the tangential holder lets it hold a good edge for a lot of work, and is easy to stone off.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0005-19.jpga new flame eater, just to be different
this is my tailstock die holder set up, bought from the son of a machinist who has long since passed, a piece of inch hex stock reamed half in through, with one end bored for five eighths dies, and the other for three quarter inch dies, and four grub screws on each end to hold the dies in.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0006-18.jpga new flame eater, just to be different
having turned about three eighths of an in down to .095, I threaded it for 4-40, for the right overall length
http://i894.photobucket.com/albums/ac150/madjackghengis/_0007-18.jpga new flame eater, just to be different
and here's the finished rod next to the broken one
http://i894.photobucket.com/albums/ac150/madjackghengis/_0010-18.jpga new flame eater, just to be different
a little bit of hand work, putting a radius on the little end with a file
http://i894.photobucket.com/albums/ac150/madjackghengis/_0009-18.jpga new flame eater, just to be different
and the other side as well, making it look good, even if it can't be seen
http://i894.photobucket.com/albums/ac150/madjackghengis/_0011-18.jpga new flame eater, just to be different
and finished, radii and all
http://i894.photobucket.com/albums/ac150/madjackghengis/_0012-19.jpga new flame eater, just to be different
having already put the small end in the gudeon block and screwed it into the piston, it takes a bit of finagling to get the pieces of the rod end around the crankpin without dropping them, and they need to stay oriented right.  I put a small rubber o-ring on each side of the main shaft, for the ball bearings to butt up against, and centered the crank assembly between the pillars before adding the rod and piston assembly.  The rod is locked into the big end with a lock nut, setting minimal clearance on the head end
http://i894.photobucket.com/albums/ac150/madjackghengis/_0013-17.jpga new flame eater, just to be different
a bit of a side view of the engine with the rod assembly in place, the square rod being rather easy to align the gudeon pin with the crank pin, and easy to hold while tightening up the lock nut.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0015-14.jpga new flame eater, just to be different
I wasn't sure what I was doing with the head when I made it, so it is thick, and needs to be a lot thinner, so the flycutter, at slightly slower speed is used to cut it down to size.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0016-14.jpga new flame eater, just to be different
I'd already drilled the head bolt holes, but they don't interfere with reducing the thickness
http://i894.photobucket.com/albums/ac150/madjackghengis/_0017-13.jpga new flame eater, just to be different
with the head down to size, its time to counterbore the holes so the bolts are below the surface
http://i894.photobucket.com/albums/ac150/madjackghengis/_0018-12.jpga new flame eater, just to be different
finishing up the counter boring
http://i894.photobucket.com/albums/ac150/madjackghengis/_0019-12.jpga new flame eater, just to be different
and the finished head, next to the engine.
I've decided what to do for valving, and will be posting that next probably, and then maybe a test run.  Cheers,  :beer: :nrocks: Jack
« Reply #15 on: April 04, 2011, 01:06:34 PM »
Brilliant work there Jack, just found this. I love your tweaks on the design and the angles used.  :bow:
Watching avidly.
Offline cfellows
« Reply #16 on: April 06, 2011, 10:20:10 AM »
Really like the aesthetics of this engine.  It's a very pleasing design.  By the way, do you stone the tangential cutter on the top, flat part or on the sides and leading corner?
Chuck
« Reply #17 on: April 06, 2011, 12:40:48 PM »
Thanks Nick, this has been a learning experience all the way along.  Hi all, getting close to a finished engine, so here's today's installment.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0001-23.jpga new flame eater, just to be different
a piece of brass round has been bored out for a flywheel, so I've turned a piece of steel for the hub, and I'm center drilling it in preparation for drilling and reaming to fit the main shaft
http://i894.photobucket.com/albums/ac150/madjackghengis/_0002-22.jpga new flame eater, just to be different
I missed a picture of drilling, but here's reaming it out to three sixteenths
http://i894.photobucket.com/albums/ac150/madjackghengis/_0003-22.jpga new flame eater, just to be different
facing off the end of the hub and ensuring the shoulder is square with the bore
http://i894.photobucket.com/albums/ac150/madjackghengis/_0004-21.jpga new flame eater, just to be different
setting the hub up for grub screws, I like to put two at least, and at 90 degrees for security
http://i894.photobucket.com/albums/ac150/madjackghengis/_0005-20.jpga new flame eater, just to be different
centering the spindle over the hub
http://i894.photobucket.com/albums/ac150/madjackghengis/_0006-19.jpga new flame eater, just to be different
center drilling the first grub screw hole
http://i894.photobucket.com/albums/ac150/madjackghengis/_0007-19.jpga new flame eater, just to be different
tap drilling the first hole
http://i894.photobucket.com/albums/ac150/madjackghengis/_0008-19.jpga new flame eater, just to be different
tapping the first hole, the second hole is treated the same, using the tap drill in the tapped hole as a guide to getting the second hole at 90 degrees from the first
http://i894.photobucket.com/albums/ac150/madjackghengis/_0009-19.jpga new flame eater, just to be different
having centered up the cam blank, drilling the center hole for the first grub screw
http://i894.photobucket.com/albums/ac150/madjackghengis/_0010-19.jpga new flame eater, just to be different
tap drilling the cam blank
http://i894.photobucket.com/albums/ac150/madjackghengis/_0012-20.jpga new flame eater, just to be different
tapping the grub screw hole, 4-40
http://i894.photobucket.com/albums/ac150/madjackghengis/_0013-18.jpga new flame eater, just to be different
setting up for the second grub screw hole, note the tap drill sticking out to the right
http://i894.photobucket.com/albums/ac150/madjackghengis/_0014-17.jpga new flame eater, just to be different
center drilling again
http://i894.photobucket.com/albums/ac150/madjackghengis/_0015-15.jpga new flame eater, just to be different
flywheel bored and faced for the hub
http://i894.photobucket.com/albums/ac150/madjackghengis/_0017-14.jpga new flame eater, just to be different
hub pressed in, facing off the other side holding the hub
http://i894.photobucket.com/albums/ac150/madjackghengis/_0016-15.jpga new flame eater, just to be different
flywheel and cam, ready for mounting on the main shafts
http://i894.photobucket.com/albums/ac150/madjackghengis/_0018-13.jpga new flame eater, just to be different
with a grub screw on the end of the allen wrench, the cup is stoned flat to keep from scoring the shaft  I will have to adjust the cam some, and don't want the shaft all buggered up
http://i894.photobucket.com/albums/ac150/madjackghengis/_0020-12.jpga new flame eater, just to be different
valve lever blanks, ready for hole drilling
http://i894.photobucket.com/albums/ac150/madjackghengis/_0021-10.jpga new flame eater, just to be different
drilling the first of many holes
http://i894.photobucket.com/albums/ac150/madjackghengis/_0019-13.jpga new flame eater, just to be different
filing the first of many radii on valve train gear
http://i894.photobucket.com/albums/ac150/madjackghengis/_0022-8.jpga new flame eater, just to be different
the main valve actuating arm with its follower bearing riveted in place
http://i894.photobucket.com/albums/ac150/madjackghengis/_0023-11.jpga new flame eater, just to be different
two connecting link plates, clamped for drilling holes
http://i894.photobucket.com/albums/ac150/madjackghengis/_0024-10.jpga new flame eater, just to be different
holes drilled for the arm, the valve pin, and for the pivot rivet to hold them to the valve levers
http://i894.photobucket.com/albums/ac150/madjackghengis/_0025-9.jpga new flame eater, just to be different
setting up to cut off the rivet, a brass brad from a box of picture hangers
http://i894.photobucket.com/albums/ac150/madjackghengis/_0026-8.jpga new flame eater, just to be different
cutting off the rivet, draw sawing for control
http://i894.photobucket.com/albums/ac150/madjackghengis/_0027-9.jpga new flame eater, just to be different
the main lever in place with the valve link riveted in place
http://i894.photobucket.com/albums/ac150/madjackghengis/_0028-7.jpga new flame eater, just to be different
the cam back off the engine, getting a flat milled so I can set the valve at its open point
http://i894.photobucket.com/albums/ac150/madjackghengis/_0029-8.jpga new flame eater, just to be different
getting the flat down to the hub diameter, minus a hair for filing
http://i894.photobucket.com/albums/ac150/madjackghengis/_0030-7.jpga new flame eater, just to be different
with the valve lever in place, some idea of location established with the flat, drilling the generator brush for the valve pin which will carry it.  The pin is about .093 diameter, with .040 pins machined on each end, it came like this out of a CD player or something, and happened to be the right width for the head, and already have pins machined
http://i894.photobucket.com/albums/ac150/madjackghengis/_0031-9.jpga new flame eater, just to be different
having set up the valve, the cam is removed again, to get its second flat milled, to make it proper timing
http://i894.photobucket.com/albums/ac150/madjackghengis/_0033-6.jpga new flame eater, just to be different
several passes later, the cam is on its final cut
http://i894.photobucket.com/albums/ac150/madjackghengis/_0034-6.jpga new flame eater, just to be different
the cam, ready for some filing to remove the sharp corners, and make for smooth valve opening and closing
http://i894.photobucket.com/albums/ac150/madjackghengis/_0035-4.jpga new flame eater, just to be different
not quite done, but ready for a trial run.  You have to test things like cam timing and how things like the linkage work.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0001-24.jpga new flame eater, just to be different
engine disassembled for drilling mounting holes, all the parts spread out
http://i894.photobucket.com/albums/ac150/madjackghengis/_0002-23.jpga new flame eater, just to be different
drilling the mounting holes for mounting on some brown stuff
http://i894.photobucket.com/albums/ac150/madjackghengis/_0001-25.jpga new flame eater, just to be different
after the first run, I found the levers of the valve gear wrong, and remade them a quarter of an inch longer so the valve would stay flat against the head, something it quit doing in the first run.  I didn't take pictures of cutting out new brass levers, but do show how I finish the flat pieces for a good finish.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0002-24.jpga new flame eater, just to be different
another view of the surface plate, 18 by 24 by 4 inches
http://i894.photobucket.com/albums/ac150/madjackghengis/_0009-20.jpga new flame eater, just to be different
I decided I needed more flywheel, so I took a piece of steel shaft, a bronze gear with its teeth eaten away, and made a hub, then pressed on the old gear, and turned the o.d. smooth
http://i894.photobucket.com/albums/ac150/madjackghengis/_0010-20.jpga new flame eater, just to be different
cutting off the hub
http://i894.photobucket.com/albums/ac150/madjackghengis/_0011-20.jpga new flame eater, just to be different
the hub and old gear ready to be mated
http://i894.photobucket.com/albums/ac150/madjackghengis/_0012-21.jpga new flame eater, just to be different
centering for drilling grub screws
http://i894.photobucket.com/albums/ac150/madjackghengis/_0013-19.jpga new flame eater, just to be different
using a long center drill, center drilling the hub
http://i894.photobucket.com/albums/ac150/madjackghengis/_0014-18.jpga new flame eater, just to be different
after tap drilling, tapping the hub
http://i894.photobucket.com/albums/ac150/madjackghengis/_0015-16.jpga new flame eater, just to be different
setting up for the second grub screw, same as the first
http://i894.photobucket.com/albums/ac150/madjackghengis/_0016-16.jpga new flame eater, just to be different
again, stoning off the cup of the screw
http://i894.photobucket.com/albums/ac150/madjackghengis/_0019-14.jpga new flame eater, just to be different
with the head at .300 in thick, I found I needed to bore a taper as the straight port seemed to "quench" the flame as it went in, the angle is such that the diameter of the conical port is bore diameter at the head surface, and has about .020 in thickness on the face end
http://i894.photobucket.com/albums/ac150/madjackghengis/_0020-13.jpga new flame eater, just to be different
having seen several such engines with pressure relief valves of sorts, I decided one might help the running of this engine, so I used a #1 center drill, and drilled in the top center of the head till the tip of the center drill just pierced the port.  I'd found a ball bearing which measures .112, which dropped nicely into the .125 hole the body of the center drill left.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0021-11.jpga new flame eater, just to be different
another view of the head and the center drill.  I also drilled a .140 hole deep enough to leave about an .100 in of the center drill hole, the full taper seat of the center drill for the ball to seat on, but with plenty of room for excess air to escape
http://i894.photobucket.com/albums/ac150/madjackghengis/_0022-9.jpga new flame eater, just to be different
here you can see the tapered port, and the pressure relief hole just entering it
http://i894.photobucket.com/albums/ac150/madjackghengis/_0024-11.jpga new flame eater, just to be different
another view of the head, relief hole and check ball
http://i894.photobucket.com/albums/ac150/madjackghengis/_0025-10.jpga new flame eater, just to be different
I had left the head square for surface area for the valve, but found no need, so turned it round to reduce the mass of the head
http://i894.photobucket.com/albums/ac150/madjackghengis/_0026-9.jpga new flame eater, just to be different
I bolted the head on the cylinder, centered it up, and turned it down, here it is done, with the relief port on top
http://i894.photobucket.com/albums/ac150/madjackghengis/_0027-10.jpga new flame eater, just to be different
I almost lost the ball testing to see if it worked, and put the head in the mill vise to drill a hole for a pin to retain the ball.  The pin hole goes through from the cylinder surface, through the relief hole, and just starts in the front surface of the head, it is .042 as I have some .041 spring wire to use for the pin.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0028-8.jpga new flame eater, just to be different
drilling from the cylinder side
http://i894.photobucket.com/albums/ac150/madjackghengis/_0029-9.jpga new flame eater, just to be different
drilled, ready to clean all the swarf out of tiny holes
http://i894.photobucket.com/albums/ac150/madjackghengis/_0030-8.jpga new flame eater, just to be different
head, check ball, and retaining pin
http://i894.photobucket.com/albums/ac150/madjackghengis/_0018-14.jpga new flame eater, just to be different
this is the first run after fixing the valve gear, but before the check valve was added, this run was the reason for the check ball.
http://i894.photobucket.com/albums/ac150/madjackghengis/_0031-10.jpga new flame eater, just to be different
And here is the last run of the engine, with the check ball, and everything completed except its own burner, which will probably be modelled after John's butane burner from his flame eater, as I like the clean burning and the ability to adjust the flame and thus the speed.  I hope you all enjoyed this as much as I have.  :nrocks: :ddb: :beer:  Cheers, Jack
« Reply #18 on: April 06, 2011, 12:47:43 PM »
Hi Chuck, the beauty of the tangential tool is the ease of grinding, just straight in, at an angle to form a diamond shape, and then I lap the end on a diamond hone, just until there is enough for two edges, and touch up the two sides, and the intersecting corner which is a small radius after numerous lappings.  I just stone the top face when changing metals, or when I see some build up in the edge.  Any dullness showing up means hitting the grinder and lapping the top again.  It's one of my favorite tool holders.  Jack
« Reply #19 on: April 06, 2011, 12:55:44 PM »
That is a real stunner Jack, very well done indeed.  :clap: :clap: :clap:
I am wondering why my one wasn't fed under the block rather than from the top, it would have saved a lot of hassle.
You seem to be able to get them done a lot quicker than me, I am only half way thru the flywheel bling, weeks still to go yet.
« Reply #20 on: April 06, 2011, 01:10:31 PM »
Just beutifull.  :bugeye: :bugeye: :thumbup:
« Reply #21 on: April 06, 2011, 03:35:21 PM »
Great to see it running Jack.  :clap: :clap:
So quickly too!  :thumbup:
Well done......  :bow: :bow:
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #22 on: April 06, 2011, 03:58:44 PM »
That's a real nice runner there Jack :clap: :clap: :thumbup: :thumbup:
Tim
« Reply #23 on: April 06, 2011, 08:50:04 PM »
Thanks very much for watching and the comments.  The posting is a bit deceptive, I've been working on it for some time, I've just not have time post, as I've had some weeks of drs. appts. and the like, taking up all my mornings and "extra" time.  I've been working with a friend getting his custom bike fired up and broke in, thirty years collecting, three years building, and about three weeks doing the initial fixes and alterations, jetting, making things never together before, play nicely.  A lot of time supervising, with constant interuptions to do something I have to do as it's ticklish.  It's almost easier to do the "shake-down and break in" hours and miles myself.
    By the way John, it was in watching the video of your engine which inspired me to flip the valve levers, and have the valve slide up.  And Nick, you mentioned having the cam close the valve, and let the spring open the valve when the pressure rises, so I used the same concept with the slide valve as well as on the oddball.  The check ball was the reason for a thick head and it makes the engine run very smoothly and rather quietly and makes the engine warm up very quickly.  It runs at a steady 550 rpm after about a minute of running.  I rinse the cylinder with WD-40 before starting, drying the outside, and spinning the liquid out of the cylinder, then set it down, light the burner and spin it over.  I believe I can reduce the cleaning if I run it off butane instead of the alki.  I just need to scale down your burner to fit the port.  You've all been an inspiration to my experimenting and provide lots of food for thought. :nrocks: :beer:  Cheers, Jack
« Reply #24 on: April 07, 2011, 01:30:54 AM »
Great Job Jack  :clap: :clap: :clap: :clap: :clap:
And a real smashing runner
I learnt a lot from following your thread thanks for showing.  :nrocks:
