Author Topic: SABB valve job  (Read 43021 times)
Re: SABB valve job
« Reply #25 on: April 27, 2011, 08:28:35 PM »
Nice fix! Glad you got it done.
Why you moving shop?
Re: SABB valve job
« Reply #26 on: April 27, 2011, 09:45:29 PM »
Well that's a new one on me!  :borg:
Reading your post you said you were aiming for a thou over the insert size? Surely a thou under was the aim?
Still, all's well that ends well  :thumbup:
Only one cracked insert too.... not too bad  :clap:
Hope it runs well once he re-builds it.... Still think that was a seized water tap on the side?
Re: SABB valve job
« Reply #27 on: April 28, 2011, 08:13:47 AM »
HI well dun yep the tool is yours to keep   regards bob
Re: SABB valve job
« Reply #28 on: April 28, 2011, 10:34:27 AM »
Bob - phew! And thanks; again, I couldn't have done it without that tool.  :thumbup:
Ralph - I the +1 thou was to allow me to get the seat in the hole; that was only in the test ali piece. I realise I forgot to mention in the main writeup that I re-cut the second diameter to the seat diameter exactly, so it fit nice & snug.
Eric - The shop I'm in now, at 4000sq/ft, has become too expensive, what with the rent, taxes, and electric. So, I'm downsizing into a 1250sq/ft unit instead. The racing cars and most of the other car stuff is going to another lockup in Wales. The combined rent + rates of the 2 new places is still nearly £4,000 per year cheaper than the rent alone at the place I'm leaving; so cost wise it's a much better prospect.
Fortunately, I've still got a decent sized space allocated to the machines, but I'm not sure yet how to lay them out.... that's the subject of another question, which I'm about to post on a separate thread...
