Author Topic: Small fixed steady  (Read 13409 times)
Small fixed steady
« on: March 10, 2011, 03:48:37 AM »
I've been asked by a fellow model engineer if I could help out with a tricky bit of machining that he just doesn't have the kit for. Its a long slender 5/32 screw cut butress thread, that needs a fixed steady to make.
The fixed steadies you get suplied with most lathes are far too big for small slender jobs, so I decided to make my own, I've seen this design someware before so its not mine just my interpretation on it.
This is it quite simple realy.
http://i431.photobucket.com/albums/qq32/sbwhart/Modmodder/100_4965.jpgSmall fixed steady
It just clamps to the running centre, this is how you use it.
http://i431.photobucket.com/albums/qq32/sbwhart/Modmodder/100_4971.jpgSmall fixed steady
I'll post a few more pics when I cut the thread, fingers crossed.  :ddb:
Offline tomrux
Re: Small fixed steady
« Reply #1 on: March 10, 2011, 04:35:40 AM »
what a bril idea.
if you made it with 2 fingers and put a small bearing on each.
definately on my list.
dont have any steadies at all. dont see me needing much more than this
Tom
« Reply #2 on: March 10, 2011, 04:52:32 AM »
Hi Tom
To get the best use out of it you need to make yourself one of these,
http://madmodder.net/index.php?topic=1208.0
http://madmodder.net/index.php?topic=1239.0
Fitting bearings would be a Rolls Royce job not sure if it would work any better though.
« Reply #3 on: March 10, 2011, 07:04:13 AM »
Just completed screw cutting the butress thread with the steady worked like a dream.
http://i431.photobucket.com/albums/qq32/sbwhart/Modmodder/100_4978.jpgSmall fixed steady
And just to show it wasn't a fluke
http://i431.photobucket.com/albums/qq32/sbwhart/Modmodder/100_4979.jpgSmall fixed steady
Made a few extra.
As I had to under cut the rod for tool run out I'm going to cut the threaded part off turn a small spiggot on it and join it back onto the main rod with silver solder.
« Reply #4 on: March 10, 2011, 08:19:40 AM »
Oohhh.....  STEW!  :bugeye:
I really, really like that.  :thumbup:
Blummin well done!  :clap: :clap:
Offline DICKEYBIRD
  • Collierville, TN ya'll
« Reply #5 on: March 10, 2011, 09:15:32 AM »
I like that one; a great idea!  I need to make one of your little centers too. :beer:
I cobbled up this rig a couple weekends ago when I needed a couple feet of 5/16" aluminum rod and the only thing I could find on a Sunday was 3/8".  I mounted a scrap of 1/2" HDME onto the carriage with a bit of steel angle, drilled & reamed a 3/8" hole in the plastic with the drill & reamer mounted in the chuck and voila!  Cheap & cheerful follow rest.  I switched to a sharp HSS bit after the pic because the carbide bit caused too much deflection to make the .063" cut on a single pass.
http://i57.photobucket.com/albums/g227/DBAviation/FollowRest.jpgSmall fixed steady
Milton in Tennesee
« Reply #6 on: March 10, 2011, 10:03:58 AM »
Nice bit of fixing there Mr Bird, that ones filed away.
Offline arnoldb
  • Windhoek, Namibia
« Reply #7 on: March 10, 2011, 10:42:48 AM »
Nice one Stew  :thumbup:
And good threads as well  :clap: - how were the nuts done ?
 :beer:, Arnold
« Reply #8 on: March 10, 2011, 11:16:15 AM »
Nice work, I like it.  :thumbup:
« Reply #9 on: March 10, 2011, 12:17:34 PM »
Thanks Chaps
Arnold I made a tap like this
http://madmodder.net/index.php?topic=4384.0
« Reply #10 on: March 10, 2011, 01:24:41 PM »
My old Drummond lathe has a steady that you put wooden blocks in to support the workpiece. Just clamp in a block or two and drill it out to fit the work.  Such a simple idea, fits any size and would not mark the work (I assume).
