Author Topic: Potty Over Crank Wall Engine  (Read 379112 times)
Re: Potty Over Crank Wall Engine
« Reply #250 on: June 09, 2011, 08:29:12 AM »
Thanks Guys  not much more to do now before we will be putting it all together.
Had a bit of disaster with the paint the base came out great but the cylinders needed a bit more of a spray, and the re-spray came out all crinkly, I then did what I should have done first and read the instruction on the can, it said :-Respray before 6 hours or after 36 hrs or it will go crinkly  :bang:
Real Men don't read instructions they just live with the consequences.
:D
So I've had to rub things down and start again.
Finished off the stop valve.
I made the valve gland and the bridge from the same bit of brass.
First turned up the OD and the step fro the gland.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0384.jpgPotty Over Crank Wall Engine
Then over onto the mill using the PCD function drilled the four clamp holes taking them deep enough to get the bridge made.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0383.jpgPotty Over Crank Wall Engine
Part the gland off, then turn the bridge and part off
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0385.jpgPotty Over Crank Wall Engine
Then milled off two opposite holes to complete the bridge.
The valve stem is made in steps if you chuck grips reasonably concentric you can do it this way as it will tolerate a little eccentricity between the threads, but it is important that the cone is concentric with the main body.
So first turn and thread M2 on the end and transfer it over to the spin indexer and mill a 2.5mm square for a length of 3mm.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0392.jpgPotty Over Crank Wall Engine
Then back onto the lathe and with just enough sticking out turn and thread M4.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0393.jpgPotty Over Crank Wall Engine
Pull some more stock out and turn the main body 5mm dia, then slew the compound over and turn the cone until it drops off the bar, the cone will be perfectly concentric to the body.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0399.jpgPotty Over Crank Wall Engine
The bridge posts are one of those small jobs that you have to machine in the correct sequence or you end up with little to grip on.
So first job mill a hex part way along the bar, I used both ends of the bar, her it is with one end just with the hex and the other with the M2.5 thread and plain bit turned on the other end.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0402.jpgPotty Over Crank Wall Engine
Her are the part finished pair, it was a simple job the grip on the plain bit and turn and thread M2.5 taking care to get the length between the threads the same on the pair.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0408.jpgPotty Over Crank Wall Engine
Now for the hand wheel, I've shown this a few times so I'll just show a few shots.
Turn up the wheel
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0410.jpgPotty Over Crank Wall Engine
Transfer over to the RT still in the chuck, centre the RT under the mill spindle and using a combination of the DRO PCD function and movement from the RT generate the wheel.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0411.jpgPotty Over Crank Wall Engine
And her we have the completed valve on the steam chest cover with the butterfly valve.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0414.jpgPotty Over Crank Wall Engine
I've had it connected to the air and it shut off nicely with no leaks, it gives some controll reduceing the angle of the cone would have given a bit more but I've enough for my purposes.
« Reply #251 on: June 09, 2011, 09:00:01 AM »
what a beauty valve!  :thumbup:
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #252 on: June 09, 2011, 09:15:01 AM »
Now that really looks the part  :clap: :clap: :clap: A lovely piece of workmanship.
Tim
« Reply #253 on: June 09, 2011, 12:16:27 PM »
Good work, very nicw  :clap: :clap:
« Reply #254 on: June 10, 2011, 11:31:55 AM »
Cheers Guys
On the home strech now.
To days job the oilers for the crank bearings, as this is a vertical engine, the oilers need to have a 90 deg elbow.
Start by drilling a two lengths of 14mm brass bar bar all the way through 3/8*32 ME tapping and tap each end about 8mm deep.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0419.jpgPotty Over Crank Wall Engine
Then drill a 8mm hole across the middle of each bar, then cut them in half.
Drill the next bit part way through 2mm, thread the end for 12mm M4.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0423.jpgPotty Over Crank Wall Engine
You end up with this kit of parts for silver soldering together.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0424.jpgPotty Over Crank Wall Engine
Turn up some caps.
And you have your oilers.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0426.jpgPotty Over Crank Wall Engine
« Reply #255 on: June 10, 2011, 12:04:28 PM »
Very nice indeed
« Reply #256 on: June 11, 2011, 01:18:23 AM »
Thanks John
Well finaly her are the drawings for the governor.
« Last Edit: June 11, 2011, 01:23:22 AM by sbwhart »
« Reply #257 on: June 11, 2011, 11:46:24 AM »
Slowly assembling the engine, could resist a how's it looking shot
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Over%20Crank%20Wall%20Engine/131_0430.jpgPotty Over Crank Wall Engine
Now isn't that tasty.
Offline arnoldb
  • Windhoek, Namibia
« Reply #258 on: June 11, 2011, 12:58:56 PM »
 :drool: Tasty  - DEFINITELY  :thumbup: - Some serious eye candy that Stew  :bow: - can't wait to see it all done and running  :D :D
Kind regards, Arnold
Offline cfellows
« Reply #259 on: June 11, 2011, 01:46:28 PM »
Very nice stew.  Hoping for some nice pictures and a video once you have it all back together.
Chuck
« Reply #260 on: June 11, 2011, 02:15:53 PM »
Gor-jus!
« Reply #261 on: June 11, 2011, 02:24:34 PM »
Lookin' great Stew.  :drool:
Looks like a museum piece to me.  :thumbup:  :bow:
« Reply #262 on: June 11, 2011, 07:44:02 PM »
 :jaw: :jaw: :jaw: :jaw: :jaw:
 :bow: :bow: :bow: :bow: :bow:
I haven't looked in on this in awhile... OMG. that looks amazing.
Offline KB3RLJ
« Reply #263 on: June 11, 2011, 08:10:58 PM »
Omg! First time I've looked at this thread. That's beautiful. Is there a prototype for it or your own design? Are you planning to drive something with it?
« Reply #264 on: June 12, 2011, 01:11:46 AM »
Well thank you all for your kind comments.
I can't wait to get the wall built for the finished engine.
KB3RLJ (is that a car reg  :scratch:)  If you look on page one of the thread there is a picture of the prototype, its on display at Quarry Bank Mill Style Cheshire (try googling it for more info) I contacted the museum for information on the engine and all they could tell me was that it was a "steam engine"  :loco:  I drew it up from photographs, the model is about 1/3 full size, if you read back through the thread you will find that I've attached drawings for you to down load. I have no plans to drive anything with it, I only intend to run it on air, the pasageways are too narrow for steam running.
Thanks for your interest.
« Reply #265 on: June 12, 2011, 01:27:43 AM »
Hi Stew, your also an early bird I`ve noticed!
It is looking really great, can`t wait to see it finished. Spot on so far!
Offline HS93
« Reply #266 on: June 12, 2011, 03:11:49 AM »
Radio Ham I think Stew.
Peter
G0PAH
Offline KB3RLJ
« Reply #267 on: June 12, 2011, 05:46:57 PM »
Yes, its my ham call sign. I was on my iphone and didn't have time to go back and read the whole thread. I'll do it now. Georgous engine.
Brian
« Reply #268 on: June 12, 2011, 05:52:35 PM »
I had the pleasure of watching this engine run at Harrogate (in the back of a car)
I can assure you it runs as well as it looks
That valve is a work of art in its self
« Reply #269 on: June 12, 2011, 06:33:12 PM »
Voltswagen ??
John S.
« Reply #270 on: June 12, 2011, 06:47:12 PM »
Voltswagen ??
John S.
Didn't know they made electric ones!
« Reply #271 on: June 12, 2011, 06:48:34 PM »
I think it was
Hatch back anyway
Rob Wilson was there he would remember
« Reply #272 on: June 12, 2011, 07:22:37 PM »
Engine in the back ? Voltswagen ?
Oh forget it that was wasted.....................
« Reply #273 on: June 12, 2011, 07:29:03 PM »
Very good for a monday morning  :D :D :D :D got me anyway  :) :) :) :)
Offline BiggerHammer
« Reply #274 on: June 12, 2011, 09:30:31 PM »
LOL! Got me too.
