Author Topic: Potty Over Crank Wall Engine  (Read 249167 times)
Re: Potty Over Crank Wall Engine
« Reply #125 on: March 25, 2011, 09:34:18 AM »
You are doing very well, I am very glad that you are showing us this wundefull engine.  :thumbup:
Offline shoey51
« Reply #126 on: March 25, 2011, 11:43:03 PM »
wat to go Stew lovely engine :thumbup:
cheers Graham
« Reply #127 on: March 26, 2011, 05:49:05 AM »
That's going to be a hell of a wall clock driver   :jaw:    :lol:
I bet you can't wait to see this ticking over Stew?
I could not see the detail properly in you photo's cause they are small.... Maybe mine are just too large again?  Anywho, I don't know if any of you out there know this but....
(on vista at least)
If you hold CTRL down and then press the + button it magnifies the whole screen text and pic's included. Then CTRL and the - button and it goes back.  I just count the number of +'s I  hit and return back to the normal screen with the same amount of -'s .  Just a thought?   :borg:
Clad to see you got rid of than bodge in the re-sizer too  :headbang:
Very nice work Stew  :thumbup:
Offline BiggerHammer
« Reply #128 on: March 26, 2011, 09:18:17 AM »
That is looking very nice. Can't wait to see it go.
Offline arnoldb
  • Country: na
  • Windhoek, Namibia
« Reply #129 on: March 26, 2011, 10:40:31 AM »
It looks great all assembled like that Stew  :clap:
Can't wait to see it finished  :thumbup:
Kind regards, Arnold
« Reply #130 on: March 28, 2011, 12:10:50 PM »
 :bugeye:  WOW Stew
you have really made  great progress with the engine since i last looked ,,, she is looking great  :clap: :clap: :clap: :clap: :clap:
« Reply #131 on: March 31, 2011, 07:23:21 AM »
Thanks for your support and interest Guys.
It's starting to assemble up nicely.
Next up the slide bar bearings.
This is what I'm making them from
Spent a bit of time measuring up the assembly to check the size to make them to. The inner bearings are different to the outer, when I was drawing the engine up I couldn't see how to line up and fix the inner bearings, so left the ? hanging now that i've got a few bits around me the solution is quite simple just screw them to the bearing housing with a counter sunk cap screw, I can get alignment by ensuring I drill the hole for the cap screw central, and drilling the housing on the same centre line as the bearing, the outer bearing will be tapped with four M2.5 threads and will be bolted to the outer housing
Milled the bearings up in pairs.
Drill and counter sink the inner bearings
Next up the slide valve attachment made from a bit of square mild steel bar, faced off and tapped and parted off in the lathe, then milled and drilled using my little vice.
This is where they go.
Then with them fitted measured up the eccentric straps for the forks.
The fork were made from some round brass bar with flats milled and the fork cut with a 3 mm slot drill.
Next using the method John showed us but solder the fork to the strap.
This is how they fit.
And how the assembly is looking.
I've got to strip it all down now and drill the bearing housing for the slide bar bearings and I need to modify the crank a little so that the fly wheel fits.
I'll be more or less ready them to try it out:- fingers crossed.
« Reply #132 on: March 31, 2011, 10:08:25 AM »
Amazing it's so fine engine you are making :bugeye: :bugeye: :bugeye:
« Reply #133 on: March 31, 2011, 07:38:16 PM »
That really is a good looking machine your building Stew  :bow:
I'm really going to have to try to remember many of these techniques!  :scratch:
Very nice.
« Reply #134 on: April 04, 2011, 07:03:19 AM »
Well its a runner a video is on its way,
Grinning Stew
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #135 on: April 04, 2011, 07:34:37 AM »
Well done that man :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:, cant wait for the video :mmr:
« Reply #136 on: April 04, 2011, 07:50:52 AM »
Here we go
« Reply #137 on: April 04, 2011, 07:56:06 AM »
This was something, so cool and I love the sound.  :bugeye: :bugeye: :bugeye: :bugeye: :clap: :clap: :thumbup: :thumbup: :thumbup:
« Reply #138 on: April 04, 2011, 08:50:17 AM »
Stew,
WOW :jaw: :bugeye: :jaw: :bugeye:
Sounds just like "I think I can, I think I can"
Oh, forgot to add a few of  :ddb:  :ddb:  :ddb:  :ddb:  :ddb:  :ddb:  :ddb:
« Reply #139 on: April 04, 2011, 08:57:19 AM »
That really is great Stew, I can't wait to see it in person.
I bet the chaps at the museum would be well pleased to see it as well.
Wonderful work.
Offline spuddevans
    • My Photo website
« Reply #140 on: April 04, 2011, 09:11:28 AM »
That has a beautiful movement  :clap: :clap: :clap:
A lovely slow runner too.
Have a few nana's
 :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb:
Tim
« Reply #141 on: April 04, 2011, 09:30:31 AM »
 :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: CRACKING Stew ,,,,,,,,,Crackin  :clap: :clap: :clap: :clap: :clap: :)
Offline Gerhard Olivier
« Reply #142 on: April 04, 2011, 10:13:13 AM »
That is a GREAT engin Stew
Fantastic love the sound in slow-go
Gerhard
Guernsey
Channel Islands
« Reply #143 on: April 04, 2011, 10:31:11 AM »
VERY NICE! Love that sound when it is at the lower rpms.
« Reply #144 on: April 04, 2011, 10:48:07 AM »
Hi Stew
NICE ENGINE     :clap:  :clap:
Unusual layout, very interesting to watch..
It's much bigger than I thought, you going to run it on steam?
How fast is it intended to run?
Dave BC
Offline HS93
« Reply #145 on: April 04, 2011, 11:24:19 AM »
very nice  :bow:
                      :ddb:  :ddb: Peter  :ddb:  :ddb:
        :nrocks:
« Reply #146 on: April 04, 2011, 12:04:51 PM »
Thanks for all your kind comments Guys.
I was that pleased at getting it running I forgot to show how I cut back the crank
Set it up in the lathe using the fixed steady
Clocked it up.
Cut the shoulder back and faced the length back, taking small cuts with a sharp tool worked a treat.
To get the guide bar bearings on centre measured the centre line of the crank and checked piston rod was on the same centre line.
Then as I'd milled the bars concentric drill the fixing holes in the bearing housing so that the guide bar bearing come onto the centre line, this sounds as clear as mud, but I'm sure you can work it out.
Worked out well
Now that I've got the engine running I want to spend a little time doing a few other jobs before I pic it up again and make the fly ball governor and tart it up for painting fit oiler and make a proper base thinking of mounting it vertical are the original.
Thanks again
« Last Edit: April 05, 2011, 05:12:46 AM by sbwhart »
Offline cfellows
« Reply #147 on: April 04, 2011, 12:15:22 PM »
Very nice!  I love the sound at slow speed.  It's one of the few, 2 cylinder, double acting model steam engines I've seen where you can hear all 4 individual strokes.  Simply lovely.
Chuck
« Reply #148 on: April 04, 2011, 12:41:41 PM »
Stew...  :thumbup:
Love it! Sounds great and wasn't expecting the thunder at the end  :bugeye: Had the speakers up!!  :headbang:
Offline arnoldb
  • Country: na
  • Windhoek, Namibia
« Reply #149 on: April 04, 2011, 12:50:02 PM »
 :D Great runner Stew  :clap: and a top job  :thumbup:
Just love the sound !
