Author Topic: Chainsaw / Strimmer / Mini Moto Engine Ignition  (Read 43740 times)
Re: Chainsaw / Strimmer / Mini Moto Engine Ignition
« Reply #25 on: February 19, 2011, 08:07:33 AM »
Oh yeah, of course, didn't think of that!  :wack:
MrFluffy
« Reply #26 on: March 16, 2011, 08:04:33 AM »
The gaps critical to low rpm running, so maybe there are some gains to be had tinkering with magnet->coil clearance there to be had. I know my cement mixer has the same system and that goes down into the hundreds of rpm when its working against a full (overfilled...) drum of mix, poor thing...
Nick, I just stripped down a old ducati 2stroke off a rotovator (see other thread, making a die filer from a small IC engine :D ) , and it has a induced coil power mag type ignition like above, except it has the triggering done by points, and a points baseplate and removeable cam which keys to the crank.
Do you want it for post costs? I can saw the magnet out the flywheel easy enough and put it in a box and post it or it can go back to the UK with a relative in someones boot to keep postage down.
