Author Topic: The size of drill?  (Read 12200 times)
The size of drill?
« on: January 10, 2011, 02:38:13 PM »
Hi, I need to know, how big must I drill for threading a 5-40 tapp?
I found this:
  TAP    Decimal Drill Size
4-40     .0860
4-48     .0935
5-40     .0980
Do you think that this is right?  :smart:
Offline Jasonb
Re: The size of drill?
« Reply #1 on: January 10, 2011, 02:49:05 PM »
that may be a bit on teh tight side, for most things you don't need such a full thread engagement, try a #43 drill which is 0.089"
Jason
« Reply #2 on: January 10, 2011, 03:51:11 PM »
Thanks Jasonb   :thumbup:
Where can I find a tabel for all of those drills and tabs. I am use to mm so this is hard for me. :doh:
Offline mklotz
  • LA, CA, USA
« Reply #3 on: January 10, 2011, 04:15:49 PM »
Diameter of numbered screws = 0.060 + 0.013*N where N is the screw number.  Thus for a #5...
Diameter = 0.060 + 0.013*5 = 0.125
Tap drill size for 77% depth of thread = major diameter - 1/tpi = 0.125 - 1/40 = 0.1"
For other percentages of depth of thread
Tap drill size = major diameter - 0.013*dot/tpi
where dot = depth of thread expressed as percentage.
Regards, Marv
Home Shop Freeware
« Reply #4 on: January 10, 2011, 05:09:39 PM »
Thank you, but I am not sure that I am a wize man for that  :doh:
However I found this page http://www.csgnetwork.com/drillsizeconvert.html så I know a bit what it is.
It's so hard to try to do somthing from a US-plan, you have inc, you have your fanny number(#40) iver you're plan is diffrent. It's like learning a new language, but I am stupid enough so I continue. I can always learn somthing new, or just change som words with some new friends.  :wave:
Offline ieezitin
« Reply #5 on: January 10, 2011, 06:58:50 PM »
Saw
When I am not sure I Use the .9742 ratio. It’s not dead balls on like shown on all the charts, but a few 10ths of a thou don’t bother me that much.  It certainly works.
Divide .9742 by the thread pitch. Next subtract your answer from the tap diameter this will give you the tap pilot drill size.
Example. ¼-20 bolt.
Divide  .9742 by the pitch 20 and you get .0487 Now subtract .0487 from the diameter of the tap .250 You get .20129 this is your drill size. Remember stainless, cast, aluminum are percentage slightly different, so apply as necessary.   This will always get you in the ball park.
Hope this helps.   Anthony.
Offline mklotz
  • LA, CA, USA
« Reply #6 on: January 10, 2011, 07:04:00 PM »
.9742/0.013 = 75%
so that is the rule I showed but adjusted for 75% depth of thread rather than the 77% one gets using "1" in place of "0.9742"
Regards, Marv
Home Shop Freeware
« Reply #7 on: January 10, 2011, 07:24:07 PM »
i Saw,
Here's another table, showing the metric tap drill size as 2.65mm for 5-40 UNC: http://mdmetric.com/tech/thddat9.htm#uc
That just leaves you with the problem of finding a 2.65mm drill.
Offline kvom
« Reply #8 on: January 11, 2011, 07:24:48 AM »
My drill index box has the tap/body drill sizes for most common imperial threads written on the box lid.  Very useful.
« Reply #9 on: January 11, 2011, 10:08:12 AM »
Thanks folks no I think I kan manage it.  :thumbup:
Offline Jasonb
« Reply #10 on: January 11, 2011, 11:38:56 AM »
Just read your post again and I gave the size for 4-40,the first on your list of 3, was a bit early in the morning.
This site has a lot of thread sizes and the tapping drills are in metric
http://www.gewinde-normen.de/en/index.html
J
« Reply #11 on: January 11, 2011, 12:09:22 PM »
Thanks Jasonb
Benni,  Take a look at the document titled Pilot Hole Considerations posted at http://www.scribd.com/Lew%20Merrick.  It will probably tell you more than you ever wanted to know on the subject.  There is also a document titled UN Thread Data Chart that covers the Unified National (American standard inch-based) screw threads in fair detail.
