Author Topic: If You Own A Mill, You Need To Make These  (Read 14032 times)
Offline matthew_g
« on: December 06, 2010, 04:16:15 AM »
Thought this might interest some of you fellas.
I was as usual all over the world tonight looking at all things engineering and came accross this little invention, Very very handy.
Ima off to make a couple now.   :clap:
http://rick.sparber.org/Articles/tn.pdf
I never enter a battle of wit with an unarmed person
Re: If You Own A Mill, You Need To Make These
« Reply #1 on: December 06, 2010, 06:02:14 AM »
Matthew.
Good thinking!  :thumbup:
Already got 'em in my aluminium greenhouse frame. Never thought of adapting the idea for mill!  :doh:
There's allus summat else to make.......  ::)
Offline maybecnc
« Reply #2 on: December 06, 2010, 08:10:18 AM »
Is is used since long on industry:
also as studs:
« Last Edit: December 06, 2010, 08:20:14 AM by maybecnc »
Latest project: Modifying chucks for front monting  http://www.toolsandmods.com/mini-lathe-chuck-backplate.html
Offline matthew_g
« Reply #3 on: December 09, 2010, 03:30:18 AM »
I like the idea of using them as studs.
« Reply #4 on: December 09, 2010, 07:32:23 AM »
Not so sure if it really is a good idea.  There will be situations where you aren't getting complete support from these things.  If you're going to make T bolts (or nuts) it would be better to go for making the proper size in the stard shape.  After all,  how many different T slots do you have in the average workshop ?
Offline kwackers
« Reply #5 on: December 09, 2010, 07:45:47 AM »
I've some of these - the beauty of them is when you've already set something up but decide you another bolt might be a good idea but there's no way to slide another t-nut along without unbolting something already in place and upsetting stuff.
This is particularly true if you tend to leave a vice and RT on the table...
In essence they're emergency T-nuts.
« Reply #6 on: December 09, 2010, 08:14:53 AM »
And in emergency...... VERY welcome, as every little helps!  :thumbup:
« Reply #7 on: December 11, 2010, 03:24:30 AM »
Great idea!  I might make some of those studs. :thumbup:
I actually hate T nuts as I am afraid I will screw the bolt down too far and jack off a chunk of my machine table. :coffee:
Offline matthew_g
« Reply #8 on: December 11, 2010, 04:35:05 AM »
I have burred the last 2 threads on all my "T" nuts to prevent busting my table up..Just a thought, It has worked for me.
Matt
« Reply #9 on: December 11, 2010, 06:06:52 AM »
It's best to use studs and not bolts or screws with T nuts. Much safer.
