Author Topic: Tiny BA fasteners/studding  (Read 15439 times)
Offline bry1975
    • http://www.satintime.co.uk
« on: November 23, 2010, 12:00:40 PM »
Hi chaps,
So do any of you know if you can still source the really tiny BA fasteners/studding with decent lengths like 20-25mm?
Am in need of tiny threaded bars to replace rivetted pins on watch bracelets!  :(
Tar
Bry
Re: Tiny BA fasteners/studding
« Reply #1 on: November 23, 2010, 12:05:15 PM »
hi Bry
Try These www.modelfixings.co.uk/index2.htm
Or These  www.fastfixdirect.co.uk/
Hope this helps
Offline Jasonb
« Reply #2 on: November 23, 2010, 12:13:24 PM »
EKP make the fixings that most of the other ME suppliers sell.
What size BA are you calling tiny?
http://www.ekpsupplies.co.uk/index.php?act=viewCat&catId=1
Jason
Offline bry1975
« Reply #3 on: November 23, 2010, 12:18:37 PM »
Kool!
Tiny so probaby 14 or 16 BA.
That's the painful part I need to remove the peened pin to the far left will then be able to have the parts coated separately.  Hopefully can use a tiny BA fastener to reassemble the 1000 Euro bracelet can't afford any F ups with this job.
http://img189.imageshack.us/img189/5333/bbrr.jpgTiny BA fasteners/studding
http://img259.imageshack.us/img259/2450/brev.jpgTiny BA fasteners/studding
« Last Edit: November 23, 2010, 12:34:38 PM by bry1975 »
« Reply #4 on: November 23, 2010, 12:35:50 PM »
If you are after studding, the smaller you go, the more expensive it gets, if available at all. It is much cheaper to make yourself.
For small ones, I first get the thread started and thru the die, then I hold the first bit of thread produced in a pin chuck, or pin vice, held in the chuck of a battery drill, and wind it thru, drill running in reverse from the back of the die. You can easily make a 6" length in whatever material you require in less than a couple of minutes.
Offline bry1975
« Reply #5 on: November 23, 2010, 12:59:42 PM »
Thanks Bogs,
Yep I've been contemplating making my own just wanted to look at all options.
http://www.modern-screws.co.uk/
Sizes found hopefully I can find a suitable nut type that doesn't look to chunky.
« Last Edit: November 23, 2010, 01:07:49 PM by bry1975 »
« Reply #6 on: November 23, 2010, 01:41:37 PM »
Bry,
Why not just buy something like 1/32" copper snap head rivets, or brass escutcheon nails (in fact I still think I have some of them knocking about from my model boat days), and fit them like shown in the C-o-C below. You could even get them plated to match. Once assembled with loctite, they should never move.
Offline bry1975
« Reply #7 on: November 23, 2010, 01:48:12 PM »
Thanks for the rivet idea Bogs I hadn't thought about that must be my young age (34)  :D
Probably have them DLC'D if it's possible.
Offline Jere
    • Adventures in Watchmaking
« Reply #8 on: November 24, 2010, 08:37:52 AM »
I wasn't sure what you needed/wanted to do exactly, but you may be able to replace the pin with parts intended for the job.
I'd browse around here a bit before I made any final decisions.
http://www.cousinsuk.com/catalog/10/0/664.aspx
best of luck,
Jere
"If only I had known, I should have become a watchmaker."  A. Einstein
« Reply #9 on: November 24, 2010, 05:59:45 PM »
anything below 3mm is hard to see  :( :( :( :( :( :(
Offline cidrontmg
« Reply #10 on: November 24, 2010, 07:13:52 PM »
Very true.
http://i866.photobucket.com/albums/ab229/cidrontmg/Sekal/Optics.jpgTiny BA fasteners/studding
Olli
Penafiel
Portugal
