Author Topic: Solenoid engine Build  (Read 109587 times)
Offline foozer
  • Camano Island WA
Re: Solenoid engine Build
« Reply #50 on: July 15, 2011, 02:19:14 AM »
Ages ago helped the boy build a gadget similar for his school science project. Do 'member timing was fun. Energized the coil and let it lock the piston in place. Used that to set rod length so crank was at the qtr over position (90 with BDC as 0) We set the switch to energize coil a tad after BDC  and release before crank reached the 90 degree point. Was a simple gizmo and IIRC it ran the best with just the tiniest bump of juice to the coil.
Robert
Offline cfellows
« Reply #51 on: July 15, 2011, 11:03:45 AM »
Al, I think I see what you are trying to do.  I saw a similar magnetic engine in an old Popular Mechanics (or Popular Science) magazine.  It can be done if your piston (plunger) is exactly at the half way point through the coil when the crankshaft is at 90 degrees and 270 degrees.  In other words, at top dead center and bottom dead center,  the piston must be past the center of the coil by an equal amount.  The coil coil should be energized at both top dead center and bottom dead center, then turned off when the piston is close to the center of the coil in either direction.
I doubt this form of double acting piston really gains anything in speed or efficiency over a single acting piston which is energized for the full stroke with the piston travel reaching the center of the coil at or before top dead center.
Chuck
« Reply #52 on: July 15, 2011, 01:31:46 PM »
My 2ยข Al, I think you'll need two selenoids to make it work. I'll try to get a C-of-C together and post it later.
Offline foozer
  • Camano Island WA
« Reply #53 on: July 15, 2011, 02:50:30 PM »
One thing that I haven't seen in this build and have assumed you've tested it.
When you energize the coil does it center the piston in the bore or draw it to one end, shape seems to indicate that it pulls the piston all the way to the end of the stroke. If thats the case dont think a double action will fly. A pulse of juice at any point from BDC to TDC for a duration of just a few degrees should get it going
Offline CallMeAl
« Reply #54 on: July 17, 2011, 03:20:20 PM »
Well I finally got it to run! :ddb:
Today I did some more fiddling with the eccentric timing, bump cams positioning, and the piston rod length on the cross head and what do you know it started running.
I guess I wasn't so crazy after all and with all the encouragement to not give up on this from the members of Mad Modder I accomplished what I hoped.
You can have a double acting solenoid if you position the armature correctly when the electrical pule is applied.  Since the solenoid works by drawing a iron armature in to the center of the coils magnetic field, if you do that at the same position at each end if the coil and time your switch correctly the coil should pull in on the armature from each end on the coil.
http://i61.photobucket.com/albums/h49/apowellx/Sol%20engine/Doubleactingsolenoid.jpgSolenoid engine Build
This switching has to be done just after TDC and BDC as several posters mentioned. Part of my problem was I was timed to actuate the switches a both ends of the stroke just prior to those points. You can get away with that on a IC engine because you're compressing a gas but not on a solenoid!
Another thing that was causing me grief was the solenoid I chose to use has a very narrow coil width since a hydraulic vale spool only needs to travel about .250 to .375 inch so it only needs to pull the armature that distance and it is spring offset the other direction.  Here is cross section off the solenoid I used.
http://i61.photobucket.com/albums/h49/apowellx/Sol%20engine/solenoid.jpgSolenoid engine Build
I believe this made the setting of the timing more critical since my total stroke is 1.500 inches.  Also, a rotatory cam would probably be better than my bum cams since you could better control the on time of the coil for more power.
Anyway, thanks for all the replies, suggestions, and encouragement. :bow:  I probably would have given up on it.  It's still not completely finished.  I want make wood base, mount a on/off switch, and fix the wobble in the flywheel among other things.
Also, I don't need the governor - it doesn't run that fast. ::) The coil heats up quite fast so running time may only be about 3 - 4 minutes.
Here is a video of actually running:
I skin cats my own way!
« Reply #55 on: July 17, 2011, 03:45:25 PM »
Yay!! ....... That's Great Al!!  :ddb::ddb::ddb:
It even sounds right!  :thumbup:
Blummin well done!  :clap: :clap:
Offline foozer
  • Camano Island WA
« Reply #56 on: July 17, 2011, 04:42:57 PM »
Cool!!  now thats a runner
Robert
« Reply #57 on: July 17, 2011, 04:48:08 PM »
Excellent! Great sound too! :ddb: :ddb: :ddb: :ddb: :ddb:
So this is with AC?  Did you have to take a piece out of the end of the bore?
« Reply #58 on: July 17, 2011, 05:26:04 PM »
 :bow: :bow: :bow: :bow: :bow: :bow: :bow: Way to go  Al  :ddb: :ddb: :ddb: :ddb: :clap: :clap: :clap: :clap:
Just new you would sort it  :zap:
Rob  :)
« Reply #59 on: July 17, 2011, 06:02:17 PM »
Al,
 :bow: :bow: :bow:
Absolutely Fantastic
« Reply #60 on: July 17, 2011, 07:40:47 PM »
Very nice Al to see her running finally.  :thumbup:
Offline SPiN Racing
« Reply #61 on: July 17, 2011, 09:01:06 PM »
Awesome!! Glad to see and hear it chugging away!
 :headbang:
SPiN Racing
Offline winklmj
« Reply #62 on: July 18, 2011, 11:40:50 AM »
 :headbang: :bow: Wonderful build.
Mike
Offline ilia-45
« Reply #63 on: July 18, 2011, 12:31:45 PM »
I love it :bow: :bow: :bow:
Awesome :drool:
« Reply #64 on: July 18, 2011, 03:18:05 PM »
Really NEAT!
Offline sjb
« Reply #65 on: July 18, 2011, 03:44:44 PM »
Great job Al  :thumbup:
Offline CallMeAl
« Reply #66 on: July 18, 2011, 11:24:28 PM »
foozer, sjb, PekkaNF, winklmj, DaveH  : Thanks for nice comments and compliments.
SPiN Racing, Bernd : No one is more impressed than me that it runs - I had given it up for dead.
Rob.Wilson : I appreciate your confidence I would drag it into life.
John Hill:  Yes AC, it's surprising what might happen when you don't know better than to try something and hope it works.  I didn't have to do anything to the core tube besides bore out the entrance to get the armature out.  There was enough length to allow the armature to get the proper overlap on the coil.
Stilldrillin: Thanks, it does sound good - an unexpected bonus!
« Reply #67 on: July 18, 2011, 11:32:18 PM »
John Hill:  Yes AC, it's surprising what might happen when you don't know better than to try something and hope it worksaNF, winklmj, DaveH  : Thanks for nice comments and compliments.
Thanks Al, that is interesting as I am presently engaged in a little research on using AC solenoids for solenoid motors.  I hope I can post my finding soon. :coffee:
« Reply #68 on: August 08, 2011, 05:18:16 AM »
Brilliant!  :thumbup:
« Reply #69 on: September 28, 2011, 12:12:46 PM »
That's really great Al, I was going to post it could easily be done with one solenoid, I seem to remember building one out of a magazine when I was a kid, and it just needs the flyweel to carry it.  I will also say they are considerably more efficient and effective double action, and that is the best switching setup I've ever seen.  The one I did had something like an armature and it wanted to move around.  What voltage are you running it on?  If it's 110 ac, you can stack two solenoids with a longer "piston", and run them in series and reduce the current in half, and get the same power with lots less heat.  DC is most efficient, but is most demanding of timing, while ac is at its most efficient if it is running at slightly below synchronous speed, and the switching is done via the alternating.  That demands setting up our of phase solenoids, and can easily become a four "pole" or solenoid, or more engine.  In any case, that is great, and perhaps the best version I've ever seen. :nrocks: :bow: :jaw: :beer:  Cheers, mad jack
Offline CallMeAl
« Reply #70 on: September 29, 2011, 11:04:52 PM »
Thanks madjackghengis, it is 110  VAC.  Since posted the video I rebuilt the crank trying take some of the wobble out without success, :bang: but it did take out some of the drag in the bearings and I redid the eccentric in steel instead of aluminum.  I also fine tuned the timing on the switching.  Now the dang thing takes of from half a turn on the flywheel and continues to build rpm till it concerns me and I pull the plug! This how I expected it would act when I first envisioned it and had planned to have it be hit and miss with a governor.  I am in the process of doing that now and hope to have it going  shortly.
