Author Topic: Removing a hex bolt that has been rounded  (Read 34352 times)
Offline Sorekiwi
Re: Removing a hex bolt that has been rounded
« Reply #25 on: November 11, 2010, 09:22:47 PM »
Now, I would have thought you'd put it in your fancy cnc controlled rotary table and cut a new hex on it!
Mike, expat Kiwi in NE Ohio, USA
« Reply #26 on: November 12, 2010, 08:12:09 AM »
HAha ... I would, but firstly it was so rounded that I`d have to take it down significantly to get a good shaped bolt on it. Secondly, I use to think people were really lazy for saying things like this but I`ve not had much shop time lately with work and such, so I`d much prefer to spend my time on one of my projects for the sake a £5 for a new one!
Offline andreas
« Reply #27 on: November 12, 2010, 11:09:56 AM »
Hmmm....Kvom said it :headbang:  I do that a lot on truck differentials and gearboxes draining screws,and sometimes it comes out by hand(make sure its cold!!!) Something you have to be careful is the ground lead,if you don`t want to mess electronics on the bike....Ground as near as possible were you going to weld. It`s also wise to remove the battery and short the terminal cables together while welding :beer:
Offline bry1975
    • http://www.satintime.co.uk
« Reply #28 on: November 12, 2010, 06:36:25 PM »
Are any of you chaps into cold heading bolts? :D
« Reply #29 on: November 12, 2010, 07:22:14 PM »
Whenever i weld on a vehicle i put a surge protector across the battery (saves blowing ecu,s)
On most modern stuff you are going to run in to trouble disconnecting the battery
