Author Topic: My 6" X 26" mill broke this weekend  (Read 35610 times)
Offline Xldevil
Re: My 6" X 26" mill broke this weekend
« Reply #25 on: April 29, 2012, 05:59:26 AM »
Hello.Wes.
Would you mind showing some pics of the change and where to set a stop?
I own the similar mill and I'm working on a riser.
Looking at the nut of the mill's knee causes me to worry.
Cheers,Ralph
Offline Powder Keg
  • Machinist Extraordinaire
« Reply #26 on: April 29, 2012, 10:57:12 PM »
Hey Ralph,
Sorry I didn't get any pictures. When you raise the table the screw also raises. If you go too high the screw will come out of the nut. You need to measure your screw and calculate how much you can travel. I would suggest buying a new screw and making one 6" longer than the original.
Good luck:o)
~Wes~
Wesley P
Offline Xldevil
« Reply #27 on: April 30, 2012, 02:39:48 AM »
Hey Ralph,
Good luck:o)
~Wes~
Hello,Wes.
I should tell you that Acme threads are not very common in Germany.
Can you tell what size it is and if it's a stub Acme thread or just an Acme?
http://www.gewinde-normen.de/en/stub-acme-thread.html
http://www.gewinde-normen.de/en/acme-thread.html
We got something similar that is called Trapezgewinde.
http://www.gewinde-normen.de/en/trapezoidal-coarse-thread.html
Due to the fact that I own a Myford and therefore an imperial lead screw,turning an Acme shouldn't be a problem in general but the necessary length will most likely bring me in to trouble.
You see,it' s not that easy to follow your suggestion.
Sometimes,buying is the better solution,but there is no seller of Acme rods around,afaik.
I think,I will change to the Trapezgewinde.
Rods and nuts are available at Maedler.
http://www.maedler.de/Category/1643/1620/2029.aspx
Anyway,thank you.
Cheers,Ralph
Offline Powder Keg
« Reply #28 on: May 01, 2012, 08:03:57 AM »
If I remember it's a 1" - 8 left handed acme. I bought mine from a big place called McMaster Carr. Here is the page. http://www.mcmaster.com/#acme-precision-lead-screws/=hce2jj I hope this helps.
~Wes~
Wesley P
