Author Topic: Sharing a little trick I discovered.  (Read 14429 times)
Offline websterz
« on: September 03, 2010, 07:49:05 PM »
Not saying I invented it, just that it came to me in a forehead slap moment.  :doh:
Centering up round stock, or finished round parts in your mill vise, can be a pain in the butt. I figured out that before I part something off from the lathe prior to milling that if I turn and part off a little extra stub the same diameter I can chuck it up in the mill with the part in the vise and center up dead nuts every time. Just a bit of gentle pressure on the quill as you maneuver the table and when it goes in you are there. I have one part that I make several dozen of on a regular basis so I just made up one of these centering nibs and keep it with the collets. Works like a charm!
 :med:
Offline andreas
Re: Sharing a little trick I discovered.
« Reply #1 on: September 04, 2010, 12:27:48 PM »
I love photos!!!....i don`t know about the rest of the guys here :D :D :D
cheers
Andreas
Offline crabsign69
« Reply #2 on: September 04, 2010, 01:17:31 PM »
 :worthless:  ya pics we love pics of the set up  thanx   :thumbup:
Offline websterz
« Reply #3 on: September 04, 2010, 04:06:52 PM »
 :bow: Sorry...I figured this one needed no visual aids.  :doh: I will get pics next time I visit the shop.
 :med:
« Reply #4 on: September 05, 2010, 08:32:29 AM »
Photo's ! ?  :scratch:   ::)
Offline crabsign69
« Reply #5 on: September 05, 2010, 01:38:37 PM »
i cant use the brain it hurts too much  :beer:  thinking is beyond what i can do so pics is what dont hurt the brain   :beer:  :thumbup:
Offline websterz
« Reply #6 on: May 13, 2011, 06:02:38 PM »
Hey...here are the pics.  Guess I kinda' forgot. :doh:
Here I have a 9/16" diameter piece of stock in the vise that needs a slot milled along its' length. I need to center the spindle for proper slot location. Rather than get out the edge finder and mess about dividing, subtracting, and all that nonsense I use my cheater. The stock in the spindle is a couple of thousandths smaller than the stock in the vise.
With the vise tightened up securely I move the table out until I can lower the spindle mounted rod between the vise jaws. Now the spindle is perfectly centered, no fuss no muss. You can do this in seconds, without a calculator or edge finder, in the dark even.
 :med:
« Reply #7 on: May 13, 2011, 06:16:50 PM »
Error showing the pictures, have you forgott something???  :lol:
Offline websterz
« Reply #8 on: May 13, 2011, 06:24:28 PM »
 :med:
Offline dickda1
« Reply #9 on: May 13, 2011, 09:20:08 PM »
Oops.  Picture does not load. :(
Dick
Skype: VladTheChemist
« Reply #10 on: May 14, 2011, 05:14:09 AM »
Websterz,
I use a similar trick using exact fitting transfer punches to pick up previously drilled holes in parts.
I suppose if you can afford sets of drill blanks, you could use those as well.
I'm usually at most, about 0.001" out, which for me is generally plenty close enough.
