Author Topic: A couple of tools I made  (Read 20600 times)
Offline grinder
« on: August 19, 2010, 12:54:27 PM »
Hi Folks,
I tried uploading a couple of pics for your comment.
I'm using PB for the first time, so I hope they come through OK
Your comments please.
« Last Edit: August 19, 2010, 02:20:31 PM by Brass_Machine »
I feel like a 22-year old, but my wife won't let me have one.
Re: A couple of tools I made
« Reply #1 on: August 19, 2010, 02:21:17 PM »
Nice job on the tools!
Fixed a tag in your post so both pictures show.
Offline j45on
« Reply #2 on: August 19, 2010, 03:13:52 PM »
Nice work  :thumbup:
Did you make these from plans ?
Jason
« Reply #3 on: August 19, 2010, 03:21:47 PM »
Hi Grinder,
They are two nice pieces of tooling you've made. I particularly like the vice!  :thumbup:
« Reply #4 on: August 19, 2010, 03:51:14 PM »
Grinder
Very nice job on both pieces. They will both come in very handy on a lot of your future projects. Thanks for sharing them with us.  :D :D
Offline cidrontmg
  • Country: pt
« Reply #5 on: August 19, 2010, 04:42:34 PM »
Both pieces look excellent   :thumbup:   IŽd want a small V-groove in one or both of my vise jaws (both a horizontal as well as a vertical). It comes handy when mounting round workpieces.
Olli
Penafiel
Portugal
Offline wheeltapper
  • Spixworth Norfolk
« Reply #6 on: August 19, 2010, 05:25:49 PM »
nice tools.
glad to see you got your pics sorted out.
Roy
« Reply #7 on: August 19, 2010, 06:09:28 PM »
Top job grinder  :clap: :clap: :thumbup:
I must get round to making one of those tipped dovetail cutters  :dremel:
« Reply #8 on: August 19, 2010, 06:15:24 PM »
Nice job on the tooling. Looks like your very good a maching. :thumbup:
I realy like the dovetail cutter.
I have to make one someday. Ah, tool project #204.  :doh:
Offline rleete
« Reply #9 on: August 19, 2010, 08:21:22 PM »
204?
I think you forgot a couple of zeros in there, Bernd!
Offline Gerhard Olivier
« Reply #10 on: August 20, 2010, 06:35:15 AM »
Grand job on the tootls Grinder
If you have plans or a link to the plans for that dovetail cutter I would love to copy make one as well.
Gerhard
Guernsey
Channel Islands
Offline grinder
« Reply #11 on: August 20, 2010, 08:30:00 AM »
Hi everyone,
Thanks for all the encouraging comments, I feel like part of the group now. Thanks to Eric too, for linking my pics, (how did you do that?)
There are a few more projects that I'm working on now. I have a number of end mills that have seen better days, and I just started designing a fixture to hold them to the mill table so I can grind them. I'll post some pictures as I work through it. BTW I found the plans for the milling vice on the web at http://www.deansphotographica.com/.
« Reply #12 on: August 20, 2010, 09:25:14 AM »
204?
Ya, well maybe I'm trying to deceive myself. I get depressed just thinking about not being able to get them done in this life time.  :lol:  :lol:
Offline grinder
« Reply #13 on: August 20, 2010, 09:52:59 AM »
I though about that, but decided to leave the faces flat. I have some small "V" blocks that I can use if I need to. McMaster-Carr have some "V" blocks only 1" on the side
Offline fatal-exception
« Reply #14 on: August 20, 2010, 01:04:56 PM »
Looks good!
Did you get the dovetail cutter idea from the CNCCookbook page? I just read that bit last week and thought it was a pretty good idea. http://www.cnccookbook.com/MTMillDovetail.htm
All it needs is a polishing and gun-blueing and call er done!
Paul
Offline cidrontmg
  • Country: pt
« Reply #15 on: August 20, 2010, 06:17:10 PM »
yes, mini V blocks are even better, in that you can also use them at an angle. Jaw Vees are always 0 or 90 deg to the quill. (Unless you tilt the whole vise - not a good idea...)
Olli
Penafiel
Portugal
Offline grinder
« Reply #16 on: August 21, 2010, 10:12:08 AM »
Looks good!
Paul
Hi Paul,
The website you mentioned did give me the idea, but I had a problem with the radius. If you look at the diagrams, you'll see that the trailing edge of the cutter actually sticks out farther than the cutting edge. To overcome this problem, you have to cut the backside of the mount shallower then is shown. The idea being to get the cutting edge farther out than the trailing edge. I realized this was a problem after I made my first one. With proper relief, it works great!
