Author Topic: Mystery tool: What is it??  (Read 15985 times)
« on: August 05, 2010, 11:46:01 AM »
When I bought my Bridgeport, it came with a small selection of tool holders. The strangest, and only one I can't identify is this one. Does anyone know what it's for?
The holes on the top & bottom surface go all the way through, and are angled outwards to the bottom edge (i.e. not perfectly vertical - bottom face has a larger PCD). They look to me like they've been drilled, followed by a 9/32" or 8mm square broach.
The letters "N S P" have been stamped or engraved near 3 of the holes (one letter per hole), but I assume this is the manufacturer rather than anything relating to those holes specifically... No other letters or markings are visible.
Any ideas?
Re: Mystery tool: What is it??
« Reply #1 on: August 05, 2010, 12:11:40 PM »
A large fly cutter that uses some kind of insert?   :scratch:
Offline jim
« Reply #2 on: August 05, 2010, 12:34:58 PM »
is it an early "tipped" face mill??
« Reply #3 on: August 05, 2010, 12:55:42 PM »
Yes!
Even older than me...... I saw one in a pile of scrap, when I was a new apprentice. It used square section "tools".
Some time previous, we'd gone over to modern throwaway tip cutters.
« Reply #4 on: August 05, 2010, 04:27:26 PM »
 :lol:
I'd better get it down to Antiques Roadshow then, that should confuse them  :headbang:
Thanks chaps. I'm guessing it's not really worth keeping. I don't have any suitable inserts, and I already have a 2" shell mill which does most of my surfacing work (which takes standard triangular inserts).
« Reply #5 on: August 05, 2010, 07:08:52 PM »
.... I'm guessing it's not really worth keeping....
But it's bound to come in useful sometime, so I'm betting you don't throw it away :lol:
« Reply #6 on: August 05, 2010, 07:20:25 PM »
Damn, rumbled!
Actually, I've got a monster roughing cutter which needs to be mounted on an R8 collet; it's currently on an INT50 (no use to me)... so I can at least re-use that much of it. I guess the rest will make an excellent paperweight!
