Author Topic: Moteur oscillant double effect  (Read 91058 times)
Re: Moteur oscillant double effect
« Reply #50 on: August 29, 2010, 04:41:31 AM »
Nice bit of kit their Dave to big for my shed though.
I've got a stool like that in my shed, but I'm not a hard nut.
Spent a bit of time making the jig to drill the holes in this gland thingy
Here we are with a drilled part.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4315.jpgMoteur oscillant double effect
Thought I'd point out a few design features of the jig.
The base is relieved so that it sits flat.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4316.jpgMoteur oscillant double effect
The plain diameter clears the job to give the drill guide location thats concentric with the job.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4322.jpgMoteur oscillant double effect
Make sure you can hold the jig safely, my first attempt was made with a noggin of steel from my scrap box than I realized my fingers would be close to the drill as it came through the job, I thought Ill just after be careful, but then thought my time would be less painfully used making a new one than waiting in the ER room.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4323.jpgMoteur oscillant double effect
« Reply #51 on: August 30, 2010, 11:34:19 AM »
Nice work there, Stew but if you don't leave some blood on it, how will forensics ever know they are your engines?  From the way your log is going, I should get on the same project myself, and have a pile of small engines to pass around at Christmas for all and sundry.  I'm really looking forward to seeing them together and all running at the same time.  Beautiful work aided by well made jigs, they definitely make the difference in this build. :thumbup: :bow: mad jack
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #52 on: August 30, 2010, 06:59:45 PM »
Neat thread, Stew.  Took me a few days to catch up, as I came in late.  Glad I got to it!
Lots of neat parts and neat machining tips.   You run a good show!
Dean
Dean W.
Shop Projects:
« Reply #53 on: August 31, 2010, 12:53:56 PM »
Thanks Jack/Dean
Jack I try to keep the red stuff off the floor  :D
To finish this part off
Mount back stop in the head stock and face to length turn register to 10mm dia*1mm length, then using the two wire trick mill the flats for a nice match on the cylinder.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4329.jpgMoteur oscillant double effect
Here they are with one in place and studs in place that will take the gland seal.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4330.jpgMoteur oscillant double effect
Now for the other end, this cap is only 3.5mm thick with no through centre hole so its not to easy to jig up, time for another approach:- Turn 17mm dia, a goodly length, enough to make all the caps plus a bit.  Then over to the mill, using the PCD feature of the DRO drill the holes full depth of the drill.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4334.jpgMoteur oscillant double effect
Back to the lathe turn up 10 mm register and part off, repeat repeat repeat, until no more holes left then back onto the mill drill four more holes full depth of drill again back to lathe etc etc, I got 7 parts out of each cycle so it was nice and quick.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4339.jpgMoteur oscillant double effect
Then mill the flats as before, and her we are all finished.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4341.jpgMoteur oscillant double effect
Getting a good collection of parts still quite a few to go though.
« Reply #54 on: September 10, 2010, 10:12:31 AM »
 :nrocks:
I've not done an update on this for over a week, reasons being a short holiday, domestic duties, and I was beginning to repeat myself, lot of the bits required similar techniques with stops etc, so I just got on with making bits until something interesting came along.
The rotary valve is the interesting bit  :D
I've gone away from the drawing with this one because John tipped be off that the drawing put the arm in a awkward position, and he added a stop to the movement.
The first job was to drill and part off some brass, then mill a 5.5mm slot across the middle.
This slot becomes the reference feature for the position of the air ports, so to get this location correct I first turned up a mandrel and with this on the rotary table milled a location key in it for the slot.
Like this
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4377.jpgMoteur oscillant double effect
The valve was then fastened to it and using the rotary table and a 2mm slot drill the ports and the stop slot milled.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4381.jpgMoteur oscillant double effect
When using a rotary table its all to easy to get lost, so with a soft pencil I mark the degrease on the scale I want to work too.
Her they are with the crib sheet I used.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4384.jpgMoteur oscillant double effect
And here's a box of bits.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4387.jpgMoteur oscillant double effect
I've got enough bits to do a trial assembly to see how it all fits:- The base and take off is from Johns spare box.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4382.jpgMoteur oscillant double effect
I'm going to have to do a bit of bling work soon.
This job is going on the back burner for a couple of days, its the club Gala next week (18th Sept) so I want to see if I can get my boiler finished and some of my model polished up to add to the show, if any of you Guys live in the South Cheshire area the club is located between Crewe and Nantwich behind the Peacock Pub, if you want to drop in and have a look round and a ride on one of the locos.
« Reply #55 on: September 10, 2010, 12:03:27 PM »
Very nicely done, again Stew.  :clap:
Love your parts stash. Building an assembly line next?  :thumbup:
Pity, your open day is a little far for me.......
« Last Edit: September 10, 2010, 12:05:03 PM by Stilldrillin »
« Reply #56 on: September 10, 2010, 02:56:11 PM »
Nice!
« Reply #57 on: September 21, 2010, 01:04:29 PM »
Thanks again Guys
Well got this off the back shelf, and made a start on the piston,con rod, and big end assy.
I'm making the piston and big end out of ally bronze which has good wear properties.
First Job skim three lengths of bar down to 10mm the same size will do for the big ends. Ally bronze is not that easy to machine its very sticky and generates a lot of frictional heat, but John advised be to use a slower RPM, and it worked a treat.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4400.jpgMoteur oscillant double effect
The pistons were then drilled a tapped and parted off from one of these lengths.
I'm not making the big ends to the drawing I'm going to make them square more big end shape if you know what I mean
So over to the mill and with the spin indexer mill the 10mm bars to 7mm square.
At this point thing went wrong with the first bar I was planning to drill 4mm holes along the bar for the bearings but I had too much flex in the set up even with a centre and a jack under the bar the holes were coming out all shapes,
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4399.jpgMoteur oscillant double effect
Plan B scrap the bar off turn and mill another one up, and drill them in the vice.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4401.jpgMoteur oscillant double effect
With a self centering four jaw in the lathe and using a bit of 4mm rod through one of the cross holes as a stop, face, turn step, drill and tap M3, not forgetting to drill a 1.5mm 3mm dia register hole, this will help pull the con rod concentric when its screwed home.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4411.jpgMoteur oscillant double effect
Remove the cross bar first before turning.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4403.jpgMoteur oscillant double effect
Check that I'd got the correct hole centre.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4402.jpgMoteur oscillant double effect
Whilst I'd got the spin indexer set up I fluted a couple of bars to make knobs out of for the displacement lubricator.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4412.jpgMoteur oscillant double effect
Her are the con rod ends finished and a couple of lose assemblies.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4414.jpgMoteur oscillant double effect
Last job of the day clean the pistons a rods and glue with thread lock, I'll leave them over night so I can make a start on turning the pistons to size in the morning.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4415.jpgMoteur oscillant double effect
« Reply #58 on: September 21, 2010, 03:49:23 PM »
Nice to see you're back, and producing Stew!  :thumbup:
« Reply #59 on: September 28, 2010, 12:28:27 PM »
Cheers Dave
Things have slowed down a bit on this job:-
It's amazing how a six month old rug rat can distract you enough to keep you out of the shed.  :D
Any way finished off the pistons the only pic I took was of the set up to final turn the OD to size with a nice sharp honed tool.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4419.jpgMoteur oscillant double effect
Then I went on and knocked out the power take off bearing housings, nothing too interesting on these I've shown similar set ups before.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4424.jpgMoteur oscillant double effect
Now this will interest you:- the Base Plate.
This is made from brass sheet so first job cut seven out to rough size and stick them together with two way tape, and give the bundle a squeeze in the vice.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4425.jpgMoteur oscillant double effect
I then milled the two opposite long sides clean and parallel.
Then with the bundle clamped together as an insurance drill the four corner holes 3mm as each hole was drilled a stuck a m3 cap screw in it just in case things wanted to move.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4426.jpgMoteur oscillant double effect
Then bolted the plates together this make the bundle nice a secure for milling.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4428.jpgMoteur oscillant double effect
Then mill down the short edges to clean them to size
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4429.jpgMoteur oscillant double effect
Then blue the job and mark out the cuts and the rest of the hole position.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4431.jpgMoteur oscillant double effect
Then chain drill 3.5mm.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4433.jpgMoteur oscillant double effect
Then connect the chain up with a 4mm slot drill.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4436.jpgMoteur oscillant double effect
I struggled to get them apart so put them in a cup of boiling water to soften the glue and cleaned them off with petrol.
That's it Job done.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4438.jpgMoteur oscillant double effect
« Reply #60 on: September 28, 2010, 12:53:15 PM »
Love how you did the base plates Stew!  :clap:
Don`t mention rugrats......  ::)     Severe complications, imminent!
« Reply #61 on: September 28, 2010, 01:51:30 PM »
The plates came out very nice Stew! Super impressed.
« Reply #62 on: September 28, 2010, 07:57:20 PM »
Have to say Stew, nice idea with sticking those plates togeher with tape. Have to file that one away for later use.
Looks like the project is coming along nicely.
« Reply #63 on: October 27, 2010, 12:28:38 PM »
Since getting back from China I've finished of the base girders sorry no pics and started on the displacement lubricator.
Decided to fabricate the lubricator up from copper tube as this will save on material, making from solid would just reduce a lot of good material into swarf.
These are the bits for the body.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4440.jpgMoteur oscillant double effect
I've fitted a bleed nipple into the base so that the water can drained off and the oil top up, without taking the engine off steam.
Bits silver soldered together and a trial fitting on the engine to she how they look.
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4444.jpgMoteur oscillant double effect
Still got to drill the steam hole in the pipe and make some caps, and that all of the bits made for the engines, next job up a bit of bling and set up an assy line.
« Reply #64 on: October 27, 2010, 12:32:23 PM »
Nice to see this is rolling again Stew!  :thumbup:
« Reply #65 on: October 28, 2010, 11:50:20 AM »
What he said, Stew!  good to know you're back and working again :poke:  looking forward to the rest of the story.  :jaw: mad jack
« Reply #66 on: November 04, 2010, 12:03:32 PM »
Well got No 1 running I went through a bit of learning curve, had to do a little bit of fettling and run the tight spots out with a power drill for a couple of minutes with plenty of oil, its now nice and free and running as sweat as a nut, and the forward and reverse works like a dream.
Here it is all oiled up a ready to go'
http://i431.photobucket.com/albums/qq32/sbwhart/French%20Wobler/100_4460.jpgMoteur oscillant double effect
I'll post a vid when I get the rest running.
:D :D :D :D :D :D :D
« Last Edit: November 04, 2010, 12:59:10 PM by sbwhart »
« Reply #67 on: November 04, 2010, 01:16:56 PM »
Nice one Stew!  :clap:
Looking forward to the video......  :thumbup:
« Reply #68 on: November 04, 2010, 07:48:10 PM »
Nice looking engine Stew! Can't wait to see the video.
 :mmr:
« Reply #69 on: November 07, 2010, 07:32:41 AM »
Ok Her's the vid of the no 1 running.
Enjoy
« Reply #70 on: November 07, 2010, 07:57:05 AM »
 :bow: :bow: :bow: :bow: :bow: Nice one Stew  :clap: :clap: :clap:
Sure is a great runner  :thumbup:
« Reply #71 on: November 07, 2010, 08:28:31 AM »
Worth waiting for Stew!  :clap: :clap: :clap:
That's a cracker!  :thumbup:
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #72 on: November 07, 2010, 08:40:56 AM »
Well that looks pretty good, Well done that man :clap: :clap: :clap: :clap: :clap:  :ddb: :ddb: :ddb: :ddb:
Tim
Offline ozzie46
« Reply #73 on: November 07, 2010, 08:48:20 AM »
 Well done Stew well done.  :thumbup: :thumbup: :thumbup:
  Ron
« Reply #74 on: November 07, 2010, 11:32:40 AM »
Very nice runner Stew!
So it is self starting?
