Author Topic: old heavy iron and machine tool photo's  (Read 9790 times)
Offline PTsideshow
« on: July 19, 2010, 06:12:29 AM »
I was sent this link, and for any body into machines and old heavy iron, this is for you.
engines and machine tools photo's in the old days
Have lots of free time
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Re: old heavy iron and machine tool photo's
« Reply #1 on: July 19, 2010, 09:07:11 AM »
Glenn,
Nice archive of old pictures, all 164 of them. Amazing what was done before elcetronics and computers came along. :headbang:
« Reply #2 on: July 19, 2010, 01:22:42 PM »
Glen
Thanks for posting the link. I went and looked at all 164 and a bunch of them twice. I found one description (that repeats several times) which I think is in error.
Description: The Mesta Machine Company produced various types of engines for its customers. These engines included gas and steam powered engines for use with blast furnaces, una-flow or direct-flow engines for driving roll mills, and reversing and Corliss engines. These engines were designed to withstand steam pressures up to 180 pounds and superheat up to 75 degrees Fahrenheit. Mesta designed the Corliss Engine for use in rolling mills, power engines, blowing engines, air and gas compressors, pumping engines, and vacuum pumps.
"superheat up to 75 degrees Fahrenheit" I didn't think that 75 degrees Fahrenheit was that hot, heck I like my shower hotter than that. I'm not doing this to nit pick but if it is wrong I figure that they would like to be giving out the correct information. If anyone can confirm what this should be I will try and get a hold of the Library and Archives Division, Senator John Heinz History Center and advise them of the error.
« Reply #3 on: July 19, 2010, 02:50:20 PM »
I think superheat refers to an increase in temp. above the normal steam temp. taking into account the boiling point of water is higher as the pressure increases.
ie. say a boiler pressure of 100 psig  ( 115-ish psia ), the saturated steam will be at 338F. so 75F of superheat the steam temp will be some 413F.
Dave BC
Sorry Dave, I thought I hit quote and started to type before I realized that I had hit modify instead.
The dangers of Moderators not paying attention! :bugeye:
« Last Edit: July 19, 2010, 03:05:05 PM by PTsideshow »
Offline PTsideshow
« Reply #4 on: July 19, 2010, 02:51:28 PM »
I'm sure there are a couple more that I noticed just the general descriptions are probably from some librarian/photo scanning person. that doesn't have a clue or was trying to interpret the writing on the back of the photo's.
They used lower super heat temperatures, then a lot of equipment did. Having not had to deal with super heat for the last 25 years of my boiler /engineer operating career. I can say that I would have to dig through the books to get the numbers of what and the temp points. It wasn't a fun subject the first time around when I wrote for my license. 34 years ago.
Knowing how small museums work, they used the same description when they didn't have one or a clue  :bugeye:
Ok ya got me! I think this will give the basic answer. In the US back in the day the max operating superheat temps were 600'F other than for some composite tandem type engines at the Ford plant here in Detroit were the steam temperature was 700'F
Well here is a brief idea:
Because the steam is dry, it behaves more like a gas, no condensation as the engine absorbs heat from the steam. The economy increase is based on the fact that if the superheat is high enough not only to supply the heat absorbed by the cylinder walls but also the heat equivalent of the work done during the expansion, then the steam will be dry and saturated at release.
This is the condition of maximum efficiency in a single cylinder.
A superheat of 250'F to 350'F at admission is necessary to in sure the steam is dry at release in the average single cylinder engine.
Another advantage for piston engine work, A moderate amount of superheat produce a large increase volume, the pressure remaining constant, and diminishes the weight of the steam per stroke for a given amount of work.
And it has a lower thermal conductivity, less heat is absorbed by the cylinder walls.
Steam Power Plant Engineering, By G F Gebhartdt, 1922 edition
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline PTsideshow
« Reply #5 on: July 19, 2010, 03:07:55 PM »
Dave BC
Dave is correct and that's what they probably were trying to say!
A lot of people have a hard time wrapping their minds around steam and water at temperatures they were taught in grade school. or the way it will operate under vacuum.
the old boiling water at sea level or in the mountains or in a vacuum.
And you see, were I went to the more obtuse expanded description!   :bugeye: more than most will want to know  :lol: :lol: :lol:
I'm going to quite typing, and let me get back to fixing dinner.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
« Reply #6 on: July 19, 2010, 03:56:05 PM »
Dave & Glen
Thanks for the replies and information. I don't understand/know steam so I didn't want to make too big a statement about something that I wasn't sure of. Your answers both help me to understand how the 75 degree F. might not be was it first seems like. I certainly will not be having a shower with 75 degrees Fahrenheit superheated steam, just in case. :lol: :lol: :lol:
« Reply #7 on: July 19, 2010, 05:53:58 PM »
 :bugeye: cheers for sharing the link Glen  :thumbup: :clap: :clap:
GREAT STUFF
