Author Topic: Motor reversing  (Read 11277 times)
Offline slowcoach
Motor reversing
« on: July 18, 2010, 02:33:21 PM »
Hello, can anyone help, I have a single phase motor 240v AC 1/4hp that I want to use on my pillar drill. The problem I have is that its rotating in the wrong direction  (anticlockwise)   :scratch: and I was wondering if anyone on here as a solution to my problem? I have tried reversing the polarities but it still runs anticlockwise  :bang:
Rob  :thumbup:
Offline Gadget
Re: Motor reversing
« Reply #1 on: July 18, 2010, 05:03:59 PM »
IF the motor can be reversed there will be a wiring chart usually on the motor or inside the wiring box for the motor. If you don't see that you probably have a single direction motor. Turn it around and mount it on the other side of the belt if possible is your only option.
Dan
Re: Motor reversing
« Reply #2 on: July 18, 2010, 09:09:37 PM »
I was going to say flip it 180º. May be the same thing Dan suggested.  :scratch:
lordedmond
Re: Motor reversing
« Reply #3 on: July 19, 2010, 03:35:39 AM »
take the ends off and swap them over so the shaft sticks out the other end
Stuart
  • Country: nz
Re: Motor reversing
« Reply #4 on: July 19, 2010, 04:06:44 AM »
If it has a capacitor it can be reversed by reversing the connections to the starter windings,  it is a job for someone who can open it up and figure out how to do it.
Offline Gadget
Re: Motor reversing
« Reply #5 on: July 19, 2010, 08:42:13 AM »
Yep, same thing but you described it in a more elegant fashion.  :D
Offline John Swift
Re: Motor reversing
« Reply #6 on: July 19, 2010, 09:34:04 AM »
does this help
Offline slowcoach
Re: Motor reversing
« Reply #7 on: July 19, 2010, 05:37:26 PM »
Thank you, for all you excellent suggestions  :thumbup: Mr Swift, I really must thank you for your wiring diagram that you posted, I followed it, and I'm pleased to say it worked a treat  :headbang: Pillar drill now spinning in the correct direction  :D I must admit, I was a bit nervous as I flicked the switch  :zap:
Thanks again Guys
Rob  :thumbup:
Offline John Swift
Re: Motor reversing
« Reply #8 on: July 20, 2010, 10:35:45 AM »
Hi Rob
          happy  to help when I can
I don't normally work on machines with mains powered motors but ,
 as people like to see pictures
 some vt machine's   I have worked on in the 80's and 90's
 ampex VPR2 and Sony BVC-10      ( the modded vpr1 looks the same )
« Last Edit: July 20, 2010, 10:45:49 AM by John Swift »
Offline slowcoach
Re: Motor reversing
« Reply #9 on: July 20, 2010, 11:10:35 AM »
Hi John,
Impressive, but way above me, I would'nt know where to start fixing something like that  :bow: Thanks for showing  :thumbup:
Re: Motor reversing
« Reply #10 on: July 20, 2010, 12:13:56 PM »
 :offtopic:
If we're into piccys of tape libraries ...
This is one I used to work on ..
Although I think the AML/2 is obsolete now, huge thing ... handling robot not to be trifled with .. unless you like coming second .. posthumously ..
http://www.sunstarco.com/Tape%20Drives/ADIC/ADIC%20-%20AML_2.htm
Dave BC
« Last Edit: July 20, 2010, 12:25:46 PM by Bluechip »
