Author Topic: Short bandsaw blades - do they exist/where to get them?  (Read 18756 times)
« on: July 16, 2010, 09:40:19 AM »
I have a comedy bandsaw (a DeWalt DW100), which takes little tiny 59.5" blades... a quick perusal of ePay would suggest that I can only get carbon steel blades in this size...
Does anyone know of a UK supplier of bi-metal or HSS blades in such a short length? Alternatively, could I buy a longer HSS/bi-metal blade & shorten it? If so, can the two ends simply be mig-welded together, or do they need silver soldering/brazing?
Re: Short bandsaw blades - do they exist/where to get them?
« Reply #1 on: July 16, 2010, 11:27:07 AM »
Ade -- I don't know about the UK, but several of the large (even "discount") suppliers (such as Enco) list them here in the U.S.  It will be less expensive if you just spring for a roll of blade in the size/tooth configuration you prefer and take them to the local industrial supply and have them welded to length.  Alternatively, it costs about $300 US to purchase a bandsaw blade welder.  ???
Offline cidrontmg
« Reply #2 on: July 16, 2010, 03:26:48 PM »
Hi AdeV,
I have a (very old but very good - well, I like it!) Black & Decker DN339 small bandsaw that also wants 59.5" x 1/4" blades. I´ve bought several (over the years) from Chronos,
http://www.chronos.ltd.uk/acatalog/Chronos_Catalogue_Bandsaw_Machines___Bandsaw_Blades_181.html
(about halfway down the page)
They don´t say in the page what material it is,  but they´ve worked just fine for me, for brass + ali, and for thin steel. For ten £, it maybe is worth a try  :poke:
I often cut 2"x2" ali bars with them blades, it does take some time, but still far faster (and easier on the elbow) than a hacksaw. Through 3 - 10 mm ali plate, it goes about the same as through equivalent plywood. In my use, one blade lasts for about 20-25 months. I haven´t broken any, the blade just gets dull.
I´ve also made my own (years ago), from a roll of bimetal blade that I bought locally. Ends (duly thinned) silver soldered, with a homebrew cobbled jig. I´ve also tried spot welding the ends, but they snapped open rather easily. Must have been my fault really, of course they can be welded, but not like I did it   :zap:
Silver soldering, the way I did it, was far stronger. They will cost less per blade in the long run, although the roll of material cost a zillion... It´s not really suitable for such a small saw, the material is wider (8 mm instead of 6.3 - I couldn´t find any narrower) and a bit thicker. It needs more tension in the blade than the saw was designed for, and is only good for straight cuts.
« Last Edit: July 16, 2010, 03:32:20 PM by cidrontmg »
Olli
Penafiel
Portugal
Offline JimM
  • Chessington, Surrey
« Reply #3 on: July 19, 2010, 11:56:10 AM »
There's an article on MIG welding bandsaw blades with step by step instructions in the current issue of Model Engineers Workshop, haven't tried it myself but the author is pleased with the results. G
HTH
Jim
MrFluffy
« Reply #4 on: September 14, 2010, 05:35:52 AM »
I had exactly the same issue, with a ryobi conversion. These chaps a) know their stuff and b) will make you a custom bandsaw blade to whatever you want.
Dragon Saws Ltd
Unit 13, Duffryn Business Park, Ystrad Mynach, Caerphilly, CF82 7RJ
Tel: 01443 819910 Fax: 01443 819911 email: sales@dragonsaws.co.uk
http://members.ebay.co.uk/ws/eBayISAPI.dll?ViewUserPage&userid=dragong3
« Reply #5 on: September 14, 2010, 06:44:11 AM »
Thanks for all the leads chaps! I'll try Dragon Saws first I think, they sound like the least-effort (on my part  :poke:) solution to me!  :med:
« Reply #6 on: September 14, 2010, 06:44:34 AM »
I have an old Black and Decker bandsaw that should take 59.5" x 1/4" blades. But have found that it will easily accomodate a 1/2" wide blade, which gives a much straighter cut and the blades do last a lot longer.
I get mine from Axminster and go for the 14TPI, I wouldn't cut steel or anything harder with them, but they do me for everything else. A blade will usually last me between 6 months to a year, just depending how vicious I am cutting materials.
http://www.axminster.co.uk/bandsaw-blades-1510mm(591-2)-x-0014-prod21507/
Offline Ned Ludd
« Reply #7 on: September 14, 2010, 10:49:35 AM »
Before I started to buy from J&L, I used to buy from Bandsaw Services Ltd in Windsor. They will make blades to your specs, but I am sure if you look in your local Yellow pages you will find a similar company offering the same sort of service.
Ned
Leafy suburbs of NW London
Offline djc
« Reply #8 on: September 14, 2010, 03:34:09 PM »
Dragon Saws Ltd
Sadly, Dragon Saws are no more. If you check the feedback in the page quoted, it stops in March 2009, when DS ceased trading. The bloke who was involved in it has started up again as TuffSaws, whose page Google will find for you.
