Author Topic: 32 bit or 64 bit  (Read 24885 times)
32 bit or 64 bit
« on: June 04, 2010, 11:16:03 AM »
Hi Lads
Quick question ,,,,,,,,,,is there much of a difference between a 32 bit system to a 64 bit system ?
Cheers Rob
Re: 32 bit or 64 bit
« Reply #1 on: June 04, 2010, 11:19:21 AM »
32 bits, or very nearly ...
 :lol:
« Reply #2 on: June 04, 2010, 11:22:54 AM »
Perhaps software. I just built a new computer and am using Windows 7 Proffesional. I tried veiwing some U-tube videos and couldn't because of Adobe Flash. I went to get the latest and it told me there wasn't one for Windows 7.
Now I can load and run programs but am a bit dangerous when it comes to the more intricate runnings of a computer.
« Reply #3 on: June 04, 2010, 11:23:58 AM »
Sorry, could not resist that one.
Depends why you ask ?
I have a 64 bit W7 on t'other PC, not this laptop, 'an it blows this into the crap ... Vista 32 bit.
EDIT Laptop is 1.6GHz dual core Pentium but only 1Gb memory, Desktop is 2.3GHz Quad core plus 4Gb memory
Other things come into the equation, like proc. speed & memory size.
Beware there are some stuff ( like some PIC applications for eg ) that will not run with 64bit W7
Dave BC
« Last Edit: June 04, 2010, 11:28:00 AM by Bluechip »
« Reply #4 on: June 04, 2010, 11:37:59 AM »
Hi lads
Bernd ,,,,,,, just tried you tube ,,no flash,(windows 7 ultimate 32 bit installed) , just downloaded , works now . :D
Dave ,,,,i did not get the joke , :(, went way over the top of me  :lol: :lol: :lol: ,,,,,,  BUT IS IT BETTER  :)   ,,,,,,,,,,, cos i have 4 gig of ram on this laptop , but its capped to 3 gig  :scratch:
Cheers Rob
« Reply #5 on: June 04, 2010, 11:42:13 AM »
I don't use the desktop much, but I think some progs can be run under a 'XP SP3' mode.
Never used it .. AFAIK
Still don't know why you asked? more speed ??
Dave BC
EDIT Probably the RAM makes a lot of difference.
« Last Edit: June 04, 2010, 11:44:08 AM by Bluechip »
« Reply #6 on: June 04, 2010, 11:43:59 AM »
Hi Dave
YEP is it faster ?  why have 32 and 64  :scratch:
« Reply #7 on: June 04, 2010, 11:49:37 AM »
Dunno, there must BE a reason ??
I got a download a few weeks ago, and it went into the W7 64bit Prog Library, on mine, didn't work.
Found out from another electroniccy forum ,I needed summat enabled in the security settings, so the host knew I had 64 bit , and avoided it. Thus putting the download into the W7 32 bit library where it worked ..
You got Skype on? my fingers too hot ??
dave BC
« Reply #8 on: June 04, 2010, 11:55:43 AM »
GiZ a couple of minutes ,,need to fined to fined web cam
« Reply #9 on: June 04, 2010, 12:42:49 PM »
may be this is a better question
What's the benefits of a 64 bit system over a 32 bit system ?
and a couple more
When you format a hard drive is the data actually gone . can it be retrieved ?
How many times can you format a hard drive ?
thanks Rob
Offline sorveltaja
« Reply #10 on: June 04, 2010, 01:07:25 PM »
thanks Rob
Hard drive must be over-written with 1 and 0's, or destroyed mechanically, if needed to make sure, that there is no traces of previous data.
However, those are most extreme ways.
If the hard drive hasn't been treated that way, it should be possible to retrieve at least some of the data.
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #11 on: June 04, 2010, 01:10:48 PM »
Ok, I'll start of by saying that I am not an ex-spurt ( former drip ) but what I ( almost ) know I will tell.
One of the primary benefits is that the computer can make use of much much more memory. Under 32bit windows it can only use 3Gb (possibly 4 if you do some tinkering ) but even then the total amount any one program can use is limited to below that. However, under 64bit windows, that memory limit is not there.
This memory issue doesnt bother most folk who are just surfing, emailing and general wordprocessing type activity. But move into editing video, esp' HD, heavy photo editing, 3D CAD, playing the latest games, and other high-demand processing activities and 64bit operating systems make more sense.
The other thing to take into account is that most CPU's are now 64bit, this means that if you are running a 32bit operating system you are most likely not getting the full use out of your CPU, whereas a 64 bit operating system will be able to make full use of it.
The short answer is - it depends. If you format a hard drive all you are actually doing is deleting the infomation of what and where all the data was on the drive. Kinda like taking a book and replacing the table of contents or index with blank pages. Until you write new data to the formatted hard drive, pretty much all of the old data should be recoverable. When you write new data to the formatted hard drive it will then over-write what was previously there making it nigh-on impossible to retreive.
If you want to remove the data on a hard drive so that no-one can recover it you can get software that will write over every part of a hard drive with one's, then with zero's, and will do that as many times as you want it to. ( but be prepared for a loooooooooooooong wait )
Pretty much unlimited, that is, until the hard drive itself breaks down. All you are doing when you format it is writing a new blank "table of contents", the result of formatting a Hard Drive is no more physically demanding for the drive than just writing or a file to it.
Hope this helps explain it a bit
Tim
Offline sorveltaja
« Reply #12 on: June 04, 2010, 01:44:12 PM »
Addition to that original question:
Most of the programs, that many of us are used to, are still 32-bit. Some heavier softwares (might)have support for 64-bit, such as servers and 3D-modelling.
It depends so much on what purpose you intend to use the computer.
64-bit operating system itself isn't the solution. Hardware + proper drivers plays an important role on that game.
That babbling is based on my experience with a laptop, that has win7, dual cpu, and 4 Gb ram. It also has a rather weak display adapter, when using 3D software, if compared to my desktop, where all is 32-bit.
MrFluffy
« Reply #13 on: June 18, 2010, 06:34:46 AM »
64bit architecture is worth having if the machine is set up to use it but its all still quite new in places and still filtering down to the grass roots of programs. I have a 64bit cpu server here and most of the stuff running on it takes advantage  of that but there are still some (proprietory) applications that are 32bit version only and have to be run in 32bit compatibility mode. Its not night and day but it does run some of the more calculation only intensive stuff (hash calculation work mostly) noticeably quicker compared to another 32 bit based machine that sits in the rack above it that used to do the job before it.
Outright cpu clock speed and gpu (graphics card) speed would have a much more marked improvement on speed over a change in actual architecture, because lots of stuff will just stay in legacy 32bit mode for many many years to come, but when we get a new cpu it tends to be faster, the motherboard has improvements to its chipsets to feed the cpu faster and we add a bit more ram while we're at it so you turn it on and think "Wow this 64bit thing is the bomb"  :headbang:
If you want to make sure nobody can recover your hard drive data and want a foolproof method, take it apart and smash the platter (the silver shiney weird cd looking part) with a hammer. You'll get some nice sticky strong rare earth magnets out of it which are handy round the shop to hold drawings etc as part of the destruction, and nobody is ever going to recover a hard disk from a smashed platter no matter how specialist they are  :thumbup:
You can securely wipe with dban (www.dban.org) etc which is a lengthy (>8 hrs on average) process, or there is a faster process (up to 8 times as fast) which uses something built right into the drive firmware itself if its new enough called ATA Secure Erase, you can access it various ways but this one is fairly user friendly...
http://cmrr.ucsd.edu/people/Hughes/SecureErase.shtml
If your needing to get some data back, there are programs and specialist recovery firms about. They can even rebuild the failed drive with new heads and electronics to get back lost data but this doesn't come cheap. I had one rebuilt last year because a company had no backups, and their lost data was worth a lot more than the £800 charge to have it go for specialist rebuild with new heads in a clean room. One of mine got fried in a lightning strike on our powerlines which fried the ups etc and only needed a new circuit board hence £200 recovery fee...
Offline kwackers
« Reply #14 on: June 18, 2010, 07:14:43 AM »
One of the other things worth considering is if your computer is Von Neumann architecture then the code and data word lengths are usually the same (although instructions can allow for embedded data).
What this means is the code size for a given piece of code increases for 64 bit and if the code cache is the same size can result in more cache thrashing and potential cache stalls.
It's quite difficult to say whether or not something will be faster in 64 bit, probably the most important factor is the format of the majority of the data. At work we write a lot of 128 bit stuff - but the data is nearly always arranged as 4x32 bit floats (maths intensive stuff).
« Reply #15 on: June 18, 2010, 05:13:50 PM »
Cheers Lads
Thanks for all the info ,,, i tied 64 bit and it was no quicker , and i could not get some of the drivers ,, so its back to 32 bit ........on the plus side i did learn a bit more about computer , like you just cant stick a 64 bit boot disc in ,, you need to enable it in the BIOS ,,think thats what it called ,,,,,, i worked it out all by me self  :D
Keep the info coming  :thumbup:
Cheers Rob
« Reply #16 on: June 18, 2010, 08:57:32 PM »
Getting a lot of good info here Rob. Got quite a few techie type people in here...
I am in IT, but don't do anything along the pc/laptop world... so I am of no use!  :lol:
« Reply #17 on: June 19, 2010, 04:58:21 AM »
Hi Eric ,
 The thing i fined most interesting about this site ,,is the mixed bag of interest's that other members have , you never no what's coming next  :nrocks:
Cheers Rob  :thumbup:
Offline John Swift
« Reply #18 on: July 20, 2010, 11:04:45 AM »
 Hi Rob ,
     like this sony betacart  that used to give me nightmares several years ago
 both the betacart and the 4 vt players had several  8bit Z80 cpu in them
« Last Edit: July 20, 2010, 11:07:16 AM by John Swift »
