Author Topic: R.W Gas Engine  (Read 87973 times)
Re: R.W Gas Engine
« Reply #100 on: June 23, 2010, 03:46:07 AM »
Hi Lads  :wave:
Mulled a few ideas around for holding the casting to the mill , from blue tack to making a large vice with separate jaws that bolt to the mill table (future project ) any way had a brain fart and ended up poking a couple of holes in the casting ,so i could have something to grip.Them i welded a short lenght of 3/8 bar to a couple of clamps
The casting was then shimmed up on the mill and clamped down
Then off we go
job done
First job on the 626 mill ,, works well  :D
Cheers Rob
Re: R.W Gas Engine
« Reply #101 on: June 23, 2010, 04:10:18 AM »
Neat thinking Rob!  :thumbup:
Re: R.W Gas Engine
« Reply #102 on: June 23, 2010, 04:21:02 AM »
WELDED
Good heavens man, I'd have expected some custom clamp with a mirror finish and ground to 3 nano microns of the clamps life.
What is the world coming to ? welded ??
John S.
Re: R.W Gas Engine
« Reply #103 on: June 23, 2010, 04:41:32 AM »
Actually, John........
You`re right!      :lol: :lol: :lol:
David D  :thumbup:
Re: R.W Gas Engine
« Reply #104 on: June 23, 2010, 05:07:17 AM »
David D  :thumbup:
Stop egging him on  :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Rob  :D
Re: R.W Gas Engine
« Reply #105 on: June 23, 2010, 05:21:37 AM »
WELDED
John S.
3 nano microns ?? :scratch:
Can I ask why you still persist in using the long-obsolete and archaic SI system of measurement ?
The correct dimension should read '3.187 atto FOOTBALL PITCHES' , or, alternatively, '2.613 femto DOUBLE-DECKER BUSES'.
I have sent a copy of your post to Tiff Needell .. together with a strongly worded note.
Let us have no more of this .. please  use the current UK standards. Pitifully low as they are.
 :lol:  :lol:  :lol:
Dave BC
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
Re: R.W Gas Engine
« Reply #106 on: June 24, 2010, 01:08:10 AM »
Good thinking with those pin clamps, Rod.  That welding looks very precise, to me!  ; )
Gee, that casting looks as good on the inside as it does on the outside, too.
Dean
Dean W.
Shop Projects:
Re: R.W Gas Engine
« Reply #107 on: July 01, 2010, 03:26:52 PM »
Cheers Dean ,,,,,,,,, The casting is surprisingly  good , only one spot witch has some porosity  :D
This post  may have way to many photos  ::)  ,,,,,,, I machined up the casting over the past two nights ,this is how i did it .
The casting had to be marked out to give me some reference points to work from and to make sure the casting would machine up correctly .
the casting was set up on the surface plate using a couple of small screw jacks and an angle plate so i could mark a datum line through the center of the casting .
once i was happy with the position of the casting the centre line datum was marked , this will be used to set the casting up on the mill
Next the position of the crank centre was marked out and all other parts to be machined  as a guide so that i dont machine off something that i should not  :bang:
That  done time for some machining  :ddb: , I wanted to mill all parts without having to reposition the casting once bolted to the mill , so i decided to use the Aceira F3 HZ/V mill , I just had enough travel on the mill , machining the casting this way i would not have any alignment issues.
The casting was set up on the mill using the datum line
Had to use my small doodad , that lets me have a tee slot were i need it  as i was very limited to were on the mill the casting could go.
With it all set up the cylinder end was machined up
next the bearings , the table on the mill tilted to 18 degs
next picking up the datum the inside of the bearing supports were machined
that done i could machine them to the correct thickness
then the tops were  machined
Then off with the vertical head so i could machine the bosses for the timing gear and stuff with the tooling in the HZ head , One of the previous operations machined off the crank centre , so a temp datum was fitted.
with that located it was a case of across a bit down a bit using the dials to locate the centre fro the timing gear shaft
After drilling the hole was bored to size using a very small boring head
Then the rest of the bosses were machined up
Job done ,,,,,,,,, well still need to do the bolt down pads
Cheers Rob
Re: R.W Gas Engine
« Reply #108 on: July 01, 2010, 03:40:50 PM »
Well I suppose that will have to do.......
John S.
Re: R.W Gas Engine
« Reply #109 on: July 01, 2010, 03:44:32 PM »
John S.
But are you happy with the amount of swarf in the shots ,John  :D
Offline Artie
Re: R.W Gas Engine
« Reply #110 on: July 01, 2010, 03:46:35 PM »
Wow
Offline Artie
Re: R.W Gas Engine
« Reply #111 on: July 01, 2010, 03:47:05 PM »
no, seriously...wow
Offline Artie
Re: R.W Gas Engine
« Reply #112 on: July 01, 2010, 03:49:42 PM »
I can just see a historian in 300 years time trying to research the RSW Engine Works.... was it some like BMW?..
mate this looks soooooo proffesional..... like it came from a very good factory with automation..... :clap: :beer: :headbang: :borg:
Great stuff...
Rob T
Re: R.W Gas Engine
« Reply #113 on: July 01, 2010, 04:45:27 PM »
very nice
Offline z3t4
Re: R.W Gas Engine
« Reply #114 on: July 01, 2010, 05:00:51 PM »
Have you done this before, then?
Re: R.W Gas Engine
« Reply #115 on: July 01, 2010, 05:05:24 PM »
Another fine lesson in machining. I look forward to these posts like some look forward to their soccer/football or hockey games.  :ddb: :ddb:
Even John seems somewhat satisfied for a change. :lol: :lol:
Offline Dean W
Re: R.W Gas Engine
« Reply #116 on: July 01, 2010, 06:58:01 PM »
Rob, no one will ever know that this was made by a person.  It's too good!
Great work, and done up right on the first try!
 :clap:
Dean
Dean W.
Shop Projects:
Re: R.W Gas Engine
« Reply #117 on: July 01, 2010, 09:15:11 PM »
Only one word comes to mind, "OUTSTANDING".   :jaw:    :thumbup:
Re: R.W Gas Engine
« Reply #118 on: July 01, 2010, 10:52:21 PM »
 :bow: :bow: :bow:
That's some seriously nice work. I learned quite a bit from the pictures alone.  :smart:
Offline CallMeAl
Re: R.W Gas Engine
« Reply #119 on: July 01, 2010, 11:08:54 PM »
Fantastic stuff!  I have to make that "dodad" that let's you have a T slot where you need it!  Thanks for the inspiration.
I skin cats my own way!
Offline stefang
  • Country: de
Re: R.W Gas Engine
« Reply #120 on: July 02, 2010, 01:17:02 AM »
Awesome work and many chips :)
I like the aux t-slot plate..great idea.
Also, nice Aciera milling machine you have there...I got an older style F3 (the more round version), also with the universal table, and I love it :)
Stefan
Re: R.W Gas Engine
« Reply #121 on: July 02, 2010, 02:28:05 AM »
I can`t add anything more....... It`s all been said!
Rob....... That`s blummin good work, and well shown too!  :clap: :clap: :thumbup:
Offline shoey51
Re: R.W Gas Engine
« Reply #122 on: July 02, 2010, 03:18:03 AM »
 :jaw: :bugeye: :thumbup: :bow: :bow: :bow: :bow: :bow: :bow:
what more can I say that hasnt been said :clap: :clap:
Re: R.W Gas Engine
« Reply #123 on: July 02, 2010, 03:57:07 AM »
   :jaw:  Stunning Rob - your craftsmanship is a real inspiration.  In the past we lauded famous authors for their prose - your words+pictures are up there too!  :bow:  :bow:  :bow:  :bow:
Re: R.W Gas Engine
« Reply #124 on: July 02, 2010, 03:58:44 AM »
p.s.  I thought you would have recycled all that swarf into newly-cast bearing caps by now as well !  ::)
