Author Topic: How do a drill a hole?  (Read 9666 times)
  • Country: nz
« on: March 21, 2010, 06:12:39 PM »
I want to drill a hole accurately in the end of a shaft so that I can clamp a tool in the manner of a collet.
This is a simple job to fit a centre drill to a Morse taper blank but every attempt so far has come out crooked. :doh:
Here is a sketch, of course the male bit has a saw cut so that it can compress somewhat as it is screwed into the shaft.
I drilled the hole with the two bits screwed together and mounted in the lathe spindle taper.
« Last Edit: March 21, 2010, 06:50:47 PM by John Hill »
Re: How do a drill a hole?
« Reply #1 on: March 21, 2010, 08:22:26 PM »
Did you cut the slot before you drilled the hole?
  • Country: nz
« Reply #2 on: March 21, 2010, 08:26:31 PM »
No, drilled then cut.
Offline No1_sonuk
« Reply #3 on: March 21, 2010, 08:34:16 PM »
How many cuts?
Could it be that the hole is accurately concentric, but that the grip isn't.
  • Country: nz
« Reply #4 on: March 21, 2010, 09:41:53 PM »
I have only one cut in the 'collet'.
« Reply #5 on: March 22, 2010, 02:21:27 AM »
Try putting the cut part way through, or two cut part way through from opposite ends 90 deg to each other.
Hope this helps
  • Country: nz
« Reply #6 on: March 22, 2010, 02:23:49 AM »
Thanks for all the comments and advice guys!  I am home now and just about to go down and try to check if the thread is true to the spindle axis.  The main part of this tool is stainless and I had a hard time cutting the internal thread.
