Author Topic: Whats Next? Smart Bolts  (Read 14419 times)
« on: March 15, 2010, 12:28:31 AM »
While out stumbling around on the Internet I Stumbled across this, Smart Bolts.
 http://www.smartbolts.com/?gclid=CKP-pu_xuaACFVl35Qod2Cz3Uw
Apparently you can tell just by looking at the bolt how much tension it is under. Could be a good idea but I bet they are expensive. I wonder if they make them in 2-56 size for our engines. :lol: :lol:
Re: Whats Next? Smart Bolts
« Reply #1 on: March 15, 2010, 03:22:37 AM »
..... I bet they are expensive. I wonder if they make them in 2-56 size for our engines. :lol: :lol:
You'd win your bet, Don. According to this review, about $20US each   :bugeye:
Fascinating idea, though.
Offline 75Plus
« Reply #2 on: March 15, 2010, 09:46:36 AM »
This brings up the question "How tight is tight?" Once the indicator turns black how do you determine if it is over torqued? I can see how it would be easy to over torque while using a socket which covers the indicator. Not all bolts of a certain size should be torqued the same. Torque depends on application.
These bolts are probably used by the government since it assumes we the people are too stupid to tighten bolts properly. It is also the only user that can afford them.
Joe
Offline chuck foster
« Reply #3 on: March 15, 2010, 10:05:41 AM »
how tight is tight  :scratch: :scratch:
my rule is tighten the nut or bolt till it breaks then back it off a quarter turn  :doh: :lol: :lol:
chuck  :wave:
skype:  aermotor8
former hmem member
Offline websterz
« Reply #4 on: March 15, 2010, 12:42:08 PM »
Can I get one of those installed in MY head to check MY stress level?  :borg:
 :med:
« Reply #5 on: March 15, 2010, 04:39:41 PM »
I've tuned and re-built quite a few engines over time and I've yet to use let alone own a torque wrench !!
And yes I "hammered" two of those engines for quite a few years after they were re-built, never a problem in the torque regard.
Offline Festus42
« Reply #6 on: April 12, 2010, 02:14:26 PM »
These look like a great idea, I will with hold actual judgement until I see actual test data on their accuracy. I can see these being useful in confined spaces where using a socket is not practical/possible. They could also be useful for field repairs where you may not be able to properly calibrate torque wrenches.
Offline Topos
« Reply #7 on: May 12, 2010, 01:15:44 PM »
chuck  :wave:
Now that is STRETCHING our credulity, mate!  Bet it will TORQUE someone off.  :)
