Author Topic: torsion springs, extension springs, compression springs, and finishing info  (Read 15038 times)
Offline PTsideshow
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
I'd like to add to Glenn's resources of spring makeing.
Brownell's Gunsmith Kinks book I and book II has spring making info in them.
These books may be gun related and not your cup of tea but they do contain many tips for the home shop machinist.
Offline PTsideshow
They also have a dvd on making flat springs that is also worth the money,it is for a gun part. But I have used it for other things. Brownell's  catalog and website has a lot of great stuff for the home shop person whether you are into firearms or not.
I will second his suggestion about them.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline PlanetSpring
    • Planet Spring
Re: torsion springs, extension springs, compression springs, and finishing info
« Reply #3 on: September 07, 2010, 05:41:22 PM »
Here are some calculators as well, that may help in the design process:
Compression Spring Calculator
Extension Spring Calculator
Torsion Spring Calculator
Springs are my thing!  :smart:
« Reply #4 on: September 08, 2010, 01:46:55 AM »
Planet Spring,
Your links are munged.  Try:
Compression Spring Calculator (http://www.planetspring.com/pages/compression-spring-calculator-coil-calculator.php)
Extension Spring Calculator (http://www.planetspring.com/pages/extension-spring-calculator-extension-spring-calculation.php)
Torsion Spring Calculator (http://www.planetspring.com/pages/torsion-spring-calculator-torsion-spring-calculation.php)
Also, when I did a quick check of compression springs, (A) you listed the spring constant (k) in psi rather than lb/in and (B) you list a "maximum possible load" (in lb/in rather than lb) that would compress the spring to solid height (not a good thing) rather than the normally recommended "maximum allowable load."  My copy of the Spring Design Handbook is packed away or I would provide the nominal compensation values for maximum allowable loads.
    • Planet Spring
« Reply #5 on: September 08, 2010, 01:42:01 PM »
Thank you for the info, Lew!!
 :doh:
I'm working on changing that :)
