Author Topic: Cone Centres  (Read 48382 times)
Re: Cone Centres
« Reply #25 on: December 31, 2009, 12:37:14 PM »
Thanks Lads
I finished off the larger cone centre today ,
and a couple of shots on the lathe for scale
Thanks for looking and i wish you all a HAPPY NEW YEAR
Regards Rob
Offline Trion
Re: Cone Centres
« Reply #26 on: January 02, 2010, 05:36:48 AM »
Very nice work and good looking cone centres! Clever idea to have the M6 hole aswell, I'm sure I'm going to use it sometime! :thumbup:
I'm still new to turning, but you have really made me see the advantage of having a proper TTA  :clap:
Happy new year!
Jon
Offline Gerhard Olivier
Re: Cone Centres
« Reply #27 on: January 02, 2010, 06:27:51 AM »
Very nice work there Rob as we have come to expect from you. :bow:
That m6 hole would allow you to make customized points for the tailstock should you need it?????
Gerhard
Guernsey
Channel Islands
Re: Cone Centres
« Reply #28 on: January 02, 2010, 09:13:39 AM »
Very nice tooling.
Now I've got to add that to the "round-to-it" list.
Offline Powder Keg
  • Machinist Extraordinaire
Re: Cone Centres
« Reply #29 on: January 02, 2010, 10:14:00 AM »
Nice Job!!! Almost too spiffy to use :lol:
Wesley P
Re: Cone Centres
« Reply #30 on: January 03, 2010, 06:11:57 AM »
Them's some nice looking bits of kit Rob..... Nice build log too (only just read it!)
I've no use for such myself right now, but have already figured where they would come in handy  :thumbup:
Yet another project to sit waiting in the back of my mind  ::)  :)
Re: Cone Centres
« Reply #31 on: January 03, 2010, 10:15:00 AM »
Thanks very much LADS for all your comments .
I no that i may only use these cone centres a  few times a year ,but when needed they are very handy (i just like making tools ) and others may not wish to go to the time to make them , This is what i used in the past ,very quick and fits on standard centre
Normal revolving centre
Drill a hole in a lump of stock say 12mm this is so you don't have to bore to a piont, then bore a 30 deg tapper ,to mach the centre
Spin it around and ruff turn the outer tapper what ever you fancy
Then stick a piece of bar in the chuck and face the end
Next fold a small piece of emery paper grit on the out side and mount the cone on the centre ,place emery paper between cone and bar in the chuch and lock up tight
Then using light cuts finish turn the cone
Used this one for years
Regards Rob
« Last Edit: January 03, 2010, 10:34:37 AM by Rob.Wilson »
