Author Topic: A little Sleeve Valve Engine  (Read 133487 times)
Offline jim
Re: A little Sleeve Valve Engine
« Reply #25 on: January 04, 2010, 01:49:41 AM »
excellent :clap:
Offline kvom
« Reply #26 on: January 04, 2010, 05:37:44 AM »
Great work.  Thanks for sharing.
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #27 on: January 04, 2010, 08:44:17 AM »
Very nice work there  :thumbup: :thumbup:
Tim
« Reply #28 on: January 04, 2010, 03:58:47 PM »
I'm pretty gobsmacked - the finish on those must be impeccable if the camera is not picking up machining marks that close up.  :jaw:
Offline Joachim Steinke
    • metallmodellbau.de
« Reply #29 on: January 08, 2010, 08:35:11 PM »
Hallo out there,
now it was time for  building the “cam”- and crankshaft. Actually this engine has no real camshaft in a classic way, so the thing which drives the sleeve is more a control shaft….
Both shafts are made from ETG100, a special steel with high mechanical properties combined with extraordinary good machinability. I like this stuff, the tensile strength is about  960 to 1100 N/mm2, but you can cut it like ordinary free cutting steel, it’s the perfect material for small and lightweight lathes and mills.
As my crank disk is relative thick (6.5mm) I could make a single, well fitted in crank pin (5mm diameter) which is glued into the disk with Loctite later. So I avoided the circuitous off-center operation and the extra fixture for the lathe.
Here we have all the related components before the assembling.
And here are all the bearings and gears already in place. The two gears are also glued with Loctite high strength on there precisely fitted shaft seats. I don’t have enough space for removable joints like a key combined with a shaft nut, but Loctite will do the job well.
And at last the whole assembly with the crankcase, the gears are smooth running and all is fitting well.
And today I started with the main cylinder. This component is made from spheroidal cast iron. Our German notation for this iron is GGG60, I don’t know if the name is common in the English language area too?
Grooving the cooling fins…..
and a little finishing work.
And now came the first fine machining of the cylinder bore with 400er grinding paste and an expanding lapping mandrel.
This is only a pre honing from the before turned 19.97mm up to now 19.99mm diameter, the final fitting with the sleeve (projected is 20.00mm) will be done after milling the cylinder ports and the frontal cut out for the sleeve drive.
Step by step the little engine looks more and more like a real motor….ha ha ha….
Good night from Achim
« Reply #30 on: January 09, 2010, 02:50:04 AM »
Stunning work Achim
 :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
Very well shown and described, I,m really enjoying this build.
Have fun
« Reply #31 on: January 09, 2010, 03:33:11 AM »
Achim......
That is beautiful........  :bow:
Offline spuddevans
    • My Photo website
« Reply #32 on: January 09, 2010, 04:04:09 AM »
 :jaw: :jaw:
Stunning
 :jaw: :jaw:
Tim
Offline ksouers
« Reply #33 on: January 09, 2010, 09:48:23 AM »
WOW!
Very meticulous attention to detail.
I'm in awe.
Kevin
« Reply #34 on: January 09, 2010, 04:13:32 PM »
 :jaw:
 :bow:
Just can't believe how nice that is!
« Reply #35 on: January 11, 2010, 11:22:45 AM »
Achim, I'm new to the forum and while totally enthralled by all the projects I've seen on it, yours is top notch, the machine work impeccable, the finish beautiful, and the detailed plans are something I'm not at all accustomed to.  I am going to start posting the work I'm doing on a radial engine I started working on about a year ago, but haven't figured out how to do all the posting and such on the forum, but I'm building from plans purchased, while you're building from your own plans, your expertise is showing through.  I look forward to seeing it run, and hearing the sound of it.
mad jack
« Reply #36 on: January 11, 2010, 08:59:43 PM »
Oh My! How did I miss this??
 :bow: :bow: :bow:
Wow... thats some AMAZING work.
« Reply #37 on: January 13, 2010, 09:32:42 PM »
Hallo,
first of all many thanks again for your lively interest and the versatile and very nice replies.
In the mean time I could work a little further on the sleeve and cylinder garniture. As the ball mounting needs a little backing material to enhance the rigidity at the circumference I had turned a shoulder on the end of the sleeve which now has to be milled away, sparing only a small piece for the balls base and the coming soldering. This recess is also reducing the sleeves diameter from 20.00 to 19.80mm going up to additional 2mm above the ball mounting base, so this whole area does not take part on the sleeve to cylinder fitting and does not jam the outer lapping operations too.
Then came the similar pre lapping work like I did on the cylinder bore, I went to 0.005mm below the end measure so I don’t have to do too much grinding after milling the ports out.
For the outer diameter I had made a little lapping ring from aluminium and I’m holding the sleeve on a special fixture which will be needed for milling the ports anyway.
My port layout is a compromise of the small engine scale, my machining abilities without using CNC and a relative short sleeve stroke, depending on the desired shortened design of the whole cylinder elevation and the avoidance of too much expansion of the gear housing width.
Also I had to place the sleeve ports sufficient enough above the cylinder heads compression ring, otherwise I would get problems with the sealing during the combustion cycle, what in fact is limiting the port height too.
So I’m up to rectangular ports now without the tricky elliptical arches Bristol did on there engines. Free formed arches are a little bit difficult on a non CNC mill and filing them by hand was no real option for me.
But in comparison to the usual poppet valves my free port sections are not so bad. Each port makes 8sqmm free width at maximum overlapping position, that means 24sqmm for the inlet and 16sqmm for the exhaust. Calculating a high performance cylinder head (for the same cylinder bore) with two poppet valves at 30deg inclination to both sides of the spark plug the free valve sections will be approximately 20sqmm for each valve. Even a spherical head with four poppet valves would produce no more then 27sqmm per side and it would be a very tricky task to get four dimensional optimized and functional valves into a 18mm diameter head.
But cutting a long story short, now it was time for the fiddly milling operation, the first one was the sleeve…..
……and at last the cylinder.
And here we see the collection of the fixtures and lapping mandrels I have used.
This is the intermediate result of the port milling job.
Next thing to do was hard soldering the little (4.8mm) connecting ball to the sleeves base.
To enhance the joint I made a 2mm pin from ETG which is well fitted to both holes. Things went very well, the silver solder is filling up the gap sufficiently and was even travelling along the pin to the countersink at the inner side.
After the final lapping and fitting operations of sleeve and cylinder I could assemble the moving components for the first time.
Port locations and timing are fully according to my calculations and the sleeve motion is very smooth an easy going. I made a running test on my high speed spindle and had no problems to go up to more than 8thousand rpm over a longer period. So the present results are auspicious for the further progress of this little project.
« Reply #38 on: January 14, 2010, 02:06:43 AM »
Stunning work again Achim, and wonderfully shown:-  :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
I'm beginning to understand how this engine will work.
Have fun
« Reply #39 on: January 14, 2010, 03:52:11 AM »
Yes, very nice Achim. What a complex engine, it will surely be quite unique.
Offline Gerhard Olivier
« Reply #40 on: January 14, 2010, 04:42:55 AM »
You are a master Achim    :bow: :bow:
Gerhard
Guernsey
Channel Islands
Offline crankshafter
« Reply #41 on: January 14, 2010, 11:25:50 AM »
Achim.
Thank you for the pictures and your whrite-up, amazing proj :jaw:ect.
You are a master-wizzard :bow: :bow: :beer:
Crankshafter
« Reply #42 on: January 15, 2010, 12:01:33 AM »
Achim
It certainly is a pleasure to watch this engine come to life from pieces of raw metal. Your design, machining and photography skills are amazing and a real joy to watch. I look forward to watching the balance of the engine take shape.  :ddb: :ddb: :ddb:
« Reply #43 on: January 16, 2010, 12:18:53 PM »
Hi Achim,  There is nothing in the world quite like the feel of a well lapped sleeve inside the part it was lapped to fit, and if there are several parts, all lapped together, the feel of all of them, in concert, is like knowing how it will run and sound before you get there.
    Your project is looking great, and the unique aspect of the sleeve valve design is not to be overlooked either, it is quite an achievement.  Can't wait to hear it run, great progress, despite all the jigs, fixtures and tooling having to be made.
mad jack
« Reply #44 on: January 16, 2010, 09:43:59 PM »
Good morning,
slowly the rest of the cylinder parts are growing.
Beginning with the head I could finally use this little self made tap for the first time. I got the smallest Rimfire spark plug with a NS 10-40 thread and these special and unusual taps are hard to get in Germany. So I turned and milled one from ETG and then hardened, tempered and grinded it at last. It does the job very well.
The following components are the last one to make from spherical cast iron. First I made the piston ring blanks which are 1mm high and 0.75mm width.
After parting them off they where put aside and will be divided, expanded and finally tempered in the next days. And the remaining piece of the cast iron blank was used to manufacture the piston.
As the engine has ports like a 2-cycle motor I have to fix the piston rings, so they can not come in conflict with the windows. For the installation of the little fixing pins I had to mill 1mm holes near the ring shoulder.
The lapping of the piston and the final fitting to the sleeve was made directly on the material blank, so I did not need an extra fixture for this job. After that the piston could be parted off.
To prevent the piston pin from sliding sideways I cut a little v-grove at each inside of the bore. The 4mm pin will be held by small snap rings made from 0.5mm wire.
And at last most of the vitally components are ready now.
Now the whole apparatus becomes more and more affinity with a real motor.
I could say that the lapping and fitting work was a real success. All components are sliding easy and free, a longer lasting running test with more than 8tousand rpm on my high speed spindle was no problem at all.
Even without the piston rings assembled the engine has a strong compression, I’m not able to turn it over the TDC at compression cycle on the naked 6mm crankshaft. For easier testing and handling I made the little brass cylinder, the real flywheel has to be build in the next days.
Good night and a nice weekend from Achim
« Last Edit: January 16, 2010, 09:47:52 PM by Joachim Steinke »
« Reply #45 on: January 17, 2010, 04:24:31 PM »
Wow, this really is a work of art and beginning to take shape nicely! A homemade tap too - something I've not seen before.
Nick  :bow:
« Reply #46 on: January 17, 2010, 09:40:27 PM »
Hi,
in the mean time I got through with the piston rings.
As you might remember I had turned and parted them already, now they must be divided, widened and tempered to get the right working tension.
As the grooves in piston and head are 1.05mm wide and the parted rings are exactly 1.00mm thick, I don’t have to grind there flat face for a final fitting, 0.05mm clearance will be just right for this dimension. So I just removed the tiny burrs left from the parting operation on a very fine grinding stone. With a round 1mm needle file I cut the slot for the fixing pins and then the rings where divided with a small and sharp chisel on a flat steel plate.
Being too lazy to make a special fixture for the widening operation I put the rings (I finish only 2 of the 8 prefabricated in the moment) on a little steel plate, brought the 3mm distance pieces in the gap and set a little clamp on the whole assembly. For the heating I like to take my small muffle furnace, unfortunately it has no temperature control and for stress relieve the temperature should better not go further than 600, max. 650deg Celsius.
For that reason I put the whole fixture in a small steel ash tray and filled it with dry sand.
The sand allows me to control the temperature quite easy. After the first heating up time I took the tray out about every 5 minutes and measured the temperature inside the sand, reaching approximately 600deg Celsius the whole thing was done and I let cool it down slowly. As the sand buffers the heat very well the rings get the additional needed stress relieve time outside the furnace, but without the possibility of overheating.
This are the two now finished rings, the rest will be kept for “any case of emergency” to come….ha ha ha….
The engine is running fine with both rings assembled and the compression is real strong now.
I have made two videos of the semi open engine so you can have a look at the moving parts and the rotating ports. But the quality is not that good, I don’t have a high resolution video camera at the moment and had to take them with my Canon IXUS instead.
http://pl-hi.de/JST/SLVE/JST_SLVE_RT_01.mpg
http://pl-hi.de/JST/SLVE/JST_SLVE_RT_02.mpg
« Reply #47 on: January 18, 2010, 02:27:16 AM »
Great piston valve action Achim
 :headbang: :headbang: :headbang: :headbang:
Thanks for showing
« Reply #48 on: January 18, 2010, 03:46:34 AM »
Now..... That`s mesmerising!  :clap:
« Reply #49 on: January 18, 2010, 04:23:16 AM »
Wow, never seen anything like it! This is like model engine pornography  :lol:
Shame you won't see all that motion when it's built together!
