Author Topic: Three Cylinder Radial Engine  (Read 161169 times)
Re: Three Cylinder Radial Engine
« Reply #75 on: December 22, 2009, 12:18:01 PM »
Well this post is going to be a tail of Triumph over near Disaster.
Made a start on the crank shaft, drawing calls for a solid one piece crank shafts, all crank shafts I've made to date have been fabrication, but this being a one throw crank shaft I thought i'd make it in one as the drawing.
Ok first part using a 3" long bit of 32mm dia free cutting mild steel turn the main journal 3/8" dia.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3086.jpgThree Cylinder Radial Engine
Turn it round in the chuck and drill a 2.5 mm hole 2" deep for the oil way.
Centre drill then a jobber 2.75 mm then finish off with a 2.5 mm long series drill, drilling part way with an over size drill gives a bit of clearance for the swarf reducing the chances of it clogging and breaking, also keep clearing the drill back:- job done.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3098.jpgThree Cylinder Radial Engine
OK turning the offset for the crank.
Plan A :-
Mark off set with a small centre pop then with a pointed bar in the centre pop clock the bar up turn dia.
Marking out
Mark centre line and set centre line vertical
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3093.jpgThree Cylinder Radial Engine
Touch on top of bar
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3088.jpgThree Cylinder Radial Engine
Bit of maths
Mark position of off set
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3090.jpgThree Cylinder Radial Engine
Centre pop and her we have it in four jaw ready to be set up.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3101.jpgThree Cylinder Radial Engine
At this point tried getting it roughly set on the bench, and realized that with one jaw set over the next two jaws wouldn't close down, the diameter was too small.
Ok plan B. Make a bush with a 3/8 bore clamp the crank shaft with a grub screw positioned in a none important place (grub screw would mark the shaft) then I remembered that if you put a packing piece between the job and the chuck jaw you could get the off set, so decided thats what I would do.
Her we have the bush on the shaft with the packing piece.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3105.jpgThree Cylinder Radial Engine
And job part turned
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3107.jpgThree Cylinder Radial Engine
OK spotted the deliberate mistake.
 :doh:
I'm using a three jaw, the geometry is all changed I used a 1/4" packing piece to get a 1/4" throw I should have used a bit of trig and worked out a thicker bit of packing or used a self centering four jaw.
A quick check and phew I still had enough meat left to get the job done.
Plan C:- well back to plan A really but using the sleeve to give more of a diameter to grip on.
Still had the off set marked with a centre pop on the bar end.
So her we are clocking it up
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3110.jpgThree Cylinder Radial Engine
And part cut:-  interesting shape with the near mis not quite cleaned away.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3112.jpgThree Cylinder Radial Engine
1/4 dia turned and drilling the oil way.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3113.jpgThree Cylinder Radial Engine
Turned crank
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3118.jpgThree Cylinder Radial Engine
And in the housing
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3117.jpgThree Cylinder Radial Engine
Well that came out all right in the end I'm sure glad I did a quick check as to how the throw was coming out when I did.
« Reply #76 on: December 22, 2009, 12:31:53 PM »
Stew,
Once again, you can say you`ve had a good day.   :thumbup:
All`s well, that ends well........  :wave:
« Reply #77 on: December 22, 2009, 01:33:03 PM »
Stew, you've already made a nice job of it, but if you ever do need to offset something in a 3-jaw, the formula is
Offset = 2/3 shim thickness. So, to get a 10mm offset you need a 15mm shim.
I didn't work it out for myself  :smart:. It's explained towards the bottom of this page: http://homemetalshopclub.org/news/aug03/aug03.html
« Reply #78 on: December 22, 2009, 02:03:28 PM »
Thanks Andy :thumbup:
Thats filed away in my little black book.
Great link by the way.
Have fun
« Reply #79 on: December 23, 2009, 03:55:30 AM »
Stew,
Well done with that, you've done a great job there.
I thought about doing the same for the offset in the 3 jaw. I would have used 1/4" packing for 1/4" throw too - will have to look at Andy's link to find out why it's not!
I hate doing those, just hate the interupted cut - what size cuts did you take, did it take long? Maybe I had the speed too low.
I did it with a split bush on my rocking engine as remember the hassle I had using the 4 jaw on my stirling. But I drilled the offset hole in the bush in the milling machine and it must have wondered off because my crank disc wasn't uniform thickness.
Was the main dia. of the crankdisc part too thin to grip on in the 4 jaw?
« Reply #80 on: December 23, 2009, 04:29:43 AM »
Hi Nick
For plan A I used a 5/8" square HSS tool with a speed of about 350 rpm feed about 0.01mm and a cut of 0.5mm:- for plan C I used a tpmr TC tool same speed and feed but a cut of 0.75 mm, when doing jobs like that I just listen to the complaints from the machine when it looks and sounds happy I keep to that recipe, ( treat it like a woman  ::)) I don't try and rush things, to turn the offset took me about 3 hrs with all the messing about.
« Reply #81 on: December 23, 2009, 04:32:01 AM »
Cheers Stew, will bear this in mind next time!
« Reply #82 on: December 23, 2009, 07:23:48 AM »
Managed to steel a bit of time in the shop this morning and finish off the crank.
Blued the web up and set it up in the spin indexer, then by using my height gauge touching on the web then with a bit of calculation set the crank up so it was on centre line.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3119.jpgThree Cylinder Radial Engine
Then using the indexer and the height gauge marked out the web.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3122.jpgThree Cylinder Radial Engine
First bit of machining indexer rotated to bring the crank vertical and drill the oil way.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3124.jpgThree Cylinder Radial Engine
Then with a nice big milling cutter hack out the web shape.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3125.jpgThree Cylinder Radial Engine
Then mill the flats to drive the valve crank. By rotating the indexer 180 the flats came out nice and symetrical on the crank.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3128.jpgThree Cylinder Radial Engine
A quick debur  and thats it done just need to plug the oil ways up.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3136.jpgThree Cylinder Radial Engine
« Reply #83 on: December 23, 2009, 09:42:18 AM »
Nice crank there Stew. That spin indexer has come in handy. I was showing one of the apprentices here some of your indexer pics a couple of days ago to explain some of his college homework!
« Reply #84 on: December 24, 2009, 04:48:04 AM »
I'm pleased that my pics were used to help a young chap with his education.
Got the fly wheel completed, the drawing calls for a cast iron flywheel but I'd got some suitable brass and I also like making composite brass ally fly wheels.
So first job make the hub I'd got a bit of ally the correct diameter but it was a bit on the thin side to chuck and part off, so I put a hole down the middle of it and held it on a loose mandrel to turn up the OD.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3085.jpgThree Cylinder Radial Engine
Then stuck it into the middle of this chunk of brass, I found quite a few bits like this down the scrap yard.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3141.jpgThree Cylinder Radial Engine
The fly wheel is held on the crank using a split tapered collet. so to make the collet, swing the compound over to 5 deg (10deg inclusive) and turn the taper, then put a 3/8" dia drill down the middle, and part off.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3140.jpgThree Cylinder Radial Engine
Then don't move the compound, keep it set.
Chuck up the fly wheel, flip the boring bar upside down, and working at the back, bore the taper in the hub, because nothings bin moved the tapers will match perfectly.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3142.jpgThree Cylinder Radial Engine
Skim up the OD of the fly wheel part off and face the other end.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3143.jpgThree Cylinder Radial Engine
Split the tapered collet and her are all the bits for the fly wheel completed.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3149.jpgThree Cylinder Radial Engine
This is how it looks
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3144.jpgThree Cylinder Radial Engine
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3147.jpgThree Cylinder Radial Engine
Thats all the outside bits of the engine done just the innerds to do now.
I guess thats all until after Christmas
So I'd like to wish you all and your families a very merry Christmas.
Have fun
« Reply #85 on: December 24, 2009, 05:41:44 AM »
Stew,
That engine`s looks improve almost every time I log on!  :clap:
Here`s wishing a Very Merry Christmas, to you & yours.  :thumbup:
« Reply #86 on: December 24, 2009, 07:26:00 AM »
That look great Stew   :bugeye:   :thumbup:
Gonna be good to see it running  :)
Hoping you have a great Xmas season....
I'm just planning to spend time in the 'shop! I've a whole week and a bit off...... Got to try to do something!
Take it easy,
Ralph  :beer:
« Reply #87 on: December 24, 2009, 11:35:37 AM »
Looking real good Stew.
I like your split collar method of attaching the flywheel. But the upside down boring bar makes my stomach a bit queezy.  :lol:
And a Merry Christmas to your too.
Hey Ralph, you ever going to finish your Aeolipile? (sp?)  :D Ya, I know  :offtopic:
« Reply #88 on: December 25, 2009, 05:49:48 AM »
That's excellent Stew. I like that method of fastening a flywheel. in fact I was going to try it on my engine last night with a lighter flywheel. Engine is looking great.
Merry Christmas to all.
« Reply #89 on: January 04, 2010, 12:51:28 PM »
Happy new year Chaps
I bet you thought I'd given up on this. Spent new year St Ives a Cornish fishing village/town, made a complete fool of myself by joining in the fancy dress party that the town holds, got a little bit tipsy dressed as a red indian (must have been the fire water).
Any way on with the build:- con rods.
First job draw the rods out in cad and dimension the key features from the centre line of the big end bearing, then cut some plate to size, for the rods important to get all the bits the same size as it will help help in doing all three with the same set up.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3158.jpgThree Cylinder Radial Engine
Then set up in the mill bringing the vice stop into play then drill big end zero the DRO in X and Y and then drill other holes, repeat, repeat.
Her we have them all drilled.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3162.jpgThree Cylinder Radial Engine
Put a couple of same size rods through the web holes sit them on to a couple of parallels, tighten up the vice remove rods and parallels.
and chew out the meat.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3164.jpgThree Cylinder Radial Engine
Fit the big ends with 1/4" phosphor bronze bushes, the little ends are also drilled 1/4" (that I will bush later) and make a 1/4" mandrel, one mandrel will do both ends.
Then fix on mandrel and thin the webs.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3167.jpgThree Cylinder Radial Engine
Flip over and locate on the other end and thin the other side.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3168.jpgThree Cylinder Radial Engine
Then with the mandrel held in a collet on the rotary table round the ends off.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3174.jpgThree Cylinder Radial Engine
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3177.jpgThree Cylinder Radial Engine
There we are done they just need a tickle with a file to tidy up.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3178.jpgThree Cylinder Radial Engine
The centre con rod is at the back in this pic with the two off set rods in the fore ground.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3183.jpgThree Cylinder Radial Engine
Have fun
« Reply #90 on: January 04, 2010, 01:15:11 PM »
Nicely done and shown Stew...... As usual!  :thumbup:
And a Happy New Year to you and yours!  :wave:
« Reply #91 on: January 04, 2010, 04:06:29 PM »
Wow,  :bugeye:
You did those con rods so well I've just thought of a genius nick name for you - Rod Stewart!  :lol:  :doh: never mind!
Seriously, they are really impressive, everything seems churned from the solid on this! Looking good.
Offline Powder Keg
  • Machinist Extraordinaire
« Reply #92 on: January 04, 2010, 08:40:18 PM »
Nice job on the rods Stewart :lol:
Wesley P
« Reply #93 on: January 07, 2010, 12:10:30 PM »
Made a start on the pistons over the last couple of days. The first thing I did was to hone the cylinders sp that I would have a final size to work with, I used a flexie hone with plenty of oil, I didn't go over board with the honing just a quick lick up and down for about 10 seconds, but it was enough to produce a nice smooth bore.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3186.jpgThree Cylinder Radial Engine
Then used this new toy to give the cylinders a good clean, its a lidle ultrasonic cleaner on offer for £20:- Great for cleaning glasses and false teeth, wanted to try it out on Mother in-laws teeth, but the miserable old bugger wouldn't let me.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3187.jpgThree Cylinder Radial Engine
Then I carefully measure the bores they were all within 0.02 mm and kept a not with each one of their size.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3188.jpgThree Cylinder Radial Engine
The turned down a chunk a window sash weight and drilled and bored the ID.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3189.jpgThree Cylinder Radial Engine
Then I wanted to try out my home made tool post grinder to get a nice finish on the OD of the cylinder, it took me a good bit of time and a lot of 13 amp fuzes (don't ask  :zap:) to wire up the new toggle switch I'd bought for it.
But it worked a treat got a nice finish on the cast iron and a nice fit.
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3191.jpgThree Cylinder Radial Engine
This is two ground up and just sitting nicely in the bore, the third is still on the bar waiting to be parted off:- thats a job for another day
http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/100_3194.jpgThree Cylinder Radial Engine
Have fun
« Reply #94 on: January 07, 2010, 01:46:09 PM »
Stew,
Looking great, I bet with that flexi hone and grinder you have got an amazing fit there. Very nice. That ultrasonic cleaner is a bit posh too, did it work well?
« Reply #95 on: January 07, 2010, 01:53:20 PM »
Thanks Nick
The ultrasonic cleaner worked great, you can use plain tap water or add a few drops of washing up liquid for real dirty bits. They can be too good caused a lot of problems with fuzes the parts were too clean to function, ended up adding a small amount of oil to the liquid to put a bit of slip back in the system.
Have fun
« Reply #96 on: January 07, 2010, 04:08:11 PM »
Very nice Stew  :thumbup:  looking great  :clap: :clap: :clap:
Regards Rob
« Reply #97 on: January 07, 2010, 05:06:08 PM »
Stew, do you think the ultrasonic cleaner would be good enough to clean up old watch and clock movement parts? I know you can pay hundreds for them and appreciate they probably wouldn`t compete with those but do you think they would do something or at least worth the £20 you paid for that sort of thing?
« Reply #98 on: January 07, 2010, 05:31:58 PM »
Hi Chris
I think it would be OK for watch and clock parts, although I wouldn't recommend using it on an expensive watch, it comes supplied with a basket that keeps the movement clear of the liquid whilst you clean the steel bracelet in fact I used it to clean the bracelet of my watch, it did a good job. I got it from Lidles who currently have them on offer, so far I'm happy with it.
Hope this helps
Offline Powder Keg
« Reply #99 on: January 08, 2010, 10:44:03 AM »
Looking good Stew!!
Wesley P
