Author Topic: Tailstock Die guide  (Read 28518 times)
Re: Tailstock Die guide
« Reply #25 on: November 18, 2009, 12:37:14 PM »
(1)  1/5 = 0.020 ??  :scratch:
(2)  Surely the formula only applies to a 60 deg screw thread ??
Dave BC
Offline mklotz
  • LA, CA, USA
« Reply #26 on: November 18, 2009, 12:47:19 PM »
Whoops! (I've fixed it.)
Yes, it applies to a 60 deg thread.
Regards, Marv
Home Shop Freeware
Russel
« Reply #27 on: November 18, 2009, 10:32:47 PM »
Well, I didn't have anything to thread the test part into until today. I had to tap a hole 5-40 today on a project I'm working on and decided to try the test threads out. Very nice fit, I'm happy about that. When I cut the male threads on the test part I threaded the 5-40 die split screw until it just touched the other side of the split, then gave it an additional quarter turn. Looks like that turned out about right.
« Reply #28 on: November 19, 2009, 01:12:27 AM »
Great job Russel and well shown :thumbup:
In your last post it looks like a part for a radial your making there  :worthless:
:D
Have fun
Russel
« Reply #29 on: November 19, 2009, 02:44:50 AM »
Yep, Elmer's engine number 11
http://www.john-tom.com/html/ElmersEngines.html
I took Bogs advice and started with I thought was the most difficult part to machine. 18 2-56 drilled and tapped holes done and only 6 left to go on this part. You can read more about it on HMEM.
http://www.homemodelenginemachinist.com/index.php?topic=6620.0
« Last Edit: November 19, 2009, 02:47:27 AM by Russel »
Offline Gerhard Olivier
« Reply #30 on: November 19, 2009, 03:35:32 AM »
Nice result Russel
If you can thread silversteel/drillrod you can thread anything.
Gerhard
Guernsey
Channel Islands
