Author Topic: Long Reach Drill  (Read 28991 times)
Offline 75Plus
Long Reach Drill
« on: October 31, 2009, 03:08:21 PM »
I did a search but did not find anything like this so here it is.
Ever need to drill a hole that is in some inaccessible location for the drill length you have? This is how an old tool and die maker taught me to do it.
Start with a suitable piece of round stock. (This one has been turned down for a 1/4" drill.)
Chuck it up in the lathe and, using the drill you intend to drill the needed hole with, drill the RS about 1" deep.
Now file or grind a slot approximately 3/4" from the end and half the diameter of the RS exposing the end of the hole. Poor picture BTW.
Now file a flat on the end of the bit so that it laps over the end of the hole.
After drilling the desired hole the drill bit can be removed and returned to the index and the extension can be saved for another project. I have several extensions that I made about 25 years ago. They have been handy many times over the years.
Joe
Re: Long Reach Drill
« Reply #1 on: October 31, 2009, 03:55:34 PM »
75Plus
Wow, that's one of those "why didn't I think of that" moments. :doh:
Thanks for posting that. I am sure that many here will use that one in the future. :ddb: :ddb:
Offline chuck foster
« Reply #2 on: October 31, 2009, 04:00:04 PM »
i have made extensions but i always silver soldered the drill bit it place.................i like this idea much better  :thumbup: :thumbup: :clap: :clap:
chuck  :wave:
skype:  aermotor8
former hmem member
Re: Long Reach Drill - Again
« Reply #3 on: June 09, 2010, 02:48:13 AM »
I am going to refresh this topic to bring it to the top to allow more of the newcomers to stumble over it and see what kind of response it gets.  :doh:
« Reply #4 on: June 09, 2010, 06:22:49 PM »
Thanks Don for refreshing this topic ,,i missed this one  :thumbup:
Joe thanks for showing the top tip  :clap: :clap: :clap: :clap: well worth remembering , better than brazing the drill bit into the rod as i have be doing , when i had to dill the throat plate on my traction engine boiler
Cheers Rob
Offline ieezitin
« Reply #5 on: June 09, 2010, 06:28:42 PM »
Great!. And it really works
We need a thread started with just little tricks like this, so people can just add there little tricks and knowledge.
What happened to tool & die makers anyway?…  oh that’s right they followed the Dodo off the cliff.
Anthony.
Offline ieezitin
« Reply #6 on: June 09, 2010, 06:33:14 PM »
Rob.
Nice welding on that Sch40 pipe. Are those real rivets if not how did you get that effect? What did you use?.
Thanks Anthony.
« Reply #7 on: June 09, 2010, 06:44:12 PM »
Rob.
Thanks Anthony.
Photoshop   :poke:
John S.
« Reply #8 on: June 09, 2010, 06:52:59 PM »
Hi Anthony  Thanks
Yep they are real riveted boiler stays ,, screwed in first then riveted over  .
John ,,,,,,,,one day   :lol: :lol: :lol: :lol:
I knocked this up to do my reverting  ,,,,,,,quieter than me air hammer
Cheers Rob
Offline ieezitin
« Reply #9 on: June 09, 2010, 07:32:51 PM »
Rob.
I started my apprenticeship back in 79 got out in 84, they taught me how to rivet with the form and hammer, but I never in the real world done it. All cleats and high tensile bolts then and now.
Wonderful I like those pics. Considering the Titanic was plate and rivets construction and was water tight that form of bonding  was a superior and effective technique.
Your rivet driver is superb. Well done sir.
John S.   must be Photoshop 3-HD.
Offline No1_sonuk
« Reply #10 on: June 10, 2010, 08:06:47 AM »
LOL "Titanic" in the same sentence as "water-tight", "superior" and "effective"...  :lol:
« Reply #11 on: June 10, 2010, 08:10:19 AM »
My granddad built the water tight doors for that boat.
John S.
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #12 on: June 10, 2010, 08:34:36 AM »
John S.
It's true, My granddad watched him do it.
Tim
« Reply #13 on: June 10, 2010, 09:35:31 AM »
John S.
Tim
Neither of 'em thought to query the cat-flaps then ??
Dave BC
Offline No1_sonuk
« Reply #14 on: June 10, 2010, 02:17:11 PM »
 :offtopic: It wasn't the watertight doors that were the problem.  It was the skylights at the top of the walls!
Paradoxically, some people believe the ship could have stayed afloat longer if the WT doors were open.
Offline fatal-exception
« Reply #15 on: August 20, 2010, 06:07:33 PM »
That's a great idea, BUT maybe I'm missing something here....how does the drill lock axially into the extension? Wouldn't the drill tend to pull out of the extension when retracting?
« Reply #16 on: August 20, 2010, 06:42:22 PM »
It's because it works in a time / space environment bubble.
You start drilling on October 31, 2009 when the first post was made and by today it's forgotten which way it was turning so it also forgets to fall out.
simple innit?
« Reply #17 on: August 21, 2010, 10:51:16 AM »
Fatal -- For this set-up to work well, the bore in the extension shank needs to be a close fit to the shank of the drill bit.  The chisel-edge ground at the butt of the drill bit not only locks it radially, it also jams the bit in the bore.  My experience with such things is that you need to "drift" the bit out of the extension shank in a manner not dissimilar to removing a Morse Taper bit.  Does that clarify things?
Offline 75Plus
« Reply #18 on: August 21, 2010, 12:23:15 PM »
simple innit?
Perhaps I missed it but I cannot find the rule setting the length of time before a "How To' becomes a "Don't Bother".
Can anyone point it out to me?
Joe
« Last Edit: August 21, 2010, 12:25:24 PM by 75Plus »
Offline crabsign69
« Reply #19 on: August 23, 2010, 01:39:58 PM »
here is one i made and boy did it work good and it did not come out  i had to get a punch and remove the drill bit from the tool holder
i cut everything at an angle the bit and the tool and its works very good :thumbup: :mmr:
« Reply #20 on: August 23, 2010, 05:17:54 PM »
Ok, Thanks Lew, I had a feeling like it didn't have anything to do with a time/space bubble, as not many things related to machining do...   :whip:
Anyways, I think I'll make a small one and throw it in the drill index so I don't forget...
