Author Topic: Slimline Rotary Table 150mm/6 inch  (Read 64588 times)
Re: RDG new Slimline Rotary Table 150mm/6 inch
« Reply #25 on: October 13, 2009, 02:11:27 PM »
I have a 4" Vertex sat infront of me now!    :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb:
Just need to figure out how I`m going to mount my boxford 4" pratt 3 jaw to it  :coffee:
« Reply #26 on: October 13, 2009, 02:49:05 PM »
Weld it on ?
Offline Jasonb
« Reply #27 on: October 13, 2009, 02:53:52 PM »
Chronos do an MT2 adaptor with a Boxford thread to fit the Vertex
Jason
« Reply #28 on: October 13, 2009, 03:00:50 PM »
Don't be lazy, make one ...... be good practice  :thumbup:
http://madmodder.net/index.php?topic=1390.0
« Reply #29 on: October 13, 2009, 04:06:10 PM »
Weld it on ?
Is that a serious suggestion? I can imagine making the jaw a perminant fixture would impede some alternative uses of the RT???
Jason, thanks for the suggestion, I had seen these but with the myford at £12 and the boxford at £35, I wasn`t willing to pay that. Thanks for the link Darren. It could very well be my next project.
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #30 on: October 13, 2009, 04:34:37 PM »
I cant believe no-one else has said this......
 :worthless:
 :lol: :lol:
Tim
« Last Edit: October 13, 2009, 04:43:56 PM by spuddevans »
Offline spuddevans
    • My Photo website
Re: Slimline Rotary Table 150mm/6 inch
« Reply #31 on: October 13, 2009, 04:46:23 PM »
Weld it on ?
I think John Stevenson is just pulling your leg  :thumbup:
Tim
« Reply #32 on: October 13, 2009, 04:51:49 PM »
lol - it isn`t even setup on my mill yet. It is currently on the kitchen work surface so Mrs Craynerd is  :whip: to shift it. I`m just trying to get my head around it ... 360 deg, 60 mins, 60 seconds. ....  90:1 ratio so 1 rotation of handle is 4 deg ... yes yes..
So say I want to cut 14 holes around a diameter, 360/14 = 25.71428...
I`ve been trying to figure this out all day, but since the RT is not split in decimals but deg, mins, secs .... how can you convert it? I`ve found a little calculator online that will do it, but I`m struggling getting my head around the maths!
EDIT:
Just found this:
Here's How:
The whole units of degrees will remain the same (i.e. in 121.135° longitude, start with 121°).
Multiply the decimal by 60 (i.e. .135 * 60 = 8.1).
The whole number becomes the minutes (8').
Take the remaining decimal and multiply by 60. (i.e. .1 * 60 = 6).
The resulting number becomes the seconds (6"). Seconds can remain as a decimal.
Take your three sets of numbers and put them together, using the symbols for degrees (°), minutes (‘), and seconds (") (i.e. 121°8'6" longitude)
« Reply #33 on: October 13, 2009, 04:52:41 PM »
Weld it on ?
Tim
I guessed  :poke: :poke: :poke:
Offline mklotz
  • LA, CA, USA
« Reply #34 on: October 13, 2009, 05:05:39 PM »
Chris,
Download the ROTARY program from my page and it will do all the dirty work for you.  As an example, here's the program output for your example of 14 divisions.
Code: [Select]
Number of divisions = 14
DIVISION      degdec     deg     min     sec
       0      0.0000       0       0       0
       1     25.7143      25      42      51
       2     51.4286      51      25      43
       3     77.1429      77       8      34
       4    102.8571     102      51      26
       5    128.5714     128      34      17
       6    154.2857     154      17       9
       7    180.0000     180       0       0
       8    205.7143     205      42      51
       9    231.4286     231      25      43
      10    257.1429     257       8      34
      11    282.8571     282      51      26
      12    308.5714     308      34      17
      13    334.2857     334      17       9
      14    360.0000       0       0       0
Regards, Marv
Home Shop Freeware
« Reply #35 on: October 13, 2009, 05:10:40 PM »
Thanks Chris for the explanation, that really clears it up for me as I had no idea  :thumbup:
And Marv, I'm off to collect your program  :bow:
« Reply #36 on: October 13, 2009, 05:17:54 PM »
Thank you for the software Mklotz -certainly makes things easier!   :thumbup: :thumbup:
lol, I`ve just spent ages opening up the program, putting in the number of divisions and hitting return and the program vanaishing! What it is not working  :doh: only to find the rotary.out document waiting for me with the "answers".
Still don`t get the maths in the conversion but right now got a headache so will have to wait for another time!
Darren, finally something I said of use lol
« Reply #37 on: October 13, 2009, 05:23:49 PM »
From Marv's main page................
 If you're too lazy to read this introduction, at least read the last four paragraphs so I don't have to waste my time answering questions already answered here.
A number of DOS-challenged users of my programs have written to complain that when the program terminates, Windoze, in another one of its mis-guided attempts to think for the user, closes the window before they can inspect the answers generated by the program. Dave Wood has spent some time working out how to keep Micro$oft's abortion from trying to outthink the user. He writes:
In Explorer, right-click on the .exe program name. Select "Properties". Select the "Program" tab. At the bottom of this dialog is a single check-box "Close on exit". Un-check this box. At the bottom of the dialog click on "Apply," then "OK".
Offline mklotz
  • LA, CA, USA
« Reply #38 on: October 13, 2009, 05:34:40 PM »
Gee, when the program runs it prints out the following advisory:
Your data is on: ROTARY.OUT
Is there some way I could make it more obvious?
I see that John has already advised you, should you use other of the programs, to read the Introduction on the page, lest I reach through the tangle of internet cabling, out your monitor, grab you by the neck and thoroughly throttle you.
Just kidding.  Like Sir John, I'm a real pussy cat.  Nevertheless, program users are well advised to read the Introduction.
Regards, Marv
Home Shop Freeware
« Reply #39 on: October 13, 2009, 05:38:38 PM »
lol  :lol: mklotz - I did find it in the end by reading your home page, all be it after I had made a few attempts!
No there is no way of making it clearer - it just takes an eager fool a little time to realise! I have just checked it again mklotz, and I do not get any message like you said. There is something that looks to flash up but vanished within an instant. Anyway, I did get it in the end!
Offline mklotz
  • LA, CA, USA
« Reply #40 on: October 13, 2009, 05:41:42 PM »
The reason you're not seeing the message is discussed in
wait for it
THE INTRODUCTION
You need to do what's advised there.
Now, lean forward closely toward the monitor so I won't have to reach so far. :-)
Regards, Marv
Home Shop Freeware
« Reply #41 on: October 13, 2009, 05:52:13 PM »
 :smart:
Quote: Dave Wood has spent some time working out how to keep Micro$oft's abortion from trying to outthink the user. He writes:
I just went through all that to see : Your data is on Rotary.out  ???
I`m sorry Marv, Ì`d taken the context of your introduction wrong - I`d taken it to mean that you don`t need to do that. As though someone had thought the program was closing without giving the output and so you had to do that to stop it closing.... :zap:
Anyway, this is all irrelvent, I was sucessfully using the programme after 5 minutes of downloading it ..... many thanks  :thumbup: :thumbup:
« Last Edit: October 13, 2009, 05:53:56 PM by craynerd »
Offline mklotz
  • LA, CA, USA
« Reply #42 on: October 13, 2009, 06:10:30 PM »
In the case of this program, yes.  However, understand that a number of the other programs write their output directly to the screen (as opposed to a file) and you would never see such output if you didn't disable the close-on-exit "feature".
In general, if the program generates only a single number or two, it writes that information to the screen.  If it produces complex output or tables (as is the case with ROTARY) that need to be printed and carried to the shop, the output is written to an ASCII file.  Since these files are ASCII, you can load them into any editor and annotate them with your own commentary before printing them for the shop.
Regards, Marv
Home Shop Freeware
« Reply #43 on: October 13, 2009, 06:12:04 PM »
Thanks - excellent programme!
« Reply #44 on: October 27, 2009, 07:03:46 PM »
I`m looking for the Dividing Set Plate for the 4" Vertex but unfortunately all the usual suspects RDG, Arc Euro and Chronos are out of stock. Does anyone know anywhere else I could try or any other sets that would fit the vertex, for example Chester sell a set for their RT and it is more expensive but don`t know if it will fit the vertex.
I`m really hoping to get a set within the next few weeks so any suggestions to alternative suppliers greatly appreciated.
Offline Jasonb
« Reply #45 on: October 28, 2009, 03:34:10 AM »
Engineers Toolroom have them listed
http://www.engineerstoolroom.co.uk/milling_accessories.htm
Jason
« Reply #46 on: October 28, 2009, 03:43:43 AM »
Jason, thanks for the sugestion, I`ve never used them but they are listed for the 6" hv6 and not the hv4 - it could be the same. I`ll ring and ask later.
« Reply #47 on: October 28, 2009, 05:32:53 PM »
I couldn`t get through today and want to order this asap. Does anyone else know if the 6" dividing set is the same one as the 4" only looking at RDG website and although it is out of stock it does say: VERTEX DIVIDING FOR 4" & 6" VERTEX ROTARY TABLES -  THIS DIVIDING SET FITS, HV4, HV6, VU100, VU150
I`m taking it that it will only I have also found Warco selling them for £35
http://www.warco.co.uk/Dividing-Plate-Set-for--HV6-49C5EE5C31.aspx
Anyone ordered from Warco before, are they OK in terms of delivery times?
Offline colin563
« Reply #48 on: October 28, 2009, 05:47:28 PM »
i know the dividing plates come with the hv4 & hv6 from warco
i got the hv4 from warco also the tail stock at the midlands show
 not sure how it all works yet ?
i will get round to that when i need it
colin
« Reply #49 on: October 29, 2009, 12:06:57 AM »
Just go ahead and buy it from Warco.
It should fit perfectly, but even if it doesn't, a little bit of tweaking with an axe and angle grinder will soon have it doing the job it is intended for.
But prepare yourself for the mental onslaught when you come to use it. It is a read, understand, and inwardly digest exercise, that only yourself can carry out. It is easy once you can get the rhyme and reason sorted out.
Also when using a dividing head, it is purely a no disturbance exercise. Just one little hiccup or lack of concentration can ruin hours of very accurate work.
You will also realise that with a basic dividing head, such as this is, NOT EVERY NUMBER IS CATERED FOR. There will be a few obscure ones, that if you do desperately need, you will have to make up your own dividing plate (or get someone to make up for you).
John Stevenson might be the one to approach in that situation, I know he does ones for Myford heads.
