Author Topic: Beaver Milling Machine Gearbox Repair  (Read 39790 times)
Re: Beaver Milling Machine Gearbox Repair
« Reply #25 on: October 08, 2009, 06:59:07 PM »
 :doh:
There's one in every crowd  :nrocks:
Offline ozzie46
« Reply #26 on: October 08, 2009, 07:36:42 PM »
 Sorry Darren I just couldn't resist.  :) :) :) :)
  Ron
« Reply #27 on: October 29, 2009, 02:53:05 PM »
Well this part was replicated in another post http://madmodder.net/index.php?topic=1959.msg21373#msg21373 and fitted to the Beaver gearbox.
You can just see it hiding in the background on the end of the motor shaft
http://i401.photobucket.com/albums/pp92/thebodger/Beaver/Gearbox%20Worm/IMG_3702.jpgBeaver Milling Machine Gearbox Repair
All the time I have been thinking about making this item there has been something in the back of my mind telling me something wasn't right.
I suspected that the old worn part was not the original, it just didn't look right. In fact it looked just like the one I have just made, new and shiny, not old from the sixties.
I decided to take a closer look at the securing grub screw which turned out to be 5mm ... well unless there is an imperial equiv to 5mm this as I suspected was not the original part. Add to that the bearing surface showed no signs of wear. My gut feeling was that this worm was not very old at all.
So that leads me to my next worry, if this was a new part then why was it needed? The rest of the machine shows very little wear so why is it now on it's third worm?
Not wanting to put my new freshly made part in to be ruined quickly I decided to scrutinise the way the whole contraption worked and what if anything might be wrong. Contraption it is too, lots of gears, shafts, levers, dogs etc. Very complicated for what it does.
There are a few bits in the bed, gears, leavers, dogs etc but I couldn't find much wrong there.
So I decided to rebuild the gearbox carefully.
Found it .... only just mind ....  :)
I assume originally the lid of the gearbox at one time had a paper gasket. It is no longer present and I'm assuming the worm problems began when it was first removed.
The problem is that when the lid is screwed down it pinches one of the shafts ever-so-slightly. Nip the screws down hard and it locks the shaft solid.
I'm assuming, yet again, that when someone took the gasket out and assembled without it the shaft turned so they didn't suspect anything. But as the gearbox motor runs constantly whenever the machine is powered up I suspect the parts heat up some. The shaft expands and the resistance increases possibly locking up solid.
So I made a gasket from a cereal box  :) 0.5mm thickness.
http://i401.photobucket.com/albums/pp92/thebodger/Beaver/Gearbox%20Worm/IMG_3701.jpgBeaver Milling Machine Gearbox Repair
Fitted it and tightened the screws down fully, no binding was felt
http://i401.photobucket.com/albums/pp92/thebodger/Beaver/Gearbox%20Worm/IMG_3704.jpgBeaver Milling Machine Gearbox Repair
All back together and given a test, seems fine
http://i401.photobucket.com/albums/pp92/thebodger/Beaver/Gearbox%20Worm/IMG_3706.jpgBeaver Milling Machine Gearbox Repair
I'm glad to say that it's now back on the machine and seems to be working fine. I'm hoping my gasket findings will prevent any further problem ...  :)
Hope I've not bored you ..... :med: but the thing is, if there is a problem then there is usually a reason. This one took me some finding and quite a few hours of scrutinising. I certainly wouldn't blame anyone missing the issue previously. but if there is a problem you really should try to find the cause ....  :coffee:
« Last Edit: October 29, 2009, 02:56:34 PM by Darren »
« Reply #28 on: October 29, 2009, 03:09:38 PM »
Darren, I was reading this all the way through as I was interested in doing something similar as John mentioned in a much much earlier post. Did you give in to the fact that the mini-lathe just couldn`t do it and you ended up using the Union?
« Reply #29 on: October 29, 2009, 03:14:47 PM »
Darren
It is like you said in one of your other posts. You take it apart and try and understand how it works then see why it's not working. Having the "KNACK" is what separates the mechanically minded from the rest. Good fix Darren.  :ddb: :ddb:
« Reply #30 on: October 29, 2009, 07:21:16 PM »
Chris,
The mini is just not capable to cut a 6tpi thread, no matter how gently you try to persuade it  :zap:
Thanks for the comments Don, time will tell if I got it right I suspect  :med:
Offline CrewCab
« Reply #31 on: October 29, 2009, 07:30:31 PM »
Nicely thought through Darren  :beer: I suspect your right, is the gearbox oil filled, no way those mating faces would be oil tight without a gasket.   :bow:
CC
« Reply #32 on: October 29, 2009, 08:03:52 PM »
Unfortunately the manual isn't very helpfull as it shows a different gearbox to the one fitted to my machine. No gasket shown on the exploded diagram but in the lube section it states Shell Vitrea 33/ Esso Esstic-50/ Mobil Vactra Heavy-Medium /Regen/Texaco Rando Oil C.
So I assume a gasket is required or I'd be wiping it off the floor daily  :doh:
Are any of those oils still around? I guess it doesn't matter much as long as a medium/thick oil is used.
Oh, the box has a drain plug, sorta gives it away really ...
