MadModder
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Project Logs
Home
Help
Search
Login
Register
MadModder
Gallery, Projects and General
Project Logs
Rose Engine Update
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Rose Engine Update (Read 10217 times)
old-biker-uk
Jr. Member
Taunton, Somerset
Rose Engine Update
on:
September 04, 2009, 04:59:08 PM »
Temporarily set upon the milling machine bed for a trial run (this accounts for the odd angle of the cutter frame).
If you've not seen them, there are some construction pics
here.
Mark
Logged
What you say and what people hear are not always the same thing.
CrewCab
Madmodder Committee
Hero Member
Re: Rose Engine Update
Reply #1 on:
September 04, 2009, 06:01:42 PM »
Absolutely stunning Mark, top class work Sir
CC
Logged
sbwhart
Global Moderator
Hero Member
Country:
Smile, Be Happy, Have Fun and Rock Until you Drop
Reply #2 on:
September 05, 2009, 01:18:45 AM »
Very interesting Mark and a lovely bit of improvisation
Wonderful bit of work
Did you make your own spindles for the fly cutter and cross drilling attachment what power are the auxillary motors and just one last question were they difficult to source, the reason I'm asking is I have a project in mind.
Thanks for showing
Have fun
Logged
old-biker-uk
Jr. Member
Taunton, Somerset
Reply #3 on:
September 05, 2009, 05:02:28 AM »
I made the cutter frame to the design at
www.ornamentalroseengine.com
modified to fit the bearings I had. The spindle is mild steel, cross drilled for the tool & grub screw then the bearings pressed on. The motor is a 1/10hp cap start by Ranco, it has seen better days and I shall be replacing it if I can dig out something suitable from the 'stores'.
The compound table was an epay purchase, in fact that was the only part that cost real money, everything else is recycled or stuff I had in the workshop.
Logged
Guest
Reply #4 on:
September 05, 2009, 05:43:26 AM »
Mark,
Now for the million dollar question.
With the setup you have, would it cut non ferrous metals?
Logged
sbwhart
Global Moderator
Hero Member
Country:
Reply #5 on:
September 05, 2009, 08:40:46 AM »
Thanks for the info Mark
Just bought 1/10 Hp motor that does 6000 revs off fleabay, the project i've in mind needs high revs.
Thanks
Logged
old-biker-uk
Jr. Member
Taunton, Somerset
Reply #6 on:
September 05, 2009, 11:38:56 AM »
I made it for woodwork but my mentor in things OT says it is robust enough to at least do line work on brass, NS etc. Will have to have go & see what happens
Mark
Logged
Guest
Reply #7 on:
September 05, 2009, 02:07:25 PM »
Thanks for that info Mark, it was just a general question, but one I have puzzled over for ages.
Logged
arnoldb
Hero Member
Country:
Windhoek, Namibia
Reply #8 on:
September 05, 2009, 04:17:06 PM »
Mark, that is an ingenious machine! I've never seen (or heard of) anything like it...
Thank you for showing and sharing!
Regards, Arnold
Logged
Print
Pages: [
1
Go Up
« previous
next »
MadModder
Project Logs
Rose Engine Update
