Author Topic: Punching out small gasket holes  (Read 11862 times)
« on: July 28, 2009, 11:44:20 AM »
When making paper or plastic gaskets for small engines, you have to punch or cut out a lot of small holes that need to match up with the part.
I came up with an little idea that will speed this process along.
What you need is one of those spring loaded outomatic centre punches.
You turn up a punch from silver steel with a nice deep centre drill in one end, you turn up a step the size of the hole you want to punch, harden it, and assemble it into the punch.
Use one of the parts as a guide in this case it a cylinder cover put the punch through one of the holes press it till it clicks keep the part positioned repeat for the next etc etc.
http://i431.photobucket.com/albums/qq32/sbwhart/Modmodder/100_2207.jpgPunching out small gasket holes
This is an example in a bit of paper with a spare puch and a brass bush that I used to grip it to turn the dia down along with a C o C to give you the idea.
Hope this little idea will be of use.
 :headbang:
Re: Punching out small gasket holes
« Reply #1 on: July 28, 2009, 12:38:25 PM »
Nice idea you got there Stew.  :thumbup:
Offline Andy
« Reply #2 on: July 28, 2009, 01:24:45 PM »
  :thumbup:  Good one - I'll store that idea away for future use.
From probably the smallest, dampest and most untidy workshop in Bradford, West Yorks, England, if not the world..
« Reply #3 on: July 29, 2009, 04:04:29 AM »
Nice one Stew!  :thumbup:
« Reply #4 on: July 29, 2009, 05:11:01 AM »
Thanks Chaps
Its good to share:-
I hope you all find it useful
 :nrocks:
Offline John-Som
    • Start Model Engineering
« Reply #5 on: August 20, 2009, 05:22:07 PM »
Hi Stew
On the same theme I have taken to making small circular PTFE ring gaskets for joint unions. To achieve concentricity (good word eh ?) I tape a square of PTFE to a piece of scrap wood. Clamp it to my bench drill table then a swift downward action punches the inner hole, switch to a large punch for the outside daimeter and finish up with neat concentric circles.
(sorry for misusing your bench drill Bogsie)
JohnS
start-model-engineering.co.uk - a friendly place for model engineering beginners
« Reply #6 on: August 20, 2009, 05:27:38 PM »
Good idea John more than one way to skin a cat  :thumbup:
